Old 04-14-2006, 05:01 PM   #1
MtlPete
Member#: 77332
Default simple question about ecutek
this may be a silly question, is ecutek just a tool that plugs into your ecu, which allows you to modify it, and at the end you're still driving around with your ecu in there, or does it actually replace your ecu?
MtlPete is offline   Reply With Quote
Old 04-14-2006, 05:11 PM   #2
cronic
Member#: 9749
It is just a software that allows changes to be made to the Ecu's rom files.. Everything is mapped onto the stock ecu, and there is no other physical hardware installed into the car.
cronic is offline   Reply With Quote
Old 04-14-2006, 05:13 PM   #3
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Great software to add to that too.
Poweredbysnail is offline   Reply With Quote
Old 04-14-2006, 05:14 PM   #4
MtlPete
Member#: 77332
thanks guys
Old 04-14-2006, 05:29 PM   #5
Chuck H
Member#: 20442
In case you're not familiar with it, it's also fairly expensive software, and there's a several hundred dollar licensing fee that goes back to the EcuTek company for each ECU that you re-flash with it. That's why it's generally the tuners that have it, and not individual owners.
Chuck H is offline   Reply With Quote
Old 04-24-2006, 04:48 PM   #6
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Just asking the question, but why would an individual owner want it? I understand you could attempt to tune it yourself, though what is the main purpose of having the system for your own use when a tuner could do it for you?
Thanks,
William T. Knose Jr.
Lead Programmer
I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Old 04-24-2006, 10:19 PM   #7
teiva-boy
Member#: 22825
Thanks,
Lead Programmer
I-Speed USA
For said owner to have complete control over what he/she paid for. It sucks to pay that much money for nothing tangible in hand. If it came with an unlock code for taking it to another tuner that would be great. But then again, we get into the whole debate about a tuners IP.
teiva-boy is offline   Reply With Quote
Old 04-25-2006, 01:03 PM   #8
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
From Crawford Performance/I-Speed USA you are receiving a service beyond the reprogramming of the ECU. If is CEL pops up, it is like having a warranty program with a Subaru dealership. Just bring your car in and we will take care of it.
I can understand having nothing tangible in hand but why would you want to get a tune from one shop and then have an unlock code so that you could bring it to another tuner?
Cheers,
Lead Programmer
I-Speed USA
Old 04-25-2006, 01:15 PM   #9
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
I could see it used for customers that are in the middle of no where and need a new map because modifications have changed.
Found an example of someone that has a problem and could use this solution. Though if the tuner had reprogrammed the ECU correctly from the time it left the shop, this car would not have any problems.
http://forums.nasioc.com/forums/showthread.php?t=990335
Cheers,
Lead Programmer
I-Speed USA
Old 05-04-2006, 02:11 PM   #10
Subi114
Member#: 48401
2015 STi
Dark Grey Metallic
it would be good if the owner of the vehicle can just take it to any shop/tuner after it has been tuned.... For example what if the car sucks because the tuner didn't tune it correctly? do you think they would actually go back to the same tuner? probably once but that's just to fix the problem.... and most tuners will charge for a retune. so i'd rather have some other tuner that is compitant to do the tune.
Subi114 is offline   Reply With Quote
Old 05-11-2006, 01:26 AM   #11
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
you can already do this... As long as you have the initial ecutek licence on teh ecu from whichever tuner, the new tuner can rewrite the ecu for you. You just pay for tuning labour .
jigga is offline   Reply With Quote
Old 05-11-2006, 03:43 PM   #12
turboge
Member#: 35076
2004 507whp Wagon
If you're just looking to tune the car yourself there are plenty of open source FREE solutions available.
turboge is offline   Reply With Quote
Old 05-11-2006, 07:06 PM   #13
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Most tuners might charge to fix problem they tune into the system. We stand by our work and if you get a CEL we want to know about it right away. If the problem was caused by our tune we will fix it at our cost that day if need be.
Cheers,
Lead Programmer
Crawford Performance / I-Speed USA
Simple question about one little bolt... rossscarbro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-27-2004 11:22 AM
simple question about changing lug nuts Wagon Joe Tire & Wheel 4 04-01-2004 06:03 PM
Simple Question about TTed imprezas SSJ Char Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-18-2002 09:56 PM
Simple questions about the board. Dannie Newbies & FAQs 6 09-18-2001 04:05 AM
A simple question about wheels francophile Legacy Forum 5 08-28-2001 11:12 AM
