Old 04-11-2006, 09:16 PM   #1
SammyRex
Member#: 104012
2006 WRX Wagon
Default Whats your front endlinks on your wagon?
what company makes the good front endlinks for the wagon?
Please you post the info as
1.make (part number if possibe):
2.year of your wagon:
3.Do you like they way it performs:
Thanks.
SammyRex is offline   Reply With Quote
Old 04-11-2006, 09:49 PM   #2
snowscientist
Member#: 49039
04 WRX wagon
Whiteline alloy endlinks. Designed for the wagon. 2004 wrx wagon. They fit and work perfectly. A nice upgrade, especially with a larger front swaybar.
snowscientist is offline   Reply With Quote
Old 04-12-2006, 02:26 AM   #3
dreyna14
Member#: 84297
2005 WRX Wagon
CGM
I got the Noltecs front and rear. Beefy, good looking, and cheaper than anything out there.
dreyna14 is offline   Reply With Quote
Old 04-12-2006, 08:50 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I've installed Noltec, Poltec and Whitelines on wagons of various years. All work rather well. I would tend to lean towards the Whitelines or Notlecs though to avoid using a spherical bearing as they can sometimes be noisey.
Old 04-12-2006, 12:38 PM   #5
SammyRex
Member#: 104012
2006 WRX Wagon
Thanks for the suggestions. The whiteline F endlink I bought was KLC32 which
do not fit wagon, I need to return them and switch to KLC30 to fit my wagon.
Old 04-12-2006, 04:07 PM   #6
ralliharri
Member#: 85035
2011 WRX 5-door
KTM 690 Duke
I have the poltecs on my '05 wagon and was surprised how much they helped, not a big difference but definately noticeable, have yet to install a front swaybar though.
ralliharri is offline   Reply With Quote
Old 04-12-2006, 04:41 PM   #7
Migo
Member#: 81352
2003 '03 EJ257 wagon
Green
+1 on the whitelines... 2003 Impreza wagon
Migo is offline   Reply With Quote
Old 04-12-2006, 04:48 PM   #8
seth_man
Member#: 73008
also whiteline solid links on '04 wagon
seth_man is offline   Reply With Quote
Old 04-20-2006, 08:47 PM   #9
johnnyb
Member#: 57593
2015 Crosstrek XV
Whiteline KLC30 Front Endlinks
2002 Wagon
Very happy with them.
johnnyb is offline   Reply With Quote
Old 04-20-2006, 08:53 PM   #10
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Whiteline!
Arnie is offline   Reply With Quote
Old 04-20-2006, 11:54 PM   #11
ripvw
Member#: 27790
2002 Wagon
me too...
ripvw is offline   Reply With Quote
Old 04-21-2006, 01:22 AM   #12
subenerd
Member#: 72630
2004 STi
I have the Whiteline 'noodle' steel endlinks (the non-HD ones). They very much made the cars steering feel more on point and responsive. The heavy duty ones must feel very on point! I choose the steel ones to retain the 'give' feeling, I like having some play with the suspension. I like them, not to mention the value They can break though...
subenerd is offline   Reply With Quote
Old 04-21-2006, 01:26 AM   #13
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
2002 Wagon
Me too.
Wade-O is offline   Reply With Quote
Old 04-21-2006, 08:31 AM   #14
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Actually, Whiteline says that there is no stiffness difference between the two, though the aluminum version is more durable. The few steel one's that broke were the result of some bad steel they received. You can tell by the fact that the ends are welded shut. Any ones that broke were always replace free of charge or given a big discount if one wanted to go with the alu versions. I had no problems with my steel ones for the years that I had them.
Old 04-21-2006, 12:35 PM   #15
aclaz
Member#: 56452
2002 WRX Wagon
1. Poltecs (steel version, originally ordered the aluminum ones, but heard that they can break with larger FSB).
2. 2002 WRX Wagon
3. The turn-in feels slightly better, but did not notice a significant improvement. Expect to install a larger FSB (Hotchkis or Whiteline) in the near future.
aclaz is offline   Reply With Quote
Old 04-21-2006, 10:59 PM   #16
subenerd
Member#: 72630
2004 STi
Ahhhh, interesting. Makes me glad I didnt spend the extra money on the HD ones *knocks on wood, hoping they dont break*
Arnie, is there anything you DONT know about suspension
Thanks
Old 04-22-2006, 01:45 AM   #17
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
There is tons I don't know about suspension! You can fit everything I know on a page of wide lined loose leaf! I'm still learnin' man! Thanks for the vote of confidence though.
Important thing with the Whiteline poly endlinks is to make sure you follow the install directions. Its critical that you place the proper size washer in the proper place otherwise the bolt head will go through the bushing. Seen this happen a few times and I always think, how hard is it to read directions?
Old 04-22-2006, 12:16 PM   #18
BSLICKOH
Member#: 9712
2012 LifeSpan
TR1200-DT
I've had Poltec aluminum and Poltec steel on an 04 WRX wagon. Broke one of the aluminum ones, then went to the steel ones.
Currently have Whiteline HD's on my 9-2X.
BSLICKOH is offline   Reply With Quote
Old 04-25-2006, 02:42 PM   #19
Wade-O
Member#: 31190
2002 WRX Sportwagon
Alpine White
I switched and couldn't feel a difference. However, the steel ones just look retarded, which was a major factor in my decision
Old 04-25-2006, 03:02 PM   #20
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
I think Kartboy is making some also. so stay tuned
i know i am
Shane
PARANOID56 is offline   Reply With Quote
Old 04-25-2006, 04:25 PM   #21
sixtoo
Member#: 67603
2007 WRX Wagon
Urban Gray Metallic
I have nothing but good things to say about the Helix spherical endlinks mated to a set of 21mm Cusco swaybars. I can't remember hearing any types of obtrusive noise from them either.... But then again, one can rarely hear anything with the droning of a Blitz exhaust. Seriously though, Helix is another brand that you might want to consider.
sixtoo is offline   Reply With Quote
Spacers for Kartboy Front Endlink on Wagons? mr_yellow Brakes, Steering & Suspension 15 10-28-2008 11:20 AM
Post your front lip on your bugeye wrx 03SuBbYWrX Member's Car Gallery 24 12-03-2007 11:28 AM
Post your front lip on your bugeye wrx 03SuBbYWrX Interior & Exterior Modification 4 12-02-2007 11:03 PM
2006 Sedan Front Endlinks on 2004 Wagon jjbehren Brakes, Steering & Suspension 5 04-04-2007 10:29 PM
3+ degrees front camber on a wagon. What are you using? mav1c Brakes, Steering & Suspension 36 01-28-2006 11:25 AM
