Old 04-10-2006, 10:44 PM   #1
gopsu
Member#: 96448
02 WRX VF34
Default Intake resonator removal mod... question
I took out elbow and left snorkel in place. Am I suppose to take both pieces out as snorkel can feed water into intake box? What's the proper way of doing this mod?
gopsu is offline   Reply With Quote
Old 04-10-2006, 10:48 PM   #2
DeKaP
Member#: 90627
2005 Impreza WRX
Obsidian Black Pearl
the elbow and snorkus your talking about is one piece last time i checked, and theres a bolt holding it down behind the fender, loosen that and take it out
DeKaP is offline   Reply With Quote
Old 04-10-2006, 10:49 PM   #3
blazin sti
Member#: 84853
05 STI
aspen white
Do you have a short ram intake?if not you can take out the whole bladder in the fender and cut it up high and find a way to seal the hole i used another piece of plastic used some epoxy and it sealed pretty good ,or you can remove the bladder and buy a gp moto elbow instead of cutting the bladder.
blazin sti is offline   Reply With Quote
Old 04-10-2006, 10:54 PM   #4
MyloFMX
Member#: 106536
what exactly does the intake silencer do when you take it out? just curious...
MyloFMX is offline   Reply With Quote
Old 04-10-2006, 10:55 PM   #5
gopsu
Member#: 96448
02 WRX VF34
Snorkus I am talking about is triangular plastic piece that feeds incoming air into the elbow and eventually to intake box.
Old 04-10-2006, 10:59 PM   #6
gopsu
Member#: 96448
02 WRX VF34
No, I do not have a short ram intake. I took just elbow + bladder out while leaving snorkel back on. It should help feeding cold air into the fender wall. My concern is snorkel feeding water into side fender.
Old 04-10-2006, 11:20 PM   #7
wrX-RTD
Member#: 34969
03 WRX mbp
vf34 ap 2.5
by snorkel do you mean the 'ram-air' intake piece that leads into your fender well?
wrX-RTD is offline   Reply With Quote
Old 04-10-2006, 11:23 PM   #8
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
is there any cutting involved?
affinity1 is offline   Reply With Quote
Old 04-10-2006, 11:29 PM   #9
wrX-RTD
Member#: 34969
03 WRX mbp
vf34 ap 2.5
not for the silencer removal. its very straight-forward but getting the snorkel piece out of the fender can get a bit frustrating.
if i removed another silencer i would just remove the front passenger wheel. my fender liner looks like trash now as some of the plastic screws were old and cracked while pulling the liner off.
Old 04-10-2006, 11:34 PM   #10
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
yes, it is.
I believe function of bladder is to keep water away from intake box... what would happen if elbow+bladder is removed? will ram air lead water into intake box?
Old 04-10-2006, 11:37 PM   #11
wrX-RTD
Member#: 34969
03 WRX mbp
vf34 ap 2.5
Originally Posted by txl146
yes, it is.
i removed mine last week and was told to take out both pieces. got a part number for a fender plug from subaru. its actually for the 99-01 2.5RS but it fits the impreza like stock.
i would say remove both pieces and pick up the plug. ran me $4 at my local subaru dealership.
EDIT: with both pieces removed i wouldnt think there could be a problem. even with the ram-air piece still in, if water somehow got in it should go into your now empty fender well since you removed the large snorkel piece.
Old 04-10-2006, 11:41 PM   #12
gopsu
Member#: 96448
02 WRX VF34
I have a fender plug. However, hot air from engine bay can still move into stock intake box through gap between intake box and fender wall.
Old 04-10-2006, 11:48 PM   #13
wrX-RTD
Member#: 34969
03 WRX mbp
vf34 ap 2.5
wouldnt that gap be there regardless of the ram-air being removed or not? dont feel like walking outside and i cant remember for sure. =P
i think you are gonna get a little heatsink whether its there or not. if you have the plug im thinking you will be fine. lots of others have done the mod with no issues that ive heard of.
Old 04-10-2006, 11:52 PM   #14
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Snorkel will snugly fit into stock air intake box, so hot air shouldn't go into stock intake box.
Old 04-11-2006, 12:01 AM   #15
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
is there a writeup somewhere that you guys used as reference?
Old 04-11-2006, 12:05 AM   #16
wrX-RTD
Member#: 34969
03 WRX mbp
vf34 ap 2.5
Old 04-11-2006, 12:12 AM   #17
theicewall
Member#: 70532
2004 WRX
The purpose of the silencer box in the fenderwell is not so much a silencer but it is supposed to be a pressurized compartment that increases response in off on throttle application by maintaining a vacuum pressurized compartment. It also happens to reduce turbo noise. When I removed mine completely stock I noticed a decrease in response but a little bit more pull overall. Now I am stage II so it was pretty much only for the noise but an uppipe and downpipe give so much more turbo noise that the resonator was pretty much pointless to remove actually. I have the GP elbow and the stock funnel in because the location of the stock funnel is supposed to pull air from a high pressure pocket that forms between the hood and the front grill when you are driving.
theicewall is offline   Reply With Quote
Old 04-11-2006, 12:18 AM   #18
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
theicewall, shouldn't high pressure pocket pull in water into intake box? I though purpose of bladder was to also capture water away from going into intake box...?
Old 04-12-2006, 06:30 PM   #19
crewin323
Member#: 95837
2005 WRX
WR Blue
How does the silencer mod affect air turbulance in the intake?
crewin323 is offline   Reply With Quote
Old 04-12-2006, 06:55 PM   #20
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
I picked up some foam insulating tape from Home Depot and put two layers of it around the hole in the intake box. It makes a pretty reasonable seat against the fender wall.
I'm planning on putting my silencer back in though. The sound was cool for a while but it's gotten annoying. I also feel like the engine is a little more "lumpy" now.
athakur999 is offline   Reply With Quote
Old 04-12-2006, 07:13 PM   #21
johnnyb
Member#: 57593
2015 Crosstrek XV
You know how you can drive around in comfort when the weather is around 80 degrees without turning on the A/C? If you are pulling in hot air from the engine bay, you can kiss those days goodbye. Even on the coolest setting, the air comes into your car warm. No good. Keep the stock intake unless you have a FMIC.
johnnyb is offline   Reply With Quote
Old 04-12-2006, 08:39 PM   #22
xplane
Member#: 66152
04 wrx sti
blue
Actualy removing the snorkus it draws cold air from the fender as there are small openings in the fenderwall that allow it to get colder air, regadless its everyones opinion on the efficiency but what has been proven that the removing it increases spool up by reducing turbulance in the path the air has to take to reach the turbo....I can't remember where I read this...
xplane is offline   Reply With Quote
Old 04-13-2006, 12:35 PM   #23
theicewall
Member#: 70532
2004 WRX
That's never been proven by anyone. And the air in your fenderwell is semirestricted by the fact that your fenderwell is a closed space and the air funnel that came on the car draws fresh air from the front grill. If you want to get rid of anything get rid of the silencer box but keep the U-turn in your fender and keep the funnel.
Drawing air straight from your fender without it is more likely to cause turbulence hence why acceleration is often a bit studdering... airflow is studdering. Having air flow through a tube that funnels gradually is a less abrupt transition from open space to small space. That's why the WRC 32mm restrictor isnt just a hole, its a funnel that gradually becomes smaller and then gradually becomes larger. If you are going to do this mod, either buy the gpMoto elbow, or hack up your snorkus to look like it but keep everything else the same. Intake mods are a waste of time and money on our cars. Some people like the typhoon intake but those seem to be STi people with custom tunes for them. Get an uppipe if you want better spool and woosh noise. Get a downpipe if you want a huge power increase. End of story.
Air intake resonator removal mod gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-04-2006 08:10 PM
Lookin for help on intake silencer removal mod wit2003 New England Impreza Club Forum -- NESIC 13 03-16-2006 09:28 AM
Where do I get an intake resonator remover? Daytona STi Forum Archive 7 07-09-2003 12:56 AM
Intake resonator removal ? new2rice Normally Aspirated Powertrain 4 02-01-2003 10:24 PM
Air Intake Resonator Removal zensvx SVX Forum Archive 6 07-11-2000 06:51 AM
