Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 04-14-2006, 11:18 PM   #1
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Default 2007 Legacy GT Spec B
2007 Subaru Legacy 2.5 GT spec.B Debuts new SI-Drive Performance System and 6-Speed Transmission
New SI-Drive Enables Driver to Select Engine Performance Level - VDC Stability System Supports Symmetrical All-Wheel Drive - New Audio System Offers Satellite Radio Capability
NEW YORK, April 13, 2006– Subaru of America, Inc., America’s All-Wheel Drive leader, today unveiled the 2007 Legacy 2.5 GT spec.B performance sedan at the New York International Auto Show. The introduction spotlights Subaru Intelligent Drive (SI-Drive), a key new technology that enhances driving engagement by allowing the driver to select the level of engine performance.
First offered for 2006 in a limited edition production run of 500 units, the Legacy 2.5 GT spec.B returns as a regular production model for 2007, featuring a host of performance and interior enhancements. In addition to the new SI-Drive system, the 2007 spec.B also gains a modified version of the 6-speed manual transmission from the Impreza® WRX® STI®, plus the advanced Vehicle Dynamics Control (VDC) system and a Tire Pressure Monitoring System. The 6-speed transmission is tailored to suit the spec.B’s refined driving characteristics and features unique gear ratios and a smoother shifting operation than the version used in the WRX STI.
Like all Subaru models, the 2007 Legacy 2.5 GT spec.B features Symmetrical All-Wheel Drive as standard equipment. The 2.5-liter intercooled turbo Boxer engine in the spec.B produces 243 horsepower @ 6,000 rpm and 241 lb.-ft. of peak torque @ 3,600 rpm. Subaru Active Valve Control System (AVCS) variable valve timing optimizes power at all engine speeds. The new Subaru SI-Drive system will also be standard on all Legacy 2.5 GT Limited and Outback® 2.5 XT Limited models for 2007 (all are powered by the same engine).
In its 2006 form, the Legacy 2.5 GT spec.B has already shown its taillights to a number of premium brand sport sedans. The 2007 model carries forward the Bilstein® Sport Suspension with inverted front struts, 18-inch aluminum-alloy wheels and high-performance tires.
Once again, the Legacy 2.5 GT spec.B features an exclusive interior design, for 2007 featuring Charcoal Gray leather-trimmed upholstery with Dusk Blue Alcantara® inserts.
A new standard SRS® WOW audio system brings a new sonic performance and quality to the Legacy line, plus MP3 and Windows® Media Audio (WMA) playback and an input jack for iPods and other portable audio devices. All Legacy and Outback audio systems for 2007 offer XM Satellite Radio capability.
SI-Drive: Three Engines in One
The new SI-Drive system allows the driver to maximize engine performance, control and efficiency by choosing from among three selectable modes – “Intelligent”, “Sport” and “Sport Sharp”– using a rotary dial on the center console.
The SI-Drive controls the electronic throttle system’s response and fuel and ignition curves to modify engine torque characteristics, changing the performance character of the car in each mode. With "Intelligent" mode selected, the system reduces engine torque and maximum power and switches to a more relaxed throttle response curve. Intelligent mode is an ideal choice for smoother response while commuting in traffic, for example, where it can also help boost fuel efficiency by up to 10 percent. In addition, "Intelligent" mode’s more relaxed responses and lower torque output make it an ideal complement to the low-traction surface driving safety provided by the Subaru Symmetrical All-Wheel Drive System.
In “Sport” mode, the performance of the 2.5 GT spec.B (and other 2007 turbo Legacy and Outback models) is similar to the 2006 model, with quick throttle responses and powerful, linear acceleration. The linear acceleration characteristic of this versatile mode makes it ideal for driving on freeways and suburban streets or for climbing mountain roads.
In “Sport Sharp” mode, SI-Drive modifies the engine’s electronic throttle mapping to deliver lightning quick throttle response and more power sooner. Delivering maximum driving enjoyment, this mode is ideal for tackling twisty roads and for merging or overtaking other vehicles on the highway with confidence.
On 2007 Legacy and Outback models equipped with the 5-speed automatic transmission (not available on Legacy 2.5 GT spec.cool.gif, SI-Drive also changes the transmission’s shift patterns. It will hold each gear longer through the rpm range and downshift more quickly under hard acceleration, depending on the mode selected.
The SI-Drive system includes instrument panel displays that allow the driver to monitor performance. The multi-information display located in the tachometer face – in addition to providing trip computer functions – denotes the selected SI-Drive mode and provides an active torque curve display.
When “Intelligent” mode is selected in vehicles with a manual transmission, a shift-up indicator blinks to signal the optimal shift point for maximum fuel efficiency.
Symmetrical All-Wheel Drive + Vehicle Dynamics Control
The 2007 Legacy 2.5 GT spec.B is equipped with one of the industry’s most effective combinations of all-weather handling technologies: Subaru Symmetrical All-Wheel Drive plus Vehicle Dynamics Control (VDC), a stability system that was previously available only on the B9 Tribeca SUV model and the top-line Outback.
Teamed with a manual transmission as in the Legacy 2.5 GT spec.B, Subaru Symmetrical All-Wheel Drive employs a viscous-coupling locking center differential with a normal 50:50 torque split. Slippage at the front or rear wheels will transfer more power to the opposite set. Vehicle Dynamics Control (VDC) is an advanced stability system that can help keep the vehicle going in the direction the driver is steering, especially in slippery road conditions. The system can be deactivated for conditions that require some wheel slippage, such as extricating the car from deep snow. New for 2007, a Torsen® limited-slip rear differential helps to optimize traction at the rear wheels.
Exclusive Bilstein Sport Suspension
The exclusive Bilstein Sport Suspension equips the Legacy 2.5 GT spec.B model with performance-tuned shock absorbers for improved cornering response. Subaru replaced the MacPherson strut front suspension of other Legacy models with an inverted strut configuration similar to that in the rally-bred Impreza WRX STI, including aluminum-alloy lower control arms.
The multi-link rear suspension features aluminum-alloy rear arms and upper links in place of cast-iron pieces to reduce unsprung weight (and thereby enhance handling response). Finally, the 18-inch alloy wheels are fitted with 215/45 R18 Bridgestone Potenza RE050A summer performance tires. (The standard Legacy 2.5 GT Limited models feature 17-inch alloy wheels and all-season tires.)
A 4-wheel disc Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) is standard on all Legacy models. The 2.5 GT Limited and 2.5 GT spec.B models employ larger brake rotors than other Legacy models, with ventilated rear discs in place of solid discs.
Distinct, Sophisticated Design – Outside and In
The Legacy 2.5 GT spec.B not only appeals to driving enthusiasts for its performance, but for its appearance that is both distinctive and “stealthy.” The Legacy 2.5 GT spec.B is quickly identified by its aerodynamic side ground-effects moldings with chrome trim. The road-hugging stance of the spec.B is further accentuated by the exclusive 18-inch wheels.
The Legacy 2.5 GT spec.B continues with its own exclusive interior, with the 2007 model featuring new Charcoal Gray leather-trimmed upholstery with Dusk Blue Alcantara inserts in place of the 2006 model’s Brick Red leather-trimmed upholstery.
The standard 8-way power driver’s seat gains a memory function for 2007, and the interior is further differentiated from the Legacy 2.5 GT Limited model by aluminum-alloy pedal covers, a 3-spoke MOMO® leather-wrapped steering wheel with integrated audio controls and “spec.B” floor mats. The Subaru Navigation System remains standard on the spec.B model and available for all automatic transmission-equipped Legacy 2.5 GT Limited models.
Standard features shared with the 2.5 GT Limited Sedan include dual-zone automatic climate control, performance-design front seats, power moonroof, 4-stage heated front seats, a 4-way power passenger seat and heated exterior mirrors. In addition, all Legacy sedan models for 2007 gain a new standard 60/40 split fold-down rear seat with trunk pass-through to enhance cargo-carrying versatility.
All Legacy models for 2007 feature, as standard equipment, the Subaru Advanced Frontal Air Bag System, front seat side impact air bags, active front seat head restraints and side curtain air bags.
Wiscon_Mark is offline   Reply With Quote
Old 04-14-2006, 11:20 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
And before you guys panic about the "power drop" remember that the new SAE rating system is in place, it's the same, it's just measured a little differently.
Old 04-14-2006, 11:29 PM   #3
tekkitan
Member#: 111884
2000 Legacy GT Ltd
White Birch
subaru.com has info as well as pics too
if i want to get a new car in the next couple of years, not sure if i'd try for the SpecB or the STI Limited
tekkitan is offline   Reply With Quote
Old 04-15-2006, 03:34 AM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I'll take 10 please.
fibuz is offline   Reply With Quote
Old 04-15-2006, 04:10 PM   #5
GrassyKnoll
Member#: 111702
2004 WRX STI
Very nice looking. Just checked it out yesterday at the NYC Auto Show
GrassyKnoll is offline   Reply With Quote
Old 04-15-2006, 06:14 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Bah! Chevy's numbers went UP with the new system - that's why the Z06 is 505hp instead of 500hp.
Getting the 6-speed is certainly nice, but I don't think VDC belongs on a sporting car (unless it's changed significantly in the past few years). A couple years ago I went to a Team O'neill winter driving school with a group of NESIC guys, and one of the other students brought a VDC Outback. Even the rally drivers couldn't get the thing to "play", the VDC just killed any fun you could possibly have.
And the SI Drive sounds ghey to me.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-15-2006, 07:34 PM   #7
Gator GT
Member#: 37190
07 specB - 6spds,
4 tips, 3 LSDs, stg 2!!!
Pat Olsen
Some hp numbers went up, other manufacturers went down. Depends on what manufacturers did before the new standard.
And I'm soooo in agreement with you on the SI Drive. Smoke and mirrors.
Great, some nice gestures for upgrades....but not exactly the high performance Legacy I'm waiting for.
Meh, I was excited to go down the NYC show next Sat to see what SOA is unveiling....now I'm none too excited.
SOA is getting another letter from me after the show. I'm in agreement with some other select postings from various Legacy forums:
- strengthen the 5MT thats in there now, or improve and put in the 6MT (steel vs. AL shift forks; and REVISE those gear ratios after 3rd!)
- Brembos (I say make them non-flashy; like the Grand Cherokee SRT8: black!)
- R180 rear
and my own adds (didn't see them anywhere else)
- add LSD to the front
- sleeper exterior (if I want police and thieves attention, I'll buy a WRX STI)
- HIDs (similar to differentiating between a WRX and a WRX STI)
I mean, com'on FHI, it can't be THAT expensive to do....for crying out loud...you already have the drivetrain in the GD!
(I still think its a stupid move to get rid of the MT in FI wagons....but I'm choosing my battles)
-matt
Gator GT is offline   Reply With Quote
Old 04-15-2006, 07:37 PM   #8
whoosh
Member#: 40989
OT vag inspector
saw it today...ehhh
whoosh is offline   Reply With Quote
Old 04-15-2006, 07:58 PM   #9
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
+1
Too gimmicky, and probably makes it that much harder for companies like Cobb/EcuTek to put out a reflash... I'd rather have HIDs standard than this.
-Mike-
CreoWRX is offline   Reply With Quote
Old 04-15-2006, 08:23 PM   #10
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I don't mind the idea of an economy mode considering these cars aren't exactly sparing on fuel.
Old 04-15-2006, 09:57 PM   #11
MitchGT
Member#: 73684
2012 4Runner
I think GGT hit it on the head which is why my next car will be a WRX or STI, not an LGT. I think if Subaru wants to make a "performance" oriented LGT, they shouldn't half-ass it.
MitchGT is offline   Reply With Quote
Old 04-15-2006, 11:13 PM   #12
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yeah, I know, I was just being grumpy.
2007 Legacy GT Spec b kcirtap1984 Private Vehicle 'For Sale' Classifieds 0 03-13-2008 10:50 PM
2007 Legacy GT spec-B brake pads??? txl146 Brakes, Steering & Suspension 2 08-24-2007 09:30 PM
2007 Legacy GT spec.B Specifications Released cefoskey News & Rumors 511 12-04-2006 11:55 AM
Canadian Driver 2007 Legacy GT Spec B review bakadayo News & Rumors 2 09-15-2006 01:17 PM
2007 Legacy GT spec.B and Impreza WRX STi Limited Bone_stock77 North West Impreza Club Forum -- NWIC 15 07-11-2006 11:56 AM
