Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-11-2006, 10:07 PM   #1
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
Default no 'map 2' but all others report?
I may have a bad map selector switch.
I put it on position 1, and it reports 'switch 1, map 1'
I put it on position 2, and it reports 'switch 3, map 3'
I put it on position 3, and it reports 'switch 3, map 3'
all others work as they should.
It a push button encoder, so i dont understand how it could be messed up, cuz to report 3, it would be 011.
Ideas? Bad encoder is my guess.
Jason
ZR2_S10 is offline   Reply With Quote
Old 04-18-2006, 10:57 PM   #2
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
anyone?
Old 04-18-2006, 11:54 PM   #3
Gethin
Member#: 2998
Disconnect the remote switch and check to see if rotary switch on the UTEC itself reports its positions correctly. If it does then your remote switch is borked or the UTEC's electronics is damaged. As you said it's a BCD so my guess would be the UTEC itself so not much can go wrong with the BCD switch apart from bad cabling.
Gethin is offline   Reply With Quote
Old 04-19-2006, 12:35 AM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
If the LSB is stuck it would do that. What about 4? I imagine it would think its 5....
cdvma is offline   Reply With Quote
Old 04-19-2006, 10:09 PM   #5
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
Ok, just checked it again, and this is what i get
switch reported
position position
0 0
1 1
2 3
3 3
4 4
5 5
6 6
7 0
8 0
9 1
I'm not sure whats going on now.
I did notice when I was doing this test, that my CEL didnt flash 3 times (on map 3) when I started the car.
Jason
Old 04-19-2006, 10:58 PM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
It's the rotary switch on the back of the UTEC, it is not on "0", i'm pretty sure of that. However I hae seen one TXS remote map switch which was bad. Disconnect it and use the rotary switch on the back of the UTEC to change maps. If it works correctly then its the remote switch
mick_the_ginge is offline   Reply With Quote
Old 04-20-2006, 02:16 PM   #7
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
Well, this morning, i disconnected the remote switch, and tried the one on the utec.
Worked flawless.
Hooked the switch back up, utec on 0, 1,3,4,5, blah
popped the switch out, while it was on map 2, and viola, it showed map 2.
stuck it back in, and it went back to map 3.
HRMMmmmm
Wiggled the wires a lil, from the fuse area, and it started working. I think the LSB wire might be touching something inside the heatshrink.
One weird thing though, my CEL didnt flash 3 times when I started the car. I want it to, but it doesnt. I even stopped 1/2 way to work, let it sit, shut off, for like 2 minutes, and restarted it, no flash.
Thanks guys!
Jason
Old 04-20-2006, 06:36 PM   #8
i_doni
Member#: 42849
2004 WRX
Java Black Stage 4
I have the same problem as yours. Mine work fine though if you switch from map 3 to 2. But if I go from 1 to 2, the UTEC will just jump to map 3. So mine is going like this:
1->3->3->4->5
or
5->4->3->2->1
About the flash cel, if you have firmware 5.0, it will not flash the cel.
i_doni is offline   Reply With Quote
Old 04-20-2006, 11:11 PM   #9
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
i'm gonna pull the heat shrink off, and see if i can isolate the wires, so they dont touch, or check for a cold solder.
I didnt know that about the flashing cel, with 5.0, good to know.
Thanks,
Jason
All JDM LFA's are sold, 90% of all others too. mhoward1 Non-Subaru News & Rumors 37 01-18-2010 08:13 AM
Why do Cobb intakes need no tune but all others do? Special Blend Newbies & FAQs 29 07-29-2009 03:16 PM
No 2nd but All other Gears are A-OK??? Sunrise City Rider Transmission (AT/MT) & Driveline 1 05-23-2006 12:22 AM
Borla cat-back 2.5L or 2.2L (possibly all others but wrx) mysubaruimp Private 'For Sale' Classifieds 4 09-23-2004 09:10 PM
