Old 04-10-2006, 11:12 AM   #1
DanCT
Member#: 84734
1998 Legacy GL
Default 98 Legacy - Removing OEM radio
I wasn't sure if I should post this here or in the Car Audio forum, but here goes.
I own a 98 Legacy GL here in Brazil. The OEM radio/cd player got a little old I am replacing it with a new one. Now, I would greatly benefit from a radio removal how-to. I did some searching but nothing consistent came up.
BTW, the Brazilian Legacy is made in Japan, so it is pretty much the JDM one driver-side swapped.
Thanks in advance.
DanCT is offline   Reply With Quote
Old 04-10-2006, 11:30 AM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I know I've seen some pictures etc, but cant seem to find them.
Should be pretty easy though. IIRC, its just a few screws hidden behind the "cupholder" and then a bunch of clips to get the plastic surround off, and then a few more screws to get the head unit out. There may be a writeup over on sl-i.net.
fibuz
fibuz is offline   Reply With Quote
Old 04-10-2006, 11:47 AM   #3
sha_zapple
Member#: 41012
1998 Legacy L
sha_zapple is offline   Reply With Quote
Old 04-10-2006, 01:00 PM   #4
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
That is a very good writeup.
Tip: For removing the ashtray, either have a very short philips screwdriver or a drill with an angled bit head to remove/insert the screws. They are a PITA to get at and can cause many headaches.
GTWagon_Phreak is offline   Reply With Quote
Old 04-12-2006, 07:17 AM   #5
DanCT
Member#: 84734
1998 Legacy GL
Thanks a lot.
Wow... that is a lot of trouble to install a simple radio.
Old 04-12-2006, 09:15 AM   #6
Kraziken
Member#: 38629
1999 Legacy GT (STI)
That doesn't look too bad, if your keeping the stock wiring.
If you look to upgrade the stock wires to monster cable or something I would think running the cables thru the car could be a pain in the rear, especially the rear speakers.
Kraziken is offline   Reply With Quote
Old 04-12-2006, 09:58 AM   #7
linsavy
Member#: 11620
1997 GF4-STiV3 clone
A phillips drill bit and some vice grips will do the trick too.
linsavy is offline   Reply With Quote
Old 04-12-2006, 10:16 AM   #8
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
Its not too bad actually. Its a lot easier if you run your sound wires on the driver's side of the car. Just fish the wires under the dash area where you instrument cluster is. Then you run them down behind the carpeting I believe to the door "foot panel" or whatever you call it. You can pop the "foot panels" off on the driver's side door areas and run wires under them easily. Then have them pop out near the rear seats and fish them up from there; at least that's easy with a wagon, no fixed rear seats to deal with. Not sure about the sedan.
Overall the install is pretty easy IMO, there are a lot more complicated radios to install.
Old 04-12-2006, 11:36 AM   #9
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
That's what i did, then i started leaving them loose enough to turn with the bit by hand. I've pulled my deck wayyy too many times.
Kawikid20o2 is offline   Reply With Quote
Old 04-12-2006, 01:38 PM   #10
spdracr00
Member#: 65823
1996 Impreza L
Red
i love it that you have to take the damn center console out to swap the radio.. man just put a new deck in the GF's wrx and man, popped the bezel and 4 screws later.. so easy.. almost like a honda...
spdracr00 is offline   Reply With Quote
Old 04-12-2006, 02:01 PM   #11
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
It's not. It only is moderately hard the first time you do it.
The second time, after you're familiar with the process, it takes about 2 minutes to pull everything off and pull the radio.
KD7000 is offline   Reply With Quote
Old 04-13-2006, 01:05 PM   #12
Legacy
Member#: 10188
2007 Forester XT
Your welcome , that's my writeup which I did after buying the 97 GT Wagon
spdracr00 - Some cars are easy, some are hard. On my 95 Jetta its a matter of removing two little pieces of trim on either side and the radio slides out. You can literally swap out the OEM deck and have a new deck in 2 minutes.
Then there's the 90's Caviliers which requires half the dash to come apart, a radio swap takes an entire morning.
Legacy is offline   Reply With Quote
Old 04-13-2006, 01:12 PM   #13
badbasser98
Member#: 104801
2011 WRX Limited
Or a small ratchet with a 1/4" hex socket and said phillips #2 bit.
badbasser98 is offline   Reply With Quote
98 legacy l - radio install tothaneck Legacy Forum 3 10-12-2007 05:52 PM
98 legacy - help removing stock radio tothaneck Legacy Forum 8 10-01-2007 09:45 AM
foglight removal question 98 legacy Wiscon_Mark Legacy Forum 7 04-18-2006 06:21 PM
WRX/Impreza OEM radio is mod-able same as Legacy/Outback JazzyMT Car Audio, Video & Security 3 03-09-2006 12:18 AM
oem radio removal.. 6 cd changer XT Nu2Subies Forester Forum 1 12-01-2003 10:46 PM
