#1 |
Member#: 12500
Ok so I just did the TGV delete mod and I thought I hooked everything back up. Car runs fine it's just that my fans will NOT turn off!!! Any ideas would be appreciated!
#2 |
Member#: 12500
No ideas?
#3 |
Member#: 50274
Vehicle:2004 WRX Wagon invisible |
Are you in test mode by chance? Under the dash there are the little connectors that you plug together.
#4 | |
Member#: 82378
South East
they still turn off though...hmmm interesting.. |
#5 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
Coolant temp sensor b0rked?
#6 |
Member#: 61617
Vehicle:2009 WRX 5-door Dark gray metallic |
yeah... that sounds like a sensor on/around the radiator not plugged up
#7 |
Member#: 12500
I'll check thanks.
#8 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
There is no sensor on or around the radiator. However you might have disconnected the coolant temperature sensor on the engine and not reconnected it, or it may be damaged. I'd expect you to have a CEL if this is what happened.
| Thread Tools | |
| Display Modes | |
| My rad fan won't turn off | shinjyo | Normally Aspirated Powertrain | 13 | 06-25-2007 01:11 AM |
| Lights Won't Turn Off...Need Help ASAP | whitecel | Electrical & Lighting | 5 | 05-28-2007 06:39 PM |
| My headlights won't turn off!! Please help!! | Carlito2002WGN | Newbies & FAQs | 15 | 05-23-2007 04:08 PM |
| radiator fans won't turn off | Arek | Normally Aspirated Powertrain | 18 | 12-08-2005 08:45 PM |
| My fans won't turn off? | rhd | Service & Maintenance | 19 | 05-24-2005 12:40 AM |
