Old 04-13-2006, 04:52 PM   #1
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
Default Throttle body coolant bypass = blocking flow instead of rerouting?
I'm thinking of doing the TB coolant bypass mod, but instead of doing the usual method of connecting the two ends of the hose together directly, put a valve on one side of the throttle body that you can open and close as needed.
Since there is still coolant in contact with the TB this won't be quite as good as bypassing it completely but since the coolant should be pretty static it shouldn't warm it up as much as before. The bonus would be it'd be very easy to "turn off" the mod if needed without spilling a drop of coolant.
Has anyone tried this? I found this diagram in the STi service manual (is the 2.0 much different?):
It doesn't look like blocking coolant flow at the TB would cause any problems.
Any ideas?
athakur999 is offline   Reply With Quote
Old 04-13-2006, 06:06 PM   #2
KmanRuffian
Member#: 48360
2011 WRX 5-door
Why don't you use two valves and two T's or Y's so you can re-route it to a bypass line or through the throttle body? Best of both worlds?
-D
KmanRuffian is offline   Reply With Quote
Old 04-13-2006, 06:45 PM   #3
orndog
Member#: 34670
2013 No gears!
Saltine American
You're in Dallas, TX, why worry about needing to turn the flow back on? As outlined on my web page my car has made it through 0F without trouble. With a CAI.
http://www.utm.edu/staff/gonzalez/TBBypass.htm If you wanna see pics and such of it done on my OBS.
orndog is offline   Reply With Quote
Old 04-13-2006, 06:49 PM   #4
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
I hooked up my water temperature sensor between the two hoses. Works great.
Don Arm is offline   Reply With Quote
Old 04-13-2006, 08:12 PM   #5
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
-D
When I first started looking at this I thought about getting a Y valve. I know I've seen them for garden hoses but I didn't see one of this sized hose. But that got me thinking is there any reason to have coolant running through that line at all? There doesn't appear to be. Getting a splitter and then two valves for each split would do it but that's adding up on the parts cost.
As for living in Dallas, yes I don't have much reason to think about this But if I can spend $1.50 for the usual way or $2.50 for a maybe better way, I'd do the $2.50 way. Just I case I take the car somewhere cold or something
Old 04-13-2006, 08:14 PM   #6
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
Why would one do this mod.....
audio1der is offline   Reply With Quote
Old 04-13-2006, 08:27 PM   #7
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
Google for "throttle body coolant bypass". It's a pretty common mod for many cars. It can lower the temperature of the air going into the engine by a few degrees.
Old 04-13-2006, 08:33 PM   #8
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
ty sir hmmm
throttle body/coolant bypass stage2?? Interior & Exterior Modification 12 07-20-2009 03:05 PM
Throltle Body Coolant Bypass revenance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 07-26-2008 08:24 PM
06 wrx throttle body coolant bypass question I Love Boobies Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-23-2008 10:24 AM
Throttle body coolant bypass problem? SubasaurusWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2006 02:05 PM
Throttle Body coolant line mod WRX Joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-14-2002 11:55 AM
