Old 04-11-2006, 05:41 PM   #1
drdeuce
Member#: 36075
2004 STi 2.65L GT35R
Hydra
Default AVCS advance clarification
I'm installing new ported heads with 1mm oversized valves and DPR cams. I'm using a Hydra for tuning.
Phil wanted to know at what degree of advance would there be interference between the intake and exhaust valves. He said that AVCS can advance the intake cams about 15 degrees, so if I install the timing belt but advance the intake cams two teeth while keeping the exhaust cams in normal position, I should be able to see if there is interference by very slowly turning the belt.
The question I have, and even Phil wasn't sure, is to advance the intake cams should they be rotated slightly clockwise (same as the crank turns) or counterclockwise. Phil said he thought clockwise because the crank turns counterclockwise, but that doesn't seem right as I consider the crank to turn clockwise and he said he was unsure himself.
And also, just to confirm, the AVCS does advance the intake during the lower RPM range to increase torque/spool, correct?
drdeuce is offline   Reply With Quote
Old 04-12-2006, 01:05 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....I believe this is a 'built motor' forum question
Old 04-12-2006, 07:53 AM   #3
TheMadScientist
Member#: 23717
2005 Big red
In street tuner the Cobb Stg2 map has 25* of advance, and cobb says not to go over ~30*. So I don't know where Phil got the 15* from.
TMS
TheMadScientist is offline   Reply With Quote
Old 04-12-2006, 11:21 AM   #4
syoung0298
Member#: 84772
2005 GDB STI
From what I was told by Cobb, the AP/ST AVCS values were computed via camshaft rather than crankshaft values, effectively doubling the net user viewable number. Therefore 15 degrees of crankshaft advance would be equivalent to 30 degrees of cashaft advance. The hydra avcs advance values are computed over crankshaft rather than camshaft and so are the ECUTEK and stock ECU. I know that Cobb discussed making mods in future versions of the ECU to update this; however I'm not sure if the change has been made. It's really not a big deal, as long as the values and their relative effect is understood by the tuner.
My $02.
syoung0298 is offline   Reply With Quote
Old 04-12-2006, 01:36 PM   #5
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
My $02.
that would make sense since cam gears are 1/2 the diameter of the crankshaft.
Illusive is offline   Reply With Quote
Old 04-12-2006, 01:50 PM   #6
RainMaker
Member#: 93301
06 CGM STI SM#17
Now with alot less verve!
Here I was thinking it was the other way around
RainMaker is offline   Reply With Quote
Old 04-12-2006, 01:52 PM   #7
drdeuce
Member#: 36075
Hydra
OK, so to advance timing, the camshaft would be effectively turned counterclockwise (opposite direction of the crankshaft rotation), so that it is at BTDC earlier, correct?
thanks
Old 04-12-2006, 02:39 PM   #8
Agile Auto
Member#: 91335
My $02.
right on the money
Agile Auto is offline   Reply With Quote
Old 04-12-2006, 03:20 PM   #9
bboy
Member#: 56468
04 Improved STI
Dirty White
Once you have changed the lift and duration, you won't know if you can get interference, but I'd think with degree wheels on both the intake and exhaust cams (no belt, heads off) you should be able to determine how many degrees of intake advance is possible without interference. Mike at Gruppe-S might know the answer to your question as he spent a lot of time with the DPR cams and degree wheels.
Old 04-12-2006, 05:35 PM   #10
drdeuce
Member#: 36075
Hydra
Why wouldn't I be able to tell? According to Phil, who usually knows what he's talking about, i should test this with the timing belt on and advance the intake sprockets and carefully check for any interference. Are you saying Phil is wrong?
Old 04-12-2006, 07:12 PM   #11
RainMaker
Member#: 93301
06 CGM STI SM#17
there's static interference, and then there is what is safe at 7000 rpm. Domestic folks have a pretty standard Piston-Valve clearance number between .050 and .035 depending on the angle of the valves and other stuff. I dont know how you would perform the old clay test unless you did it for a whole bunch of different AVCS advances, which is why Mike at Gruppe-S probably spent a long time at it.
Old 04-12-2006, 08:45 PM   #12
bboy
Member#: 56468
04 Improved STI
Dirty White
I meant you "don't know" once you move from the stock lift and duration, not "can't tell." I'm saying with a degree wheel you'll know how many degrees you need to keep them apart.
The crank turns clockwise when looking at the enginen from the front of the car and the opposite when you have the clutch off, looking toward the front. I'd have to look up the camshafts and the path of the timing belt.
Old 04-12-2006, 09:06 PM   #13
bboy
Member#: 56468
04 Improved STI
Dirty White
The crank and cams all turn clockwise. The intake cam is advanced by moving it further clockwise relative to the exhaust cam.
Old 04-13-2006, 12:21 AM   #14
drdeuce
Member#: 36075
Hydra
My $02.
This confuses me. There are 24 teeth on the crank and 48 teeth on the cam sprocket. So if I advanced the crank one tooth (15 degrees) the Camshaft only turns half as much and would only be advanced 7.5 degrees.
How does 15 degrees of crankshaft advance equal 30 degrees of camshaft advance. Seems to me that it would be the other way around. What am I missing here?
Old 04-13-2006, 12:55 AM   #15
drdeuce
Member#: 36075
Hydra
According to this document: http://www.drivesubaru.com/Win05_WhatsInside.htm
AVCS can advance the "CRANKSHAFT TIMING" as much as 35 degrees. This is slightly more than two teeth on the crank pulley (30 degrees). And since the camshaft pulleys move 1/2 the speed of the crank, 35 degrees of CRANKSHAFT advance would equate to about 17.5 degrees of CAMSHAFT advance.
Therefore, if cobb says it can advance it 30 degrees, this must be based on Crankshaft advance. This would also indicate that Phils statement about 15 degrees is correct if it applies to Camshaft rotation.
So based on this, the above info appears wrong to me. The Cobb must be referring to Crankshaft advance, whereas the Hydra is based on Camshaft advance.
Old 04-13-2006, 08:22 AM   #16
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
When I had a chance to talk to my tech what Bboy said is correct, rotation is clockwise and rotating the cam sprocket clockwise advances the cam. I should have remembered this since I watched while this was done This is why I tune the engines and don't build them
How the AVCS "target" is determined is irrelevant in this case but for the record the Hydra’s targets are also in “crank degrees” but the values used are on a different scale than 0-30 degrees. Two teeth on the cam sprocket is approximately what the AVCS system is capable of moving the camshaft and is absolutely the easiest way to check clearance. There are more precise, more difficult, more expensive, and more time consuming ways to determine interference.
This isn’t rocket science. If you want to know exactly how many degrees one tooth of the cams sprocket is then count the number of teeth and then divide 360 by that number. 360/48 = 7.5 degrees per tooth on the cam sprocket. On the crank sprocket there are 24 teeth so 360/24 = 15 degrees per tooth.
This will conclude our math lesson for the day
Thanks,
Phil
http://www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 04-13-2006, 12:44 PM   #17
drdeuce
Member#: 36075
Hydra
Thanks Phil, this confirms what i thought was true. Basically advancing the intake sprockets two teeth forward (15 degrees) would equate to 30 degrees of crankshaft timimg advance.
Old 04-13-2006, 05:50 PM   #18
bboy
Member#: 56468
04 Improved STI
Dirty White
The crank rotates twice for every 4-stroke engine cycle, so the cam degrees are half the crank's because of the exhaust stroke. In a 2-stroke each cycle corresponds to crank turn.
Using the belt and the teeth is practical for a go or no-go assessment.
Nice to know the number of teeth, I've never counted them. Good luck!!
Maximum AVCS Advance w/ Cosworth cams? wittmer25 Built Motor Discussion 44 02-08-2010 11:12 AM
Too much AVCS advance? Infamous1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-08-2008 11:39 AM
Maximum AVCS Advance w/ Cosworth cams? wittmer25 Open Source Reflashes 3 01-17-2008 11:34 PM
AVCS advance dwx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-13-2004 02:57 PM
AG970 STi RA ECU and AVCS Advance... 30 degrees? dug-e-fresh Engine Management & Tuning 0 11-04-2003 04:10 PM
