Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-03-2001, 12:26 PM   #1
SubyBean
Member#: 4367
1999 IMPREZA 2.5RS
Black :-( with dings
Default help spark plugs with zex??
ok i was told i need to run different spark plugs when running my zex, they told me i need to run 2 ranges colder than my stockers.
so does anyone who runs nitrous have a part # for some plugs i can use??
thanks guys
Brian
SubyBean is offline   Reply With Quote
Old 10-03-2001, 12:31 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i know the 2 stage colder number for the MY00-01, not sure for your car. And yes they are right you need to run 2 stages colder to prevent detonation or pre-ignition.
Jeremy
Old 03-05-2002, 12:23 PM   #3
ND4SPD2000
Member#: 6496
2000 Impreza 2.5 RS
Sedona Red Pearl
Default MY00 RS
Sup,
What spark plugs should I get for my 2000 Impreza RS running on a ZEX kit? Do you know the part number?
ND4SPD2000 is offline   Reply With Quote
Old 03-05-2002, 12:38 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
NGK BKR7EVX-11
kastle is offline   Reply With Quote
Old 03-06-2002, 12:08 AM   #5
tec
Member#: 12649
your car has some serious issues if you have detonation for the few seconds your on the bottle. most people on this bord don't have the nut's to run more the a 55 shot with a zex kit! it sounds like you need more fuel pressuer or higher octane gas. check your plugs to see if they are white! don't use octane booster! some aftermarket chips will pull back your timing! one step colder is ok but you should not need it for less that 80 hp shot. check the zex brain! there might be teflon tape or past cloging a mesh filter inside a solenoide?
I'm going to run a 100 shot with 25% tulene and 93 octane pump gas, i don't think i will need it! but it runs are all track with greddy TDO6-SH (20g) @ 18 psi with stock fuel system.
tec is offline   Reply With Quote
Old 03-06-2002, 12:34 AM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Don't listen to who ever told you to run 2 stages colder! That would be an NGK 8 plug! That is way to cold since you are only going ot be on the bottle for short bursts and not on the bottle most of the time. Personally, when I ran with just nitrous (before the turbo) I rna the NGK 6's which is a stock het range plug. You can either do that or go with the NGK 7's but do not go with 8's. you will fowl them or something.
And remember, NGK numbers (6,7,8) are backwards from most spark plug companies where the lower the number (with most companies), the colder the plug.
Eric
Eric SS is offline   Reply With Quote
Help! Spark Plug Popped out of engine! esbee Normally Aspirated Powertrain 27 08-12-2006 11:26 PM
Emergency: Help! Spark plug changing weirdness poison Normally Aspirated Powertrain 12 02-24-2005 12:10 PM
Emergency: Help! Spark plug changing weirdness!!!1!! poison Off-Topic 29 02-13-2005 01:40 AM
HELP! Spark Plug Coilpack order? Mr. Mercado Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-11-2004 11:40 AM
Shoul I use colder replacement spark plugs with this setup? MMastro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-24-2003 08:30 AM
