Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-11-2006, 07:08 PM   #1
MidRex
Member#: 32841
2007 STI (Sold)
03 WRX FP Green PPG (RIP)
Default Please check my logs from today
I recently changed to BKR7E plugs and wanted to make sure everything still was ok.
2nd gear pull:
Code:
 4301 +11.9 3.9  98  80    00   W/B  +17.5   58.4 +16.0  +0.3 400.00 3.6  11.01
 4438 +14.5 4.0  98  90    00   W/B  +16.8   63.1 +16.0  -0.9 400.00 3.7  11.05
 4728 +16.6 4.0  98 100    00   W/B  +19.3   64.4 +17.1  -1.1 400.00 3.7  11.30
 4852 +17.4 4.1  98 100    00   W/B  +21.9   71.8 +18.4  -2.0 400.00 3.7  11.33
 5035 +17.4 4.1  97  90    00   W/B  +23.1   74.0 +19.5  -2.3 400.00 3.8  11.18
 5274 +17.6 4.2  98  90    00   W/B  +24.4   76.3 +20.0  -2.5 400.00 3.8  11.11
 5518 +17.0 4.3  98  90    00   W/B  +25.1   83.7 +20.0  -1.6 400.00 3.9  11.14
 5747 +17.4 4.3  98 100    00   W/B  +24.9   84.8 +20.0  -1.4 400.00 4.0  11.08
 5827 +17.6 4.3  97 100    00   W/B  +25.5   85.7 +20.0  -1.3 400.00 4.0  11.05
 6184 +17.4 4.4  98  90    00   W/B  +26.5   88.2 +20.6  -1.2 400.00 4.0  11.01
 6242 +16.8 4.4  97  80    00   W/B  +26.5   88.3 +21.0  -1.3 400.00 4.0  10.89
 6447 +15.7 4.4  98  80    00   W/B  +29.3   90.0 +21.0  -1.3 400.00 4.0  10.80
 6184 +12.9 2.6   0  60    00   W/B  +10.7    6.8 ECU.   -1.1 LCM.   1.3  10.81
 5807  +6.4 1.6   0  10    00   W/B  +10.8    7.1 ECU.   -2.5 LCM.   1.7  12.78
 5350  -0.2 2.1   0  10    00   W/B  +11.0    8.4 ECU.   -2.9 LCM.   1.8  24.81
 5104  -6.7 2.1   0  10    00   W/B  +11.0    8.7 ECU.   -3.6 ECU.   1.9  >25:1
 4572 -10.8 2.1   0  00    00   W/B  +11.4   32.1 ECU.   -1.0 ECU.   1.9  >25:1
 4450 -11.2 2.0   0  00    00   W/B  +11.2   32.1 ECU.   -1.0 ECU.   1.8  23.82
 4432 -11.2 2.0   0  00    00   W/B  +11.2   32.1 ECU.   -1.0 ECU.   1.4  21.40
3rd gear pull:
Code:
 3775  -7.5 2.4  11  00    00   W/B  +41.2   13.5 ECU.   -1.0 ECU.   2.3  13.53
 3840  -6.1 2.9  29  10    00   W/B  +35.8   21.6 +30.1  +0.5 ECU.   2.8  13.53
 3903  -4.0 3.2  56  10    00   W/B  +30.6   28.7 +28.0  +0.5 300.00 3.0  13.28
 3930  -1.2 3.3  88  20    00   W/B  +30.5   35.6 +25.3  +0.4 WGS.   3.1  12.78
 4030  +2.3 3.7  91  40    00   W/B  +25.5   45.2 +19.0  -0.3 WGS.   3.5  12.11
 4145  +6.2 3.7  92  50    00   W/B  +19.5   53.7 +16.9  +0.1 WGS.   3.6  11.61
 4246 +10.0 4.0  94  80    00   W/B  +16.7   57.5 +15.6  +0.4 400.00 3.6  11.30
 4351 +13.1 4.0  95  90    00   W/B  +16.4   60.7 +16.0  +0.4 400.00 3.6  11.23
 4403 +16.4 4.0  95 100    00   W/B  +16.3   64.1 +16.0  +0.2 400.00 3.7  11.42
 4522 +18.6 4.1  95 100    00   W/B  +17.1   66.2 +16.6  -0.3 400.00 3.7  11.62
 4629 +19.6 4.1  97 100    00   W/B  +18.5   68.8 +17.1  -1.0 400.00 3.7  11.62
 4844 +20.0 4.1  97 100    00   W/B  +20.5   70.8 +18.2  -1.3 400.00 3.7  11.49
 4952 +20.0 4.1  97 100    00   W/B  +21.2   73.0 +18.8  -1.7 400.00 3.8  11.24
 4990 +19.4 4.2  97 100    00   W/B  +23.2   73.1 +18.9  -2.2 400.00 3.8  11.12
 5058 +19.0 4.2  97 100    00   W/B  +24.1   75.6 +19.3  -2.3 400.00 3.8  11.23
 5224 +19.0 4.2  98 100    00   W/B  +24.8   78.2 +19.8  -1.5 400.00 3.9  11.18
 5341 +19.2 4.3  97 100    00   W/B  +24.3   79.9 +20.0  -2.0 400.00 3.9  11.20
 5437 +18.6 4.3  97 100    00   W/B  +24.7   84.9 +20.0  -1.8 400.00 3.9  11.24
 5602 +18.0 4.3  97  90    00   W/B  +25.0   85.4 +20.0  -1.5 400.00 4.0  11.14
 5659 +17.8 4.3  97  90    00   W/B  +25.2   87.6 +20.0  -1.5 400.00 3.9  11.08
 5797 +16.8 4.4  97  90    00   W/B  +24.8   89.9 +20.1  -1.4 400.00 4.0  11.12
 5878 +17.8 4.4  97 100    00   W/B  +25.2   89.8 +20.0  -1.3 400.00 4.0  11.06
 5963 +18.4 4.4  97 100    00   W/B  +25.3   91.3 +20.0  -1.2 400.00 4.0  10.93
 6207 +18.4 4.4  97 100    00   W/B  +25.8   88.6 +20.0  -1.4 400.00 4.0  10.86
 6230 +18.2 4.4  97  90    00   W/B  +26.2   89.1 +20.6  -1.6 400.00 4.0  10.89
 6265 +17.6 4.4  98  90    00   W/B  +29.1   91.1 +20.5  -1.6 400.00 4.0  10.93
 6361 +17.8 4.4  97 100    00   W/B  +28.7   95.6 +20.0  -1.5 400.00 4.0  10.93
 6472 +17.4 4.4  97 100    00   W/B  +29.4   92.1 +20.0  -1.5 400.00 4.0  10.86
 6497 +17.4 4.4  97  90    00   W/B  +29.3   93.3 +21.0  -1.6 400.00 4.0  10.81
 6626 +17.0 4.4  97  90    00   W/B  +30.7   96.0 +20.8  -1.6 400.00 4.0  10.80
MidRex is offline   Reply With Quote
Old 04-12-2006, 10:00 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
everything looks good to me
Old 04-12-2006, 10:04 AM   #3
MidRex
Member#: 32841
2007 STI (Sold)
I was just wondering because I had a knock event in 4th one day, but I wasn't logging at the time. It was a little cold though.
I haven't had a chance to get to do a 4th gear pull since then...Not enough road and too much traffic.
Old 04-12-2006, 01:38 PM   #4
TurbojonLS
Member#: 38772
2 Cars, No Bling
Not knock related, but your MLP jumps between 90 & 100 a lot. Are you running the same boost values in both columns? If not, I'd either adjust your TPS values or change the boost map.
TurbojonLS is offline   Reply With Quote
Old 04-12-2006, 02:03 PM   #5
MidRex
Member#: 32841
2007 STI (Sold)
Boost values are the same in both columns (400). Isn't my TPS ok because it is showing 97 and switching between 90 and 100. The only thing that is fluctuating a little is boost. I remember that my max value for mapping is 23.4. I think it is like this due to my race gas tune from TXS. Should I change something to get that to read 100?
Old 04-12-2006, 02:13 PM   #6
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Looks good to me. You ever think of increasing your boost? what turbo are you running, vf34?
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 04-12-2006, 02:20 PM   #7
MidRex
Member#: 32841
2007 STI (Sold)
Yep VF34 it is. I actually did turn the ABC up 1/2 turn. Should I go more?
Also do you have any input on post #5?
Old 04-12-2006, 03:30 PM   #8
wrex03
Member#: 29963
04 sti
log looks fine, but I would recalibrate your tps.
wrex03 is offline   Reply With Quote
Old 04-12-2006, 04:10 PM   #9
MidRex
Member#: 32841
2007 STI (Sold)
Did you read post #5? Could I just be right on the edge between 90 and 100 with my max value for mapping which is 23.4?
Old 04-13-2006, 02:24 PM   #10
JDM 3SGTE
Member#: 35479
your timing looks low on the 3rd gear pull
JDM 3SGTE is offline   Reply With Quote
Old 04-13-2006, 02:48 PM   #11
Division By Zero
Member#: 7555
Which logging program are you using? Just curious as it looks a little different than the MPS one.
Division By Zero is offline   Reply With Quote
Old 04-13-2006, 02:58 PM   #12
MidRex
Member#: 32841
2007 STI (Sold)
UTEC Logger #1
Old 04-13-2006, 03:04 PM   #13
MidRex
Member#: 32841
2007 STI (Sold)
Should I bump it up a degree from 4500 till redline in the 90 and 100?
Open to suggestions?
Old 04-13-2006, 03:51 PM   #14
Division By Zero
Member#: 7555
Originally Posted by MidRex
UTEC Logger #1
Oh you must have the TXS Tuner box then?
Old 04-14-2006, 11:05 AM   #15
MidRex
Member#: 32841
2007 STI (Sold)
Yep...UTEC and Tuner
Old 04-14-2006, 10:38 PM   #16
fantabulous
Member#: 57364
99 m coupe
01 z3 coupe
man, i wish i could understand what all those numbers mean. im still having trouble tring to get my computer to datalog my utec. no luck. im hopeless.
<-failure
fantabulous is offline   Reply With Quote
please check my logs! mystilexzero Open Source Reflashes 22 11-18-2011 12:39 PM
Please Check My Data Log (New logs added) Xsile STI Engine Management & Tuning 6 04-30-2010 04:17 PM
Somebody please check this log...... XPT STAGE 2 RACE MAP eMoneyyy Engine Management & Tuning 2 07-06-2009 01:17 PM
07 STi w/ tuned Enginuity... fuel learning / running rich? please check my logs... TROLL Commercial ECU Reflashes 26 11-21-2007 01:51 AM
Please Check My Logs clemsonteg UTEC 4 08-28-2007 06:30 PM
