Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-13-2006, 05:26 PM   #1
bustaman
Member#: 27264
2005 STi
CGM
Question u think my WB o2 sensor is bad??
was at the track yesterday and logging all of my runs, and for some reason everything was checking out, but for some reason every time i would get into 5th gear, the WB data from the Tuner tells me that my a/f is completely lean throughout the whole gear!! now there are no counts of knock, and granted my idcs are pretty maxxed, but i dont think the a/f could really be that lean with out something blowing up at full throttle thoughout the whole gear, and i made a bunch of passes and the same thing kept happening. The thing that bothers me is that it kept doing this at the track when i was logging, and then after i left the track i tried doing some more logging, and it would do the same, but if i unplugged the data cable from the tuner and just watched the readout on the tuner box it told me what the a/f was all throughout 5th gear..... does this mean that my sensor is just messed up and its time for a new one, or wtf else could it be??
heres some log of it:
Code:
4578  -5.0 3.0  33  10    00   +33.6   30.7 +22.0  -0.1 325.00 3.3  11.34
 4636  -6.9 3.8  78  10    00   +20.8   62.7 +22.0  -0.1 375.00 3.9  11.24
 4721  -2.3 4.3  91  30    00   +19.4   92.5 +21.5  +0.6 375.00 4.5  11.37
 4714  +5.3 4.6  93  70    00   +19.6  ---.- +19.5  -0.2 375.00 4.5  11.06
 4960 +12.6 4.6  93  90    00   +19.4   97.5 +19.7  -1.9 375.00 4.5  10.89
 5058 +17.0 4.6  93  90    00   +20.3  ---.- +20.5  -2.6 375.00 4.5  11.01
 5136 +19.3 4.6  87  90    00   +20.3   98.1 +20.9  -2.6 375.00 4.4  11.11
 5249 +19.3 4.6  85  90    00   +20.2  ---.- +21.0  -2.5 375.00 4.5  11.14
 5630 +18.5 4.6   9  00    00   +19.6   55.5 ECU.   +0.0 ECU.   4.2  11.18
 4810 +12.0 3.4   2  00    00   +23.4  ---.- ECU.   +0.0 ECU.   3.2  11.58
 4450  +4.6 3.1   2  00    00   +23.4  ---.- ECU.   +0.0 ECU.   3.0  12.02
 4110  -1.9 3.0  48  10    00   +33.4   39.4 +21.0  +0.0 ECU.   3.4  11.73
 3963  -4.8 3.7  95  10    00   +14.9   46.9 +21.0  +0.0 375.00 3.8  11.81
 3912  -0.8 4.0  95  40    00   +12.2   71.9 +19.4  +1.0 375.00 4.2  12.05
 3885  +5.9 4.4  97  70    00   +11.9   85.7 +17.6  +0.0 375.00 4.4  11.30
 4040 +13.3 4.3  96 100    00   +12.4   84.8 +16.6  +0.2 375.00 4.4  10.73
 4120 +17.7 4.3  97 100    00   +12.5   79.5 +16.7  +0.4 375.00 4.4  10.78
 4171 +20.6 4.3  97 100    00   +12.8   82.7 +17.3  +0.4 375.00 4.3  10.93
 4203 +21.9 4.4  97 100    00   +12.9   84.9 +17.5  +0.3 375.00 4.3  10.95
 4323 +21.9 4.4  97 100    00   +13.1   88.1 +17.7  +0.1 375.00 4.4  10.96
 4317 +21.7 4.4  97 100    00   +13.2   89.1 +17.7  +0.2 375.00 4.4  10.96
 4415 +21.9 4.5  97 100    00   +13.2   89.2 +18.1  +0.3 375.00 4.4  10.99
 4456 +21.9 4.5  97 100    00   +14.5   92.4 +18.3  +0.3 375.00 4.5  11.05
 4528 +21.7 4.5  98 100    00   +14.6   94.1 +18.4  -0.3 375.00 4.5  11.06
 4585 +22.1 4.5  98 100    00   +14.8   96.8 +18.9  +0.3 375.00 4.5  10.96
 4701 +21.9 4.6  98 100    00   +15.0   94.7 +19.0  +0.0 375.00 4.5  10.83
 4741 +21.7 4.6  97 100    00   +15.1  ---.- +19.2  -0.3 375.00 4.6  10.81
 4761 +21.7 4.5  97 100    00   +15.3  ---.- +19.5  -0.8 375.00 4.5  10.86
 4823 +21.4 4.6  98 100    00   +15.3  ---.- +19.5  -0.6 375.00 4.5  10.93
 4901 +21.9 4.6  97 100    00   +15.3  ---.- +19.5  -1.5 375.00 4.5  10.96
 4880 +21.7 4.6  97 100    00   +15.2  ---.- +19.5  -2.6 375.00 4.5  11.01
 5073 +21.2 4.6  97 100    00   +15.4   96.8 +19.5  -2.6 375.00 4.5  11.05
 5120 +20.8 4.6  97 100    00   +16.4  ---.- +19.7  -2.6 375.00 4.4  11.17
 5096 +20.2 4.6  97 100    00   +16.8   99.7 +19.9  -2.6 375.00 4.5  11.45
 5249 +20.0 4.6  97  90    00   +16.7  ---.- +20.7  -2.6 375.00 4.5  12.00
 5316 +20.0 4.6  97  90    00   +16.7   98.5 +20.6  -2.6 375.00 4.5  13.31
 5175 +19.6 4.6  98 100    00   +16.7  ---.- +20.8  -1.7 375.00 4.5  17.72
 5411 +19.3 4.6  98  90    00   +16.9   97.9 +21.2  -2.4 375.00 4.5  >25:1
 5350 +19.1 4.7  97  90    00   +17.0  ---.- +21.4  -2.2 375.00 4.5  >25:1
 5411 +18.5 4.7  98  90    00   +17.1  ---.- +21.5  -2.3 375.00 4.5  >25:1
 5437 +17.9 4.7  97  90    00   +17.2  ---.- +21.7  -1.8 375.00 4.5  >25:1
 5428 +17.5 4.6  98  80    00   +17.3  ---.- +21.9  -1.6 375.00 4.6  >25:1
 5602 +17.7 4.6  98  90    00   +17.6  ---.- +22.2  -1.9 375.00 4.6  >25:1
 5668 +17.7 4.7  97  90    00   +17.6  100.0 +22.2  -1.7 375.00 4.6  >25:1
 5630 +17.9 4.7  98  90    00   +17.6  ---.- +22.2  -1.9 375.00 4.5  >25:1
 5678 +17.9 4.6  98  90    00   +17.6  ---.- +22.5  -1.6 375.00 4.5  >25:1
 5767 +17.0 4.6  98  80    00   +17.6  ---.- +22.6  -1.5 375.00 4.6  >25:1
 5737 +16.6 4.7  98  80    00   +17.9  ---.- +22.6  -1.5 375.00 4.6  >25:1
 5787 +16.2 4.7  98  80    00   +18.3  ---.- +22.5  -1.5 375.00 4.6  >25:1
bustaman is offline   Reply With Quote
Old 04-17-2006, 12:31 PM   #2
meld
Member#: 91217
06 Evo IX / 04' R1
Tarmac Black
I know your o2 is bad, that happened to mine too, I replaced it and everything went back to normal.
meld is offline   Reply With Quote
Old 04-17-2006, 01:03 PM   #3
Freon
Member#: 88322
2009 BMW 135i
Yes, the WB isn't reporting correctly, but you probably are running somewhat lean since your injectors are maxed, hardcore. You're maxing at MAF 4.5V and running up to 4.7v! Yikes!
Freon is offline   Reply With Quote
Old 04-17-2006, 07:44 PM   #4
Peeblesmx445
Member#: 92202
I believe the STI MAF's go up to 5.0 Volts
Peeblesmx445 is offline   Reply With Quote
Old 04-18-2006, 11:34 AM   #5
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
both my wb02 sensors that I've had both give insane readings like that when they go bad, so I believe its the sensor now and not the tuner itself. but either way, thats what they do when they seem to finally go. any race gas through yours?
sucks I know!
SBW is offline   Reply With Quote
Old 04-18-2006, 07:29 PM   #6
bustaman
Member#: 27264
2005 STi
CGM
at the time of that log, i had about 7 gal of 100 oct mixed with under 1/4 tank of 93 octane. i ordered a new sensor... so when it comes and i put it in we shall see what happens to the logs... thanks for the help though!
Old 04-19-2006, 02:04 AM   #7
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
I feel that my WB sensor also read leaner than usual ...
So is it true if the sensor going bad it will read leaner and leaner than it suppose to be?
WRX-Blue-Mica is offline   Reply With Quote
Is my O2 sensor bad? code3suby Service & Maintenance 1 02-11-2009 01:51 PM
I know you guys will know... Is my O2 sensor bad? webkris New England Impreza Club Forum -- NESIC 8 03-22-2006 08:29 PM
i think my knock sensor is causing me to detonate. possible? STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-27-2003 05:42 PM
How to tell if O2 sensor is bad paulw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-03-2002 02:07 PM
How to tell if a O2 sensor is bad??? RugDoc2003 General Forum Archive 21 02-21-2001 04:16 PM
