#1 |
Vendor Sales Rating: (65)
Member#: 23216
Vehicle:2006 949-457-1234 949-457-1234 |
Hey guys,
We're cleaning out our warehouse so we've got some cool stuff for some really good prices. All of this stuff is in stock and ready to ship. Wilwood 6-piston Front (Drilled Rotors) - 02+ WRX $1345 Shipped *6-piston billet aluminum calipers *12.9" 2-piece rotors (cross-drilled rotors) *High performance brake pads *All mounting hardware included *Requires 17"+ wheels *Brake lines are NOT included (add $150 for SS lines) Tein Flex Coilovers - 02+ WRX / 04 STi ONLY $1529 Shipped $1859 Shipped w/ EDFC *Independently height adjustable *16 way dampening adjutable *EDFC compatible *Pillowball mounts all 4 corners (camber adjustable in the front) *8 KG F / 7 KG R spring rates Cusco Zero1 - 02+ WRX / 04 STi ONLY $1699 Shipped *Independently height adjustable *Pillowball mounts all 4 corners (camber adjustable in the front) *7 KG F / 5 KG R spring rates STi Replica Strut Tower Bars - 02+ WRX / 04+ STi $75 Shipped for Front $60 Shipped for Rear $125 Shipped for Both Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. These STi Replica Strutbars improve chassis rigidity and reduce this flex. By using a monocoque aluminum tube shaft, high strength and rigidity are obtained without unnecessary weight gain. Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: sales@gruppe-s.com When ordering w/ paypal, please include the following: product name: XXXX Price including shipping: $XXXX Shipping address.
#2 |
Member#: 23216
We're excitied to announce that we just got some of the first sets of Performance Friction 2-piece replacement rotors in for the STi. Performance Friction is well established in the racing scene and these rotors look the part. They're also very affordable. Best of all, the hats are drilled for 5X100 and 5X114.3 so the 05 STi guys can finally have some fun.
Peformance Friction 2-Piece Replacment rotors for 04+ STi - Special introductory price of $699 Shipped!!! -5X100 and 5X114.3 fitment! -2-piece design allows aluminum hat for lightweight rotors. -Full floating design allows expansion of rotor and hat at different rates to prevent pad coning. -Lightweight - 17.6 lbs per rotor (stock rotors are 22 lbs.). -Dimpled to increase surface area of rotor (promotes cooling), refresh pads, and less prone to cracking than cross drilled rotors. -Vaned to promote cooling. -Allows you to retain stock Brembo calipers And a special introductory package: Porterfield R4-S Pads F, Peformance Friction Rotors F, Goodridge SS lines F+R: $1069 shipped!!! Endless SSS Pads - 04+ STi, F/R These pads are an excellent choice for the agressive street driver. They are non-metalic so they are rotor friendly and dust is minimal. The SSS feature a high friction coefficient so they are suitable for short weekend track stints but are not applicable for heavy track use. $160 shipped for F or R, $300 shipped for F and R!!! ![]() Porterfield R4-S Brake Pads (carbon kevlar), 04+ STi, F/R These pads are a good balance between race pads and street pads. The Porterfield R4-S’ are unique because they’ll withstand 20 minutes of track time with no fade (they so not fade at temperatures up to 1,100 degrees F) but at the same time, they will work fine when cold and they’re very rotor friendly (as well as being very slow wearing). The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. The R4-S compound also has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brakes material. Good for autocrossing, drivers schools, weekend track sessions, solo events, and rallys. $199 shipped for F, $269 shipped for F and R!!! ![]() Brembo Sport Replacement Rotors (Drilled or Slotted) - F/R - 04 STi only ~Brembo Sport slotted brake rotors are for drivers who want to improve the looks and performance of their vehicle's original braking system without having to change additional brake components. ~Brembo Sport slotted and drilled brake rotors provide excellent stopping power in everyday traffic, as well as high performance street and track driving. ~Brembo Sport slotted brake rotors match the vehicle's original equipment rotor's dimensions and are fully compatible with its hubs, brake calipers and road wheels. $394 shipped for F, $375 shipped for R!!! ![]() OK, now for the packages: 04 STi Front: 1) Porterfield R4-S Pads F, Brembo rotors F, Goodridge SS lines F+R: $675 shipped!!! 2) Endless SSS Pads F, Brembo rotors F, Goodridge SS lines F+R: $655 shipped!!! 3) Porterfield R4-S Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1110 shipped!!! 4) Endless SSS Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1180 shipped!!! ----------------------------------------------- Special Brake Packages for the WRX: Gruppe-S finally carrys Motul Fluid! People have been asking for some cheap effective brake combos for their WRXs for quite some time now. This is the most cost effective way to improve your brakes. Porterfield R4S Pads + Goodridge SS Lines + Motul RBF600 Fluid *The Goodridge Stainless Steel Brake Lines will improve your pedal feel and stop unwanted line flex at high temp. *The Porterfield R4S Carbon Kevlar Brake Pads have a superior coefficient of friction compared to the stock pads and have excellent fade characteristics. They'll take 20 minutes of weekend track time for beginner to intermediate drivers with no ill effects *2 Pints of Motul RBF600 Brake Fluid are more than enough to flush your entire brake system. This is some of the best brake fluid out there (DOT4) and is track worthy stuff. ![]() All 4 Corners for 02 WRX - $299 Shipped All 4 Corners for 03+ WRX - $319 Shipped If there's a package that you'd like and it's not listed, please don't hesitate to ask for pricing. Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: sales@gruppe-s.com When ordering w/ paypal, please include the following: product name: XXXX Price including shipping: $XXXX Shipping address. |
#4 |
Member#: 23216
Porterfield doesn't have that application yet but I'll tell you what. If you can send us one of your pads (or an excellent template of it), I can have them start making those pads (we have a bit of pull with them). For your services, we'll give you a set of R4S pads for your car at our cost. Shoot me a PM if you're interested in that.
Thanks, Geoff |
#6 | |
Member#: 23216
Thanks, Geoff |
#7 |
Member Sales Rating: (15)
Member#: 3664
Vehicle:2005 broken forester |
The subaru 4 piston calipers is the same as the turbo nissan 300zx front pads - perhaps you can cross reference the info on the forum to make your life easier?
[Note: Found it: AP460 for the subaru 4 pots] Last edited by vsigma; 04-18-2006 at 02:26 AM. |
#9 |
Member Sales Rating: (3)
Member#: 3149
Vehicle:01 V7 GC/R32 sky |
Yes I believe thats true about the calipers being the same, i have heard that before.
Bump for a great vendor and some nice parts! I just recieved my Brembo slotted rotors (F/R) and goodridge ss lines, thanks guys !Dan |
| Thread Tools | |
| Display Modes | |
| Cleaning out the garage...flywheel, brake stuff, side skirt, pedals, door cards etc. | giveme5bux | TXIC Private Classifieds | 10 | 02-12-2009 04:08 PM |
| Cleaning out Basement: FS WRX small items | MarylandEcstasy | MAIC Private Classifieds | 2 | 11-19-2006 10:24 PM |
| Crazy!!! Clearance Sale Tein, Cusco, Perrin, Eibach, Espelir, Helix All in Stock!! | Spun Autosports | Suspension/Brakes/Handling | 59 | 04-20-2006 12:35 PM |
| cleaning out the shop come and get this stuff | ILP Performance.com | Tri-State Area Forum | 3 | 06-04-2003 09:46 AM |
