Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 04-12-2006, 01:10 PM   #1
SuperSmog
Member#: 91926
05 sti
Default AP Question
Hi. Does stage2 run too rich for everyday drive? is it recommended to run stage1 for normal day to day drive? is it ok to drive stage1 with tbe catless? I don't want to build up carbon and raise compression running stage2
SuperSmog is offline   Reply With Quote
Old 04-12-2006, 03:06 PM   #2
toke513
Member#: 16272
2004 WRX Wagon
If you have TBE it is a better idea to run stage 2. Many people have been running stage 2 for a long time without any problems. Your stock EM runs very rich under WOT, I would guess probably even more so than AP.
toke513 is offline   Reply With Quote
Old 04-12-2006, 03:38 PM   #3
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
The map notes say no. Wastegate duty cycles will be worlds different and lead to irratic, un-reliable boost when running a stage one map with a stage two setup
One of these day's I'll compile all the map notes and make a thread, I think that would be worth a sticky if anyone else wants to beat me to it.
parker/slc/gc8fan is offline   Reply With Quote
Old 04-12-2006, 03:41 PM   #4
Chiketkd
Member#: 71634
In hibernation...
During normal around town driving, your ecu will be in closed loop operation and afr's will be kept lean at stoich. Once you romp on the throttle, and your ecu is thrown into open-loop, according to Cobb's site, with their Stage 1 the afr is 11.2:1 on boost tapering to 10.8:1 by redline. With their Stage 2 set-up, the afr is slightly leaner at 11.4:1 on boost tapering to 11.0:1 at redline.
http://cobbtuning.com/sti/power-s.html#Stage1 <- click the Stage 1 and Stage 2 graphs to see afr's
Chiketkd is offline   Reply With Quote
Old 04-12-2006, 03:50 PM   #5
Chiketkd
Member#: 71634
In hibernation...
FYI, this is a caution that Cobb lists in bold on their Map notes for the 2006 WRX Stage 1 - I don't see it listed in the STI Map notes but it may still apply:
CAUTION!!! DO NOT RUN ANY Stage1 MAPS WITH ANY TYPE OF HIGHER FLOWING DOWNPIPE OR TURBO-BACK EXHAUST ON YOUR 2006 WRX. THE Stage1 MAPPING HAS VERY HIGH WASTEGATE DUTY CYCLES SETTINGS TO TRY AND BRING BOOST ON AT LOWER RPMS. THESE SETTINGS WILL INDUCE SEVERE BOOST SPIKING AND WILL OVERSHOOT THE TARGETS CAUSING BOOST SEARCHING. THESE SPIKES CAN CAUSE ENGINE DAMAGE. IF YOU HAVE A HIGHER FLOWING DOWNPIPE OR TURBO-BACK EXHAUST SYSTEM ON YOUR 2006 WRX, PLEASE USE THE APPROPRIATE Stage2 MAPS.
Old 04-12-2006, 04:08 PM   #6
SuperSmog
Member#: 91926
05 sti
You Guys Are Awsome Thanks.
AP- question Need help Married AP!! subadrifta06 AccessPort 13 12-19-2007 03:16 PM
AP Question... F3nom3ni Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-08-2004 05:51 PM
STi AP questions -=Fox=- Engine Management & Tuning 0 11-03-2004 01:37 AM
AP question rallyme Engine Management & Tuning 1 10-07-2004 11:31 PM
More AP questions AchmedRodriguez Engine Management & Tuning 9 09-12-2004 09:13 AM
