Old 04-14-2006, 11:17 PM   #1
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Default USDM or JDM STi motor for the WRX swapped RS?
OK here is where I stand. I have an 01 2.5RS with a WRX swap and I'm buying a rolled over 04 USDM STi for a VERY GOOD PRICE. I'm trying to make this swap go as easy as possible but I'm was confronted with a very interesting propsition.
The DBW wiring is going to make this a pain. Infact this whole thing seems like its going to be a pain. I keep hearing that I'm going to have to rewire the entire swap and that just don't seem worth it.
So with that said a JDM ej207 swap might be the ticket. No DBW so the swap should be really straight forwad, few wires and im done theoreticly. And if I want torque later on I can get either a USDM 2.5l bottom end or an Crawford/Axis bottom end.
So should keep the USDM STi motor or sell it and get a JDM EJ207?
Oh and just so you know I'm swapping due to a failed ej205 bottom end in the car now. So if you have any other idea's send'em.
Big_DeWeY is offline   Reply With Quote
Old 04-15-2006, 01:51 AM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
If you are set on buying the rolled STi; what I would do is swap in the STi long block. Sell everything else and get some EM. If you want avcs you could use a JDM STi ecu and have it reflashed.
RS_to_WRX_swap is offline   Reply With Quote
Old 04-15-2006, 09:59 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if you don't want to rewire it I would buy the rolled sti, sell the motor, install the trans & brakes sell old parts, then buy a v7 motor it should net a profit
WTB: JDM sti grill for 03 WRX, JDM hood scoop, or JDM OR EDM headlights teg_09 Private 'Wanted' Classifieds 0 05-30-2009 02:22 PM
USDM or JDM STI 6MT Drivetrain Swap blksubie Mid Atlantic Impreza Club -- MAIC 16 01-06-2007 07:39 AM
JDM STi motor mounts vs. WRX USDM mounts Stealth_RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-24-2006 08:55 PM
USDM or JDM STi intecooler + Y pipe BIGSKYWRX Private 'Wanted' Classifieds 9 10-30-2003 07:11 PM
Will the cost of the JDM STi lights for the WRX come down in price? Scoobie Newbie Newbies & FAQs 4 02-25-2003 03:24 PM
