Old 04-12-2006, 06:19 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default Tech Works Shim Under Bucket Question-Where to get replacement shims?
I am considering buying a used Tech Works Shim Under Bucket setup but am wondering where to get replacement shims?
I have emailed them twice now with no reply.
If they use the stock subaru shims Ive heard they run around $70 a pop. Hopefully they make them in house and are a little cheaper.
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 04-12-2006, 07:14 PM   #2
02Toyowrx
Member#: 56520
OEM shimless bukets are $25 each and are alot better than any shimmed bucket.
02Toyowrx is offline   Reply With Quote
Old 04-12-2006, 08:12 PM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Not if you already have baught and paid for heads that have shim under bucket conversion.
Old 04-12-2006, 08:38 PM   #4
imp2.5
Member#: 11354
You really have to call them...
http://www.techworkseng.com/Common/C..._TechWorks.htm
I've e-mailed them a billion times and they typically take a month to respond.
imp2.5 is offline   Reply With Quote
Old 04-13-2006, 03:10 PM   #5
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
yea, call em.
Sko is offline   Reply With Quote
Old 04-13-2006, 03:53 PM   #6
rexnprogress
Member#: 70768
2002 wrx (RIP)
2001 Forester S
shim under bucket is a one piece design(if i remember correctly). i once dumped a set of heads over and had to re-gap them. the buckets had the thickness printed on the underside.
when you order OEM, you give them the thickness your want and you get a whole new bucket.
rexnprogress is offline   Reply With Quote
Old 04-13-2006, 11:55 PM   #7
subieyacht
Member#: 84087
98 Legacy GT
so do they just say you need that kit with the stage three cams just for liabilaty purposes? because i would like to increase my redline, but i dont want to shell out the money for that damn kit.
subieyacht is offline   Reply With Quote
Old 04-14-2006, 12:09 AM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Usually they respond to customers very quickly...but that might just be because of how much business I've done with them... <not trying to show off>
Call them, they're really nice guys! Once you call you'll want to talk a lot, just remember its Canada eh?
Old 04-14-2006, 01:14 AM   #9
imp2.5
Member#: 11354
For sure, I just got off the phone with them today. I don't care if other places might be cheaper, they know what they're talking about and are really cool guys.
+1 for TWE
Old 04-14-2006, 08:20 AM   #10
rexnprogress
Member#: 70768
2002 wrx (RIP)
2001 Forester S
liability for your engine. top mounted shims have been known to break or spit out of the recessed area on top of the bucket in high hp applications. one piece = less breakage.
also their valve springs are most likely stiffer than stock to help valve float at high rpm. weak springs will prevent the valves from closing all the way.
its in your best interests to put in a new valvetrain with anything more than a stage 1 cam setup.
Old 04-18-2006, 07:28 PM   #11
02Toyowrx
Member#: 56520
Shimless would be Ideal, but subaru stocks the shims that go under the buckets now. They are used for the 3.0L Tribeca EZ30R
Old 04-18-2006, 08:16 PM   #12
rexnprogress
Member#: 70768
2002 wrx (RIP)
2001 Forester S
but why not just call titus subaru (subaruparts.com) and get shimless buckets from an STi?
Old 04-18-2006, 08:32 PM   #13
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I just got a response from Josh at TWE who said they are OEM Subaru Shims.
I wrote him back to ask if they are Phase I EJ25 DOHC type shims that are normally over bucket or are they OEM under bucket shims like what is used in the 3.0?
I guess the main question is if this kit is totally OEM just usable in various motors or has TWE adapted a bucket that accepts the OEM shims underneath.
I'll post once I receive an answer. There is a fairly significant cost difference between the OEM under bucket shims/solid buckets, and the OEM shims for over bucket design.
Old 04-18-2006, 08:35 PM   #14
02Toyowrx
Member#: 56520
So the terminology is correct when you are inquiring for parts. The correct term are Lash Caps.
Old 04-19-2006, 02:33 PM   #15
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Just talked with a Subaru Master Tech and found that the only the intake valves of the Tribeca are Shim Under Bucket. The Exhausts are Solid Buckets.
TWE's setup has to be an adapted bucket to use OEM over bucket shims or "Lash Caps".
Where to get replacement 2004 STI Headlight Ballast plug/'cable with plugs' prototypeWRX Electrical & Lighting 11 09-09-2011 04:14 PM
Where to get replacement HID bulbs wyn525i Off-Topic 5 02-21-2007 08:28 AM
Where to get replacement center cap for Prodrive P1? Orson Tire & Wheel 10 10-12-2006 02:15 PM
Where to get replacement factory fender and Bumper? Javier Interior & Exterior Modification 7 05-19-2005 01:07 AM
where to get replacement belt for UR pulley? jacktam1 Vancouver Impreza Club Forum -- VIC 3 07-25-2001 10:29 PM
