Welcome to the North American Subaru Impreza Owners Club Thursday July 10, 2014
Old 04-14-2006, 02:54 PM   #1
Petrus
Member#: 71795
2006 Impreza WRX5spd
FREAKIN' BLUE!!!
Default Damage from running rich?
I'm looking for a car and am avoiding anything that's had a BOV on it but should I be? What kind of damage am I looking at if I find a good deal? Farking blow-off valves
Petrus is offline   Reply With Quote
Old 04-14-2006, 03:49 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I think mostly Carbon Build up in the cylinders and possibly Dead or almost dead Catalytic Converters.
Old 04-14-2006, 03:51 PM   #3
neomax
Member#: 54585
2013 WRX
doesn't running rich for long periods of time fork the life of sparkplugs?? Not a big deal though if it does.
neomax is offline   Reply With Quote
Old 04-14-2006, 04:01 PM   #4
Petrus
Member#: 71795
FREAKIN' BLUE!!!
How hard is it to get rid of the carbon buildup? (aftermarked exhaust to "repair" cats? )
Old 04-14-2006, 04:02 PM   #5
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
or if you dont have cats than you have one less thing off your hands.. and your get the lovely pops of after fire
EvolvedAK is offline   Reply With Quote
Old 04-14-2006, 04:08 PM   #6
gnef
Member#: 97014
2004 STi
carbon buildup could be taken care of with auto-rx, i think, maybe also some fuel injector cleaner like regane or techron? you could try B12 chemtool or seafoam as well.
gnef is offline   Reply With Quote
Old 04-14-2006, 04:17 PM   #7
boxxxer
Member#: 84647
For the 2.0L WRX it's a real problem because of the cat in the up-pipe. Running rich dumps fuel onto the up cat and roasts it which can lead to pre-mature failure. When the up cat fails it is sent through the turbo blades taking it out.
boxxxer is online now   Reply With Quote
Old 04-14-2006, 05:15 PM   #8
Petrus
Member#: 71795
FREAKIN' BLUE!!!
WOuld that be a gradual process or would it happen all at once, (so if the car was still operating properly and had the BOV removed it wouldn't have that problem in the future).?
Old 04-14-2006, 05:46 PM   #9
njskatchmo
Member#: 94618
2002 Bugeye
running a constant rich condition is bad. Rich from a BOV depending on how many miles its been on won't be that bad. Rich conditions lead to fouled plugs and injectors, destroyed cats, and in the worst case scenario you could end up with messed up valves and piston seals, but that's long term. BOV creates a rich condition for a second as long as you hear the bov for. (.5-2 seconds depnding on the bov)
The cat in the up pipe could destroy the turbo in one shot, it wont be gradual. Just buy a catless up pipe and problem is solved.
njskatchmo is offline   Reply With Quote
Old 04-14-2006, 05:52 PM   #10
boxxxer
Member#: 84647
It would happen all at once. The cat is ceramic, so once it cracks the whole mess lets loose. The problem with running rich, even due to a blow off valve, is you don't know how badly it's roasting that cat.
Old 04-14-2006, 09:31 PM   #11
nich0lai
Member#: 111538
2003 wagon go vroom
bug covered
I ran way rich for 1700 miles (my intercooler wasn't clamped to my throttle body). How soon should I start worrying bout replacing my cat?
thanks
nich0lai is offline   Reply With Quote
Old 04-15-2006, 05:32 AM   #12
RUrunning
Member#: 68758
04 STi
R.I.P. AEROSIM
+12345
RUrunning is offline   Reply With Quote
Old 04-15-2006, 06:47 AM   #13
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
First off the stock BOV will keep you running a safe AFR fine since it recirculates back into the intake. If you ever 'NEED' to get a bigger BOV(read NEED meaning you're turbos too big for the stock one) you'd have to get a front mounted intercooler anyway- which you can then set the BOV before the MAF getting rid of the running rich issue on off throttles. Really so long as you don't intentially set your AFR rich in the ECU there's nothing to worry about. If you buy pre 06 I'd still recommend getting a new up pipe and checking it out- it really was a stupid idea to put a cat right before a turbo . If you get 06 it comes catless in the up-pipe already .
EtoS is offline   Reply With Quote
Old 04-15-2006, 12:22 PM   #14
njskatchmo
Member#: 94618
2002 Bugeye
06 wrx is catless in the up pipe too? OMG they made that car amazing.
Old 04-15-2006, 02:20 PM   #15
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
thanks
as soon as you get a CEL with an o2 sensor code. I doubt it was that big of a deal though.
Wiscon_Mark is offline   Reply With Quote
Old 04-15-2006, 02:48 PM   #16
taedaug
Member#: 97426
2002 WRX PSM
Stage Deuce!!!
Back to the original post...
I flat-out wouldn't buy a car that wasn't 100% stock. You have no idea how it was used. especially if they have a bov without the correct supporting mods.
taedaug is offline   Reply With Quote
Old 04-16-2006, 12:27 AM   #17
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
The BOV may or may not cause damage. However, what does it say about an owner that would put that item on his car? What other bad choices did he make?
bofh is offline   Reply With Quote
ej207 v5 swapped from vf28 to vf34 not runs rich @ idle impreziv25 Subaru Conversions 6 05-24-2007 04:46 PM
Damage to car from running stiff suspension daily? BlackoutWRX Brakes, Steering & Suspension 8 04-12-2007 03:11 PM
high egt's from running rich? KitchenerWRX Newbies & FAQs 12 12-01-2005 02:35 AM
Got back from dealer, now running rich!! Javier Factory 2.0L Turbo Powertrain 1 06-17-2005 11:29 AM
can't stop running rich from RRFPR HubbieScooby Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-28-2002 07:55 PM
