Old 04-28-2001, 05:28 PM   #1
jwooman
Member#: 468
Post Will the twin turbo EJ20 fit 91-94 Legacy turbo?
I want to know what parts I need to do the swap? For example, I got the EJ20 twin turbo engine and tranny only(no wiring harness and ECU). Will it direct fit to 91-94's? Need different axles like Impreza RS?
For $900-1100 without ECU and wiring harness, is it a good deal?
Thanks!
jwooman is offline   Reply With Quote
Old 04-28-2001, 06:46 PM   #2
Benjamin Tang
Member#: 4496
2009 Forester
red
Post
i vaguely recall mention that the twin turbo plumbing was designed for a RHD car, ie. there might be clearance problems around the steering shaft of a LHD car?
ben
Benjamin Tang is offline   Reply With Quote
Old 04-29-2001, 09:23 AM   #3
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
Without a LOT of modification, it won't.
The single is simpler and can make more HP anyway.
DLC is offline   Reply With Quote
Old 05-01-2001, 12:46 AM   #4
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Post
It sounds good but it it may cost you a lot of time. Where did you get a hold of that Engine?
ejicon is offline   Reply With Quote
Old 05-01-2001, 02:29 AM   #5
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Post
If you are looking for more hp, going with an STi single turbo engine with fewer kms/miles on it will likely be easier!
Just make sure that the connections and harness etc match so you don't have the pain and expense of major work.
anotherB4 is offline   Reply With Quote
Old 05-02-2001, 12:26 AM   #6
PaulN
Member#: 566
1994 Legacy GTB
Green
Post
Hi
The Twin turbo will not fit a LHD car as the primary turbo is in the way of the steering column
I would think that the engine is of no real use without the ECU and harness as the plumbing and electronics are horrendously complicated - see my web page on the turbo plumbing - www.nebbs.com and click on twin turbo on the front page
Paul
PaulN is offline   Reply With Quote
91-94 Legacy turbo... what clutchs fit? Cstmboxermotorsports Pre-2002 Factory Turbo Powertrain 7 11-20-2007 11:49 AM
About the stock 91-94 legacy turbo Natoe Legacy Forum 7 07-29-2005 01:46 AM
Brake Pads for the 91-94 Legacy Turbo Rear Calipers? mav1c Brakes, Steering & Suspension 10 02-13-2004 11:40 AM
Need info on 91-94 Legacy Turbo DJTano Legacy Forum 9 11-16-2001 03:18 PM
Rethinking 2.5GT idea for a 91-94 Legacy Turbo... Eriksport Legacy Forum 6 05-06-2001 10:12 PM
