Old 04-14-2006, 01:48 PM   #1
Rdwrc
Member#: 112552
98 RS-WRX
RED
Default RS to Wrx swap speedo problem
Have 98 RS , have done '05 WRX swap, everything works except for speedo. Can someone help? A 98 RS DASH AND BULK HEAD HARNESS ,WIT A 05 WRX MOTOR TRANS DIFF TANK ECU AND MOTOR HARNESS ,EVERYTHING WORKS WELL EXEPT SPEDO IN DASH ,AND IF I CONECT 05 WRX SPEED SENSOR WIRE TO MY 98 CLUSTER .IGET A LOW SIGNAL SPEED SENSOR CELL LIGHT CODE .ANY HELP WILL BE AWSOME
Rdwrc is offline   Reply With Quote
Old 04-14-2006, 03:21 PM   #2
tcard
Member#: 80459
2000 impreza 6MT
DCCD silver
what exactly did you swap? everything, you swapped a tranny and motor into a 98rs harness? or did you swap in the new harness also? lemme know and i can try to help
tcard is offline   Reply With Quote
Old 04-14-2006, 05:25 PM   #3
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
the more details you provide, the better everyone here will be able to help you out. hook us up with some more info.
tweakling is offline   Reply With Quote
Old 04-14-2006, 06:05 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
typing a yelled response to questions looking for more info generally gets your thread ignored...
Old 04-14-2006, 08:11 PM   #5
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
You need to check the wire that you spliced in for the speedo. The rs wire is LG I believe, but anyway check it to see if you spliced the right wire.
JeremyRS is offline   Reply With Quote
Old 04-14-2006, 09:35 PM   #6
FF2
Member#: 63453
1998 Impreza 2.5RS
In a 98 cluster, pin A1 (white) is your speed sensor + and pin A3 (black) is your speed sensor -.
FF2 is offline   Reply With Quote
Old 07-24-2006, 04:36 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
You need to use your '98 speed sensor...
jamesfacts is offline   Reply With Quote
Old 07-24-2006, 04:53 PM   #8
TwoFive
Member#: 72511
08 Acura RDX
No, it will not work at all. I have just gone through this myself and have succesfuly got my speedo working. I have a 98 as well with a 2002 WRX swap. On 1998, the cluste uses a computer in the cluster to figure out the speed, the way the speed sensor is wired on the 98 uses three wires to the cluster, where as 99+ on uses a single wire. The other two wires A1&A3 will not be hooked up to anything, there for you will need to use a cluster calling for only a single wire, You need to use a WRX speed sensor and harness as well. Then you will need either a 99+ cluster from an RS or WRX. Then on pins A1 & A3 on the 98 cluster will not be used and A2 (Speed Sensor Signal form ECU) will be used on the RS cluster (PIN C10) You will need to completely repin the harness but it isnt hard. I have the wiring diagrams if you want them, just PM me if you have questions. But the speedometer works flawlessly on mine with no jumping/inconsistancy on the gauge itself.
Here is my thread where no one helped me figure out what was wrong, as well as other threads of note.
http://forums.nasioc.com/forums/show...t=speed+sensor
http://www.rs25.com/forums/showthrea...iagram+cluster
TwoFive is offline   Reply With Quote
Old 07-26-2006, 11:36 AM   #9
Rdwrc
Member#: 112552
98 RS-WRX
RED
Thanx Much I Will Give That A Try
Idea: Anyone help with mechanicals for rs to wrx swap? greddy18 New England Impreza Club Forum -- NESIC 3 03-18-2008 08:13 PM
RS to WRX swap xjordanx Electrical & Lighting 0 09-09-2006 02:43 PM
Have some ??'s on doing the rs to wrx swap yukon1 Alaskan Impreza Club Forum -- AKIC 20 05-27-2005 01:03 AM
rs to wrx swap civic1260 Mid Atlantic Impreza Club -- MAIC 13 11-08-2004 06:05 PM
S.E. RS to WRX swaps bluimpreza00 South East Region Forum 5 04-08-2003 08:43 AM
