Old 04-11-2006, 01:14 AM   #1
Peeblesmx445
Member#: 92202
Default Crawford R4 info?
Did a search and found some VERY old info. Just wondering if there was anybody running this motor and what you experience is with it + any other info you guys have in relation to this motor. Thanks
Peeblesmx445 is offline   Reply With Quote
Old 04-11-2006, 09:45 AM   #2
sabreofsd
Member#: 48943
2004 95%*STi Blu/Gld
www.dcawd.com
You might want to check this thread before making any decisions!
sabreofsd is offline   Reply With Quote
Old 04-11-2006, 10:54 AM   #3
scoopy100
Member#: 62557
04 WRX
WRBlue
dude read the facts, not someone who's pissed for something that was his own fault out on a smear campaign
try this one
http://www.crawfordperformance.com/r...info.cgi?id=12
scoopy100 is offline   Reply With Quote
Old 04-11-2006, 10:56 AM   #4
scoopy100
Member#: 62557
04 WRX
WRBlue
Old 04-11-2006, 11:18 AM   #5
Peeblesmx445
Member#: 92202
anybody else?
Old 04-11-2006, 12:21 PM   #6
flycaster
Member#: 60142
2011 WRX
Grey
I'm confused. Since I have to assume you refer to the car owner, could you please explain exactly why you believe this was "his own fault?" To me, the evidence points conclusively to either an assembly error or manufacturing defect - not to mention very poor customer service follow-up.
flycaster is offline   Reply With Quote
Old 04-11-2006, 12:37 PM   #7
wrex03
Member#: 29963
04 sti
try this one
And I bet you believe the earth is flat
wrex03 is offline   Reply With Quote
Old 04-11-2006, 12:41 PM   #8
happasaiyan
Member#: 37731
only if quirt says so.
happasaiyan is offline   Reply With Quote
Old 04-11-2006, 01:19 PM   #9
Peeblesmx445
Member#: 92202
This was not intended to be a flaming thread. Lets get back on topic
Old 04-11-2006, 01:40 PM   #10
Physics Junkie
Member#: 65609
What info in particular are you looking for?
Physics Junkie is offline   Reply With Quote
Old 04-11-2006, 02:18 PM   #11
Peeblesmx445
Member#: 92202
Anything updated! After I searched it appears there were only 2 of them floating around on this board and alot of the info was somewhat unclear of what the motor is capable of. Has anybody been running this motor for a while and is there any dyno graphs / hp numbers anywhere to be found????
For such an expensive and extreme motor I would assume there would be more info available on it. I guess I could go off the fact that the BV Team was using the R3 in there 9.67 STI.......
Old 04-11-2006, 03:16 PM   #12
Physics Junkie
Member#: 65609
Well, there are only 4-5 of them out there(according to the guy who sold me my axis stage 5 to go with a crawford R4)
Old 04-11-2006, 03:22 PM   #13
flycaster
Member#: 60142
2011 WRX
Grey
So you've owned 'em both? What's the scoop?
Old 04-11-2006, 05:08 PM   #14
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
the situation with my motor was caused by crawford's negligence and quality control deficiencies. there's a big difference between telling the truth and waging a smear campaign. the next time you want to talk crap about me, make sure i'm in the room. better yet, make it in person.
quirt dropped undersized pistons with .006 -.007 piston to wall tolerances into my s4, refused to replace the motor and then lied about it - period. detonation had nothing to do with the demise of my motor. it was junk before it left his shop.
to the original poster: do your homework. crawford motors are fast as hell but you better hope he builds you a good one or you are stuck with it. if that's ok with you, then go get one.
MeetMrGlock is offline   Reply With Quote
Old 04-11-2006, 05:19 PM   #15
Peeblesmx445
Member#: 92202
Aside from the P to W clearances sharade , has anybody heard of anything else that Quirt apparently doesnt do right as far as building his motors? As if I couldnt have the P to W clearances checked before installation by a local shop.
Old 04-11-2006, 05:25 PM   #16
nxttruck2002
Member#: 90879
http://forums.nasioc.com/forums/showthread.php?t=961979
Originally Posted by Crawford Performance
We run .0035" clearance on the 3.9175" bore pistons
Quirt Crawford
Quirt FTL...
nxttruck2002 is offline   Reply With Quote
Old 04-11-2006, 05:39 PM   #17
Peeblesmx445
Member#: 92202
Old 04-11-2006, 06:07 PM   #18
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
say that out loud to see how many people laugh: you are going to buy a 10,000. r4 crawford motor and you are going to take it to a local shop to make sure quirt's piston to wall clearances are correct.
two questions:
- should they check anything else while theyre at it?
- is quirt paying your local shop to do his quality control for him? if so, i might even buy another crawford motor.
Old 04-11-2006, 07:33 PM   #19
bboy
Member#: 56468
04 Improved STI
Dirty White
http://www.subarumotors.net/
http://www.axispowerracing.net/
http://www.gruppe-s.com/
Why wonder? If you ask, any of these folks will send you all the measurements. They have all built multiple Subaru motors. It's not rocket science, just careful machining, measuring, and torquing. In the end, they are all engine assemblers and you are paying them a lot of money to assemble your motor from parts that you can buy yourself (and assemble yourself if you like). You are paying them for their experience at the assembly process, not a bunch of hot air bragging and snubbing of other assembler's fine work.
Old 04-11-2006, 08:01 PM   #20
Peeblesmx445
Member#: 92202
two questions:
Well, better to be safe than sorry.I got the brand new motor for a complete steal so It wouldnt be a big deal to me to double check Quirts clearances out of peace of mind before I install it in my car (if I even do).
I am aware of the whole bobble piston ordeal and I completley lean towards your side of things but you cant tell me he built ALL his motors like that. This motor was built for a very extreme subaru project for (i believe) a freind of Quirts, so hopefully he took his time with this one and its PERFECT
But I still want to gather as much info on this motor as I can seeing there isnt a lot out there.
Like I said, aside form P to W clearances, has anybody else had any other problems with a Crawford motor???
Old 04-11-2006, 08:10 PM   #21
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
i never would. i wish you great luck with it.
Old 04-11-2006, 08:30 PM   #22
Peeblesmx445
Member#: 92202
Never would what? put it in your car? I understand your misfortune as it is a raw and crappy deal but look at the success he has also had with his motors, ie: BV Team......
Maybe it is all his fault that your motor was crap but then its also all his fault that the BV team has had much success with his R3.
After reading all the crap about Quirt and his motors I have to say Im a little scared to put this motor in my car but at the same time while I read all the bad stuff , its not a far turn to read the great stuff. Back on topic INFO!!!
Old 04-11-2006, 09:15 PM   #23
PA04STI
Member#: 37418
0491 STi FPGreen'd
GSX Evo III 16G
Ask the kid that bought that Top Secret Gold STi. His R4 is for sale & blown! on IWSTI.com & here for sale.
PA04STI is offline   Reply With Quote
Old 04-11-2006, 10:14 PM   #24
Member#: 42075
Please check the clearances on your motor and post the results. I can guarantee that they will be spot on, but I can't guarantee that the motor will live. At this point the life expectancy of your motor it is out of my control.
Good luck and keep us posted
Quirt Crawford
Crawford Performance is offline   Reply With Quote
Old 04-12-2006, 12:42 AM   #25
Peeblesmx445
Member#: 92202
Quirt Crawford
what exactly is that supposed to mean?
Crawford Performance R4 and CP35R: 592whp, that's right whp Crawford/I-Speed Proven Power Bragging 168 06-29-2006 10:30 PM
BRAND NEW Crawford 2.8 R4 Shortblock Peeblesmx445 Private 'For Sale' Classifieds 20 05-31-2006 04:30 PM
The Crawford R4-CP35R STi Package Takes 2 2nd Place Trophies at the NASA Time Trials Crawford/I-Speed Motorsports 33 05-31-2006 01:51 PM
Crawford Performance R4 and CP35R: 472hp, 489tq, 91 Octane Crawford/I-Speed Proven Power Bragging 24 05-12-2006 03:37 AM
Crawford Performance R4 and CP35R: 572hp, 551tq, 23psi Crawford/I-Speed Proven Power Bragging 60 02-05-2006 12:15 AM
