Old 04-11-2006, 02:08 PM   #1
DRNWAGN
Member#: 44255
03 Infiniti I35
Default 06 WRX + vf39 + AP stage II STI
Anyone swapped the stock turbo for a vf39 and tried to run an 06 AP sti stage II map yet? I know we used to be able to do this on our 04 FXT's but was wondering if it is possible on the 06's (wrx). I will be installing my vf39 soon enough and do plan on doing a protune but was curious if the sti maps will work or not. I am more so concerned about the timing of getting the turbo on the car with all the appropriate bolt on mods and then making the 60 mile drive to MachV for the tuning session. I have known of some people driving their fxt all the way to NJ for a tune with a 39 in place and just stayed out of boost for the trip but I am not sure I want to do that just yet. Just trying to think of a safe way that I can drive the car there for the tune without anything blowing up on the way.
DRNWAGN is offline   Reply With Quote
Old 04-11-2006, 02:17 PM   #2
hornyturbo
Member#: 108618
2010 10 RX350, 04 A4
12 IS350, 08 STI
why dont you just use the vf39 ots map from cobb?
hornyturbo is offline   Reply With Quote
Old 04-11-2006, 02:20 PM   #3
DRNWAGN
Member#: 44255
03 Infiniti I35
I did not realize they had that out already. Hell, no problem then. I can simply load that up and drive to the tuning session with out a hitch! Sweet!
thanks,
Old 04-11-2006, 03:59 PM   #4
Chiketkd
Member#: 71634
In hibernation...
You'll also need the STI TMIC to run that Map. Not sure if you've installed one in your car yet...
Chiketkd is offline   Reply With Quote
Old 04-12-2006, 06:26 AM   #5
DRNWAGN
Member#: 44255
03 Infiniti I35
Got one! Looks like I might be going with a vf22 and having it made into an 1820 as my friend has one lying around.
FS: Cobb AP Stage II 2005 STI powerslide23 Engine/Power/Exhaust 6 11-16-2007 10:28 AM
spotted. coppell. 06 aspen white stage II STI. lowranger Texas Impreza Club Forum -- TXIC 14 02-22-2007 11:13 AM
Aqua Mist 50/50% mix kicks butt on Stage II STI 06 - Dyno Flashed! Dyno Flash Proven Power Bragging 5 01-10-2007 11:59 PM
06 wrx vf39 cobb stage 3 numbers dodiox Factory 2.5L Turbo Powertrain 13 02-22-2006 02:27 PM
At altitude: Running extremely rich AP stage II REXRED04 Engine Management & Tuning 11 09-17-2005 11:00 AM
Message Board Statistics All times are GMT -4. The time now is 06:25 PM.
