Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 04-12-2006, 08:32 PM   #1
jnorth85
Member#: 76785
2000 RSTi Coupe
SRP
Default Side air bag removal
hey guys,
i just got a set of front seats out of a 05 wrx to put in my 2000 RS
now i want to save as much weight as possible so id like to remove the side air bags, does anyone know the process involved in this, can anyone point me to a write up ?
thanks!
jnorth85 is offline   Reply With Quote
Old 04-12-2006, 10:44 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I'd like to know as well.
speedyHAM is offline   Reply With Quote
Old 04-12-2006, 11:32 PM   #3
fourstrokephysics
Member#: 92132
1997 OBS GFA
I removed the air bags in a set of 03 wrx seats for my 97 OBS. First you have to unzip the two zippers on the back of the seat, and unsnap the bottom fold of plastic that holds the fabric down. Then you can pull the outside side bun upholstery up to the shoulder area and theres some foam to rip off and its a black box bolted on with 2 10mm's i believe. It's very easy, and takes about 30 minutes. The snap on the bottom is a long strip of plastic that you fold in over the frame. Each assembly weighed a couple pounds. very much worth it. If you have any foam you could stuff it where the box was, if not, it will just be slightly flimsy in the area and you can push it in, but its unnoticeable either way.
fourstrokephysics is offline   Reply With Quote
More Hot Topics on NASIOC...
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 10:10 PM.
