Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-15-2006, 12:31 AM   #1
ElmnTfrliF
Member#: 72708
2005 STi
2009 CBR600RR
Default Weird problem
So after running my 100% atmospheric BOV for the past couple months, I decided to throw my stock BPV on, just to feel the difference once again (Boy there sure as hell is...)
Going WOT up to ~6k rpms, I shift and the rpms just hang... and hang... and hang and then finally drop. First I'm thinking WTF? I must not have plugged the vacuum line in enough? I checked it to be fine. I borrowed my friend's WORX BOV/BPV and set it to 100% atmospheric and it shifts fine. I closed it to 100% recirculation and the rpms hang like a mofo.
I then bought a brand new vacuum line from the auto parts store... no dice. I decided to throw the UTEC map selector in 0 to see if going to stock helps anything and BAM problem fixed.
I have searched the forums and the best thing I have seen is adjusting the open loop to closed loop delay. Mine are set to default which is 2 for CL -> OL and 0 for OL -> CL. I played with the settings and nothing helps, moving them up makes it worse... as I would have thought.
The map I am running is a tweaked stage two map for lower boost and safety. I thought this might be the problem, so I reloaded a base stage two map on and received the same problem. I then reloaded the stage 1-3 parameters and nothing still.
I'm in the dark about this issue; can someone please shed some light?
Eric
ElmnTfrliF is offline   Reply With Quote
Old 04-15-2006, 12:33 AM   #2
ElmnTfrliF
Member#: 72708
2005 STi
2009 CBR600RR
Heres a log from a 1-2-3 pull.
*edit* also not shown: My AEM wideband is showing 11.0-11.5 A/F ratio with 0% TPS while hanging at ~6k rpms...
Code:
  3875  -0.6 3.2 100  20    00  11.5  +23.8   41.7 +21.1  -0.3 WGS.   3.4  11.50
 4035  +1.1 3.4 100  30    00  11.5  +19.5   51.9 +19.5  +0.1 WGS.   3.6  11.50
 4166  +1.1 3.4 100  30    00  11.5  +16.6   53.8 +18.7  +0.1 WGS.   3.7  11.50
 4301  +3.1 3.6 100  40    00  11.5  +17.4   58.4 +19.0  +0.1 WGS.   3.7  11.50
 4409  +3.1 3.6 100  40    00  11.5  +16.3   62.1 +19.1  +0.1 WGS.   3.8  11.50
 4474  +4.7 3.8 100  40    00  11.5  +16.8   68.7 +20.2  +1.6 WGS.   3.8  11.50
 4775  +6.4 3.8 100  60    00  11.5  +17.1   81.8 +21.0  +0.8 370.00 3.9  11.50
 4982  +8.2 3.9 100  70    00  11.5  +19.4   81.3 +21.0  -0.1 370.00 3.9  11.50
 5151  +8.2 3.9 100  70    00  11.5  +19.6   84.1 +21.0  -0.1 370.00 3.9  11.50
 5333  +9.6 3.9 100  70    00  11.5  +22.5   88.6 +21.0  -0.5 370.00 4.0  11.50
 5509 +10.8 4.0 100  70    00  11.5  +23.4   89.8 +21.0  -0.6 370.00 4.0  11.50
 5621 +10.8 4.0 100  70    00  11.5  +24.4   89.8 +21.0  -0.8 370.00 4.0  11.50
 5787 +10.8 4.0 100  70    00  11.5  +24.5   87.6 +21.3  -0.9 365.00 4.0  11.50
 5827 +11.5 4.0 100  70    00  11.5  +25.2   88.3 +21.7  -0.9 365.00 4.0  11.50
 5920 +11.5 4.0 100  70    00  11.5  +25.0   85.5 +22.0  -1.4 365.00 4.0  11.50
 5963 +12.1 4.1  96  70    00  11.5  +25.7   91.0 +22.0  -1.0 365.00 4.0  11.50
 6301 +12.1 4.1  96  70    00  11.5  +26.0   89.3 +22.9  -0.7 350.00 3.9  11.50
 6161 +11.7 4.1  23  60    00  11.5  +28.2   41.6 +21.0  -0.6 ECU.   2.2  11.50
 5931 +11.7 4.1  23  60    00  11.5  +11.0   11.6 +21.0  -0.4 ECU.   2.1  11.50
 6016  +9.6 2.1   0  30    00  12.2  +10.7   11.7 +21.0  -0.9 ECU.   2.0  12.20
 5973  +9.6 2.1   0  30    00  11.5  +10.9   11.4 +21.0  -1.8 ECU.   2.1  11.50
 6049  +6.6 2.1   0  10    00  11.5  +10.9   12.0 +21.0  -1.8 ECU.   2.1  11.50
 5910  +3.1 2.2   0  10    00  11.5  +10.7   12.3 +21.0  -1.8 ECU.   2.1  11.50
 5889  +3.1 2.2   0  10    00  11.5  +10.8   12.7 +21.0  -1.8 ECU.   2.1  11.50
 5807  -0.2 2.2   0  10    00  11.5  +10.9   12.1 +21.0  -1.8 ECU.   2.1  11.50
 5807  -3.2 2.2   0  10    00  11.5  +10.9   11.9 +21.0  -1.8 ECU.   2.1  11.50
 5767  -3.2 2.2   0  10    00  11.5  +10.7   11.6 +21.0  -1.8 ECU.   2.1  11.50
 5717  -6.1 2.2   0  10    00  11.5  +10.6   11.8 +21.0  -1.6 ECU.   2.1  11.50
 5583  -9.1 2.1   0  10    00  11.5  +11.6   12.6 +21.0  -1.6 ECU.   2.3  11.50
 5537  -9.1 2.1   0  10    00  11.5  +14.7   15.3 +21.0  -1.5 ECU.   2.5  11.50
 5464 -11.2 2.6  13  10    00  12.0  +21.6   28.7 +21.0  -1.7 ECU.   3.0  12.00
 5324 -10.8 3.2  40  10    00  13.0  +24.1   39.7 +23.0  -1.6 ECU.   3.3  13.00
 5208 -10.8 3.2  40  10    00  13.0  +24.4   45.6 +23.0  -1.9 225.00 3.3  13.00
 4844  -9.4 3.4  83  10    00  11.5  +26.5   55.3 +22.0  -0.6 WGS.   3.5  11.50
 4604  -7.1 3.6 100  10    00  11.5  +22.2   62.7 +22.0  -0.9 WGS.   3.7  11.50
 4480  -7.1 3.6 100  10    00  11.5  +18.7   60.7 +22.2  -0.2 WGS.   3.7  11.50
 4474  -4.5 3.8 100  20    00  11.5  +16.2   66.7 +20.5  -0.8 WGS.   3.8  11.50
 4668  -1.2 3.8 100  40    00  11.5  +18.0   72.1 +20.2  +0.5 WGS.   3.9  11.50
 4796  -1.2 3.8 100  40    00  11.5  +18.8   81.3 +20.5  +0.5 370.00 3.9  11.50
 4816  +1.9 3.9 100  60    00  11.5  +16.2   83.6 +19.9  +2.2 370.00 3.9  11.50
 4938  +5.1 3.9 100  60    00  11.5  +18.0   80.9 +20.7  +0.7 370.00 3.9  11.50
 5020  +5.1 3.9 100  70    00  11.5  +19.2   80.1 +20.7  -0.1 370.00 3.9  11.50
 5005  +7.8 3.9 100  70    00  11.5  +20.6   81.9 +21.0  -0.1 370.00 3.9  11.50
 5144 +10.0 4.0 100  70    00  11.5  +21.5   82.5 +21.0  -0.1 370.00 3.9  11.50
 5144 +10.0 4.0 100  70    00  11.5  +20.9   86.1 +21.0  -0.5 370.00 3.9  11.50
 5299 +11.3 4.0 100  70    00  11.5  +22.1   87.7 +21.0  -0.2 370.00 4.0  11.50
 5367 +11.9 4.0 100  60    00  11.5  +22.6   88.8 +21.2  -0.2 370.00 4.0  11.50
 5385 +11.9 4.0 100  60    00  11.5  +22.9   88.2 +21.2  -0.3 370.00 4.0  11.50
 5564 +12.3 4.0 100  60    00  11.5  +23.6   90.7 +21.2  -0.4 370.00 4.0  11.50
 5649 +12.3 4.0 100  60    00  11.5  +23.5   91.8 +21.2  -0.4 370.00 4.0  11.50
 5707 +12.3 4.0 100  60    00  11.5  +23.7   92.0 +21.2  -0.4 370.00 4.0  11.50
 5807 +11.7 4.1 100  60    00  11.5  +23.9   93.0 +21.5  -0.4 365.00 4.0  11.50
 5847 +11.9 4.1  79  70    00  11.5  +24.1   91.8 +21.3  -0.9 365.00 4.0  11.50
 5920 +11.9 4.1  79  70    00  11.5  +24.8   92.5 +21.6  -0.9 322.50 3.9  11.50
 5707 +10.6 3.9   6  50    00  11.5  +41.5   13.2 +21.0  -0.1 ECU.   2.3  11.50
 5817  +8.0 2.2   0  30    00  11.5  +10.6   10.9 +21.0  -1.1 ECU.   2.0  11.50
 5878  +8.0 2.2   0  30    00  11.5  +10.6   10.7 +21.0  -1.1 ECU.   2.0  11.50
 5868  +5.3 2.1   0  10    00  11.5  +10.8   11.7 +21.0  -1.8 ECU.   2.1  11.50
 5787  +2.5 2.2   0  10    00  11.5  +10.9   12.2 +21.0  -1.8 ECU.   2.1  11.50
 5727  +2.5 2.2   0  10    00  11.5  +10.8   11.8 +21.0  -1.8 ECU.   2.1  11.50
 5767  +2.5 2.2   0  10    00  11.5  +10.8   12.1 +21.0  -1.8 ECU.   2.1  11.50
 5727  -0.4 2.2   0  10    00  11.5  +10.9   12.1 +21.0  -1.7 ECU.   2.1  11.50
 5717  -0.4 2.2   0  10    00  11.5  +10.7   12.6 +21.0  -1.6 ECU.   2.2  11.50
 5602  -6.1 2.2   0  10    00  11.5  +10.9   12.1 +21.0  -1.5 ECU.   2.2  11.50
 5546  -8.9 2.5  12  10    00  11.5  +14.8   24.1 +21.0  -1.7 ECU.   2.9  11.50
 5491  -8.9 2.5  12  10    00  11.5  +16.5   35.6 +21.0  -1.7 ECU.   3.1  11.50
 5464 -10.0 3.2  52  10    00  14.1  +19.5   50.9 +23.0  -1.5 255.00 3.4  14.10
 5274  -8.7 3.6  92  10    00  11.5  +25.4   57.3 +23.0  -1.9 255.00 3.6  11.50
 5151  -8.7 3.6  92  10    00  11.5  +25.3   64.3 +23.0  -1.9 WGS.   3.7  11.50
 4852  -6.7 3.7 100  10    00  11.5  +21.1   71.0 +22.0  -1.7 WGS.   3.8  11.50
 4528  -3.6 3.9 100  20    00  11.5  +17.9   70.7 +20.2  -0.9 WGS.   3.8  11.50
 4649  -3.6 3.9 100  20    00  11.5  +17.0   73.6 +20.2  -0.2 WGS.   3.9  11.50
 4816  -0.6 3.9 100  50    00  11.5   -3.4   83.0 +20.7  +1.5 370.00 3.9  11.50
 4662  +2.5 3.9 100  50    00  11.5  +14.7   80.2 +19.1  +0.1 370.00 3.9  11.50
 4803  +2.5 3.9 100  60    00  11.5  +14.9   80.9 +19.3  +1.3 370.00 3.9  11.50
 4894  +5.7 3.9 100  70    00  11.5  +17.8   82.8 +19.5  +1.2 370.00 4.0  11.50
 4901  +8.4 3.9 100  70    00  11.5  +17.0   76.7 +20.3  +1.5 370.00 3.9  11.50
 4960  +8.4 3.9 100  70    00  11.5  +18.5   79.4 +20.3  +0.2 370.00 3.9  11.50
 5027 +10.6 3.9 100  70    00  11.5  +19.6   76.7 +21.0  -0.1 370.00 3.9  11.50
 4982 +12.3 3.9 100  70    00  11.5  +21.3   79.1 +21.0  -0.1 370.00 3.9  11.50
 5050 +12.3 3.9 100  70    00  11.5  +21.3   82.9 +21.0  -0.1 370.00 3.9  11.50
 5050 +12.3 3.9 100  70    00  11.5  +20.3   82.2 +21.0  -0.1 370.00 3.9  11.50
 5112 +12.7 3.9 100  70    00  11.5  +21.7   80.9 +21.0  -0.1 370.00 3.9  11.50
 5112 +12.7 3.9 100  70    00  11.5  +20.6   83.3 +21.0  -0.1 370.00 3.9  11.50
 5282 +12.5 4.0 100  70    00  11.5  +22.0   83.9 +21.0  -0.5 370.00 3.9  11.50
 5232 +12.5 4.0 100  60    00  11.5  +22.0   86.0 +21.2  -0.1 370.00 4.0  11.50
 5385 +12.5 4.0 100  60    00  11.5  +22.3   88.7 +21.2  -0.2 370.00 4.0  11.50
 5359 +12.1 4.0 100  70    00  11.5  +22.2   90.4 +21.0  -0.3 370.00 4.0  11.50
 5437 +12.3 4.0 100  70    00  11.5  +22.5   89.6 +21.0  -0.5 370.00 4.0  11.50
 5446 +12.3 4.0 100  70    00  11.5  +22.4   88.0 +21.0  -0.5 370.00 4.0  11.50
 5473 +12.3 4.0 100  70    00  11.5  +22.7   90.5 +21.0  -0.6 370.00 4.0  11.50
 5611 +11.9 4.0 100  70    00  11.5  +23.2   89.0 +21.0  -0.6 370.00 4.0  11.50
 5500 +11.9 4.0 100  70    00  11.5  +23.0   88.9 +21.0  -0.6 370.00 4.0  11.50
 5668 +12.5 4.0 100  70    00  11.5  +23.8   91.8 +21.0  -0.8 370.00 4.0  11.50
 5747 +12.5 4.1 100  70    00  11.5  +24.2   91.5 +21.0  -0.8 370.00 4.0  11.50
 5707 +12.5 4.1 100  70    00  11.5  +23.7   90.0 +21.0  -0.9 370.00 4.0  11.50
 5777 +12.5 4.0  98  70    00  11.5  +24.1   93.0 +21.0  -0.9 370.00 4.0  11.50
 5777 +12.3 4.0  98  70    00  11.5  +24.1   91.7 +21.1  -0.9 370.00 4.0  11.50
 5787 +12.3 4.0  98  70    00  11.5  +24.5   93.8 +21.2  -0.9 350.00 4.0  11.50
Old 04-16-2006, 12:56 AM   #3
ElmnTfrliF
Member#: 72708
2005 STi
2009 CBR600RR
Bump!!!!!!!!!!!!!! Anyone have an idea what this might be??
Old 04-19-2006, 11:25 AM   #4
ElmnTfrliF
Member#: 72708
2005 STi
2009 CBR600RR
Old 04-19-2006, 12:02 PM   #5
Xman23
Member#: 50224
2004 WRX
Well, I'll take a stab here...
Your IDC's seem really high for the low boost you're running. As if you're drowning in fuel. The wideband readings seem...broken...or useless.
Are you using bigger injectors? Either way, is the injector scaling set right? You might want to check all your parameters, or find out why your IDC's are so high.
Xman23 is offline   Reply With Quote
Old 04-19-2006, 01:02 PM   #6
ElmnTfrliF
Member#: 72708
2005 STi
2009 CBR600RR
My mods are: catless exhaust, intercooler hoses, turbo inlet pipe and bov. Nothing too special.
My AEM UEGO isn't integrated into my logs. I need to wire that up, so I can take true logs /w a/f... However, I know I'm running 10.x:1 a/f ratios @ WOT because the AEM goes blank.
The parameters are standard stage 1-3 from turboxs.
Here is my stage two map. Initially, the target was for 16psi this winter, but since its warmer.. they seem to have dropped a bit. It's about 60 degrees outside today. I'll get a log on lunch break.
*edit* I also added in some timing and fuel for the 0% column to prevent shift knock. I was experiencing it during the winter.
Code:
[START][MAPGROUP1][MAPGROUP]
Map Name:-[Stg2 Eric Tune]
Map Comments:-[Stg2 Eric Tune]
Fuel Map
      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]
      [0]   [-1.2]   [-1.2]   [-0.9]   [-0.6]    [0.3]      [1]      [1]      [1]      [1]      [1]
      [0]   [-1.2]   [-1.2]   [-0.9]   [-0.6]    [0.3]    [1.3]    [1.3]    [1.3]    [1.3]    [1.3]
      [0]     [-1]     [-1]   [-0.3]      [0]    [1.3]    [2.3]    [2.6]    [2.6]    [2.6]    [2.6]
      [0]   [-0.7]   [-0.7]    [0.2]    [0.5]      [2]    [3.3]    [3.8]      [4]    [4.1]    [4.1]
      [0]   [-0.2]   [-0.2]    [0.7]      [1]    [2.5]    [3.8]    [4.3]    [4.5]    [4.6]    [4.6]
      [0]   [-0.2]   [-0.2]    [0.7]      [1]    [2.1]    [3.4]    [3.9]    [3.9]      [4]      [4]
      [0]   [-0.2]   [-0.2]    [0.5]    [0.8]    [1.9]    [3.2]    [3.7]    [3.7]    [3.8]    [3.8]
    [0.2]   [-0.4]   [-0.4]    [0.3]    [0.6]    [1.5]      [3]    [3.5]    [3.5]    [3.6]    [3.6]
    [0.2]   [-0.9]   [-0.9]   [-0.2]    [0.1]    [1.6]    [2.6]    [2.9]    [2.9]      [3]    [3.1]
    [0.3]   [-0.9]   [-0.9]   [-0.2]    [0.1]    [1.6]    [2.6]    [2.9]    [2.9]      [3]    [3.1]
    [0.3]   [-0.1]   [-0.1]    [0.6]    [0.9]    [1.6]    [2.2]    [2.5]    [2.5]    [2.6]    [2.7]
    [0.3]   [-1.9]   [-1.9]   [-0.6]    [0.4]    [0.4]   [-0.2]   [-0.1]   [-0.1]    [0.1]    [0.2]
    [0.4]   [-1.9]   [-1.9]   [-0.6]    [0.4]   [-0.1]   [-0.1]   [-0.1]   [-0.1]   [-0.1]   [-0.1]
    [0.4]   [-1.5]   [-1.8]   [-1.1]   [-0.1]   [-0.1]   [-0.4]   [-0.6]   [-0.5]   [-0.4]   [-0.3]
    [0.5]   [-1.8]   [-1.8]   [-1.1]   [-0.1]   [-0.1]   [-0.4]   [-0.9]   [-0.9]   [-0.8]   [-0.7]
    [0.5]   [-1.8]   [-1.8]   [-1.1]   [-0.1]   [-0.1]   [-0.4]   [-0.9]   [-0.9]   [-0.9]   [-0.9]
    [0.5]   [-1.5]   [-1.5]   [-0.8]   [-0.1]   [-0.1]   [-0.7]   [-1.2]   [-1.1]     [-1]   [-1.2]
    [0.5]   [-1.5]   [-1.5]   [-0.8]   [-0.4]   [-0.4]     [-1]   [-1.5]   [-1.4]   [-1.3]   [-1.2]
    [0.5]   [-1.4]   [-1.4]   [-0.7]   [-0.3]   [-0.3]   [-0.9]   [-1.4]   [-1.3]   [-1.2]   [-1.1]
      [0]   [-1.4]   [-1.4]   [-0.7]   [-0.3]   [-0.3]   [-0.9]   [-1.4]   [-1.3]   [-1.2]   [-1.1]
      [0]   [-1.1]   [-1.1]   [-0.4]    [0.3]    [0.3]      [0]   [-0.3]   [-0.3]   [-0.3]   [-0.3]
Timing Map
   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
   [-100]     [38]     [35]     [32]     [29]     [29]     [29]     [29]     [29]     [29]     [29]
   [-100]     [37]     [34]     [31]     [28]     [28]     [28]     [28]     [28]     [28]     [28]
   [-100]     [36]     [33]     [30]     [27]     [27]     [27]     [27]     [27]     [27]     [27]
   [-100]     [35]     [32]     [29]     [26]     [26]     [26]     [26]     [26]     [26]     [26]
   [-100]     [34]     [31]     [28]     [25]     [25]     [25]     [25]     [25]     [25]     [25]
   [-100]     [33]     [30]     [27]     [24]     [24]     [24]     [24]     [24]     [24]     [24]
   [-100]     [32]     [29]     [26]     [23]     [23]     [23]     [23]     [23]     [23]     [23]
   [-100]     [31]     [28]     [25]     [22]     [20]     [20]     [20]     [20]     [20]     [20]
   [-100]     [30]     [27]     [24]     [21]     [16]     [16]     [15]     [14]     [14]     [13]
   [-100]     [29]     [26]     [23]     [20]     [16]     [16]     [15]     [14]     [14]     [13]
   [-100]     [28]     [25]     [22]     [19]     [16]     [16]     [15]     [14]     [14]     [13]
   [-100]     [27]     [24]     [21]     [18]     [16]     [16]     [15]     [14]     [14]     [13]
   [-100]     [26]     [23]     [20]     [18]     [16]     [16]     [15]     [14]     [14]     [13]
   [-100]     [25]     [22]     [21]     [17]     [16]     [16]     [15]     [14]     [14]     [13]
   [-100]     [24]     [21]     [20]     [18]     [18]     [18]     [17]     [16]     [16]     [16]
     [19]     [23]     [21]     [20]     [19]     [19]     [17]     [17]     [17]     [17]     [17]
     [19]     [22]     [21]     [20]     [19]     [20]     [17]     [17]     [17]     [17]     [17]
     [21]     [22]     [21]     [20]     [19]     [21]     [19]     [19]     [19]     [19]     [19]
     [21]     [23]     [23]     [23]     [23]     [22]     [22]     [21]     [21]     [20]     [20]
     [21]     [23]     [23]     [23]     [23]     [22]     [22]     [21]     [21]     [21]     [21]
     [21]     [25]     [25]     [24]     [24]     [23]     [23]     [22]     [22]     [22]     [22]
     [21]     [25]     [25]     [24]     [24]     [23]     [23]     [23]     [23]     [22]     [22]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [23]     [23]     [22]     [22]
Boost Map
      [0]      [0]      [0]    [200]    [225]    [250]    [275]    [300]    [325]    [400]    [500]
      [0]      [0]      [0]    [200]    [225]    [250]    [275]    [300]    [325]    [350]    [385]
      [0]      [0]      [0]    [200]    [225]    [250]    [275]    [300]    [325]    [350]    [365]
      [0]      [0]      [0]    [200]    [225]    [250]    [275]    [300]    [325]    [350]    [375]
      [0]      [0]      [0]    [200]    [225]    [250]    [275]    [300]    [325]    [350]    [370]
[END][MAPGROUP][03D1E][EOF]
Old 04-19-2006, 02:57 PM   #7
ElmnTfrliF
Member#: 72708
2005 STi
2009 CBR600RR
Here's a log of a stock ECU pull. Everything works as it is supposed to, but it feels SLOW!
Code:
 3687  +0.0 3.4  99  30    00  12.5  +21.4   38.8 ECU.   +0.0 ECU.   3.3  12.50
 3745  +0.0 3.4  99  30    00  12.5  +20.1   40.8 ECU.   +0.0 ECU.   3.3  12.50
 3849  +0.0 3.4  99  30    00  11.5  +20.2   43.2 ECU.   +0.0 ECU.   3.4  11.50
 3940  +2.3 3.4  98  40    00  11.5  +19.4   45.7 ECU.   +0.0 ECU.   3.4  11.50
 3907  +2.3 3.4  98  40    00  11.5  +19.1   47.6 ECU.   +0.0 ECU.   3.4  11.50
 3982  +4.1 3.4  98  40    00  11.5  +18.4   46.9 ECU.   +0.0 ECU.   3.5  11.50
 4065  +4.1 3.4  98  40    00  11.5  +15.9   51.9 ECU.   +0.0 ECU.   3.6  11.50
 4055  +5.5 3.6  98  50    00  11.5  +15.7   53.1 ECU.   +0.0 ECU.   3.6  11.50
 4060  +5.5 3.6  98  50    00  11.5  +15.2   53.3 ECU.   +0.0 ECU.   3.6  11.50
 4192  +7.0 3.5  98  60    00  11.5  +15.2   58.4 ECU.   +0.0 ECU.   3.6  11.50
 4224  +7.0 3.5  98  60    00  11.5  +14.8   59.8 ECU.   +0.0 ECU.   3.7  11.50
 4262  +8.4 3.6  99  60    00  11.5  +17.0   61.4 ECU.   +0.0 ECU.   3.7  11.50
 4363  +9.4 3.7  98  60    00  11.5  +16.1   65.9 ECU.   +0.0 ECU.   3.7  11.50
 4368  +9.4 3.7  98  60    00  11.5  +16.1   67.2 ECU.   +0.0 ECU.   3.7  11.50
 4444 +10.2 3.8  99  60    00  11.5  +16.8   68.2 ECU.   +0.0 ECU.   3.8  11.50
 4559 +10.8 3.7  98  60    00  11.5  +17.3   72.2 ECU.   +0.0 ECU.   3.8  11.50
 4578 +10.8 3.7  98  60    00  11.5  +17.7   74.4 ECU.   +0.0 ECU.   3.8  11.50
 4636 +11.5 3.8  98  70    00  11.5  +18.3   75.7 ECU.   +0.0 ECU.   3.9  11.50
 4741 +11.9 3.8  98  70    00  11.5  +18.6   78.5 ECU.   +0.0 ECU.   3.9  11.50
 4873 +11.9 3.8  98  70    00  11.5  +19.4   78.5 ECU.   +0.0 ECU.   3.9  11.50
 4916 +12.5 3.9  98  70    00  11.5  +20.1   82.4 ECU.   +0.0 ECU.   3.9  11.50
 5081 +12.5 3.9  99  70    00  11.5  +20.4   82.3 ECU.   +0.0 ECU.   3.9  11.50
 5065 +12.5 3.9  99  70    00  11.5  +20.6   86.1 ECU.   +0.0 ECU.   4.0  11.50
 5224 +12.7 4.0  98  70    00  11.5  +21.5   86.6 ECU.   +0.0 ECU.   4.0  11.50
 5367 +12.9 4.0  98  70    00  11.5  +21.7   90.0 ECU.   +0.0 ECU.   4.0  11.50
 5274 +12.9 4.0  98  70    00  11.5  +22.2   88.3 ECU.   +0.0 ECU.   4.0  11.50
 5482 +12.9 4.0  98  70    00  11.5  +22.8   89.0 ECU.   +0.0 ECU.   4.0  11.50
 5602 +12.9 4.0  99  70    00  11.5  +23.0   90.8 ECU.   +0.0 ECU.   4.0  11.50
 5659 +12.9 4.0  99  70    00  11.5  +23.5   89.0 ECU.   +0.0 ECU.   4.0  11.50
 5668 +12.7 4.1  98  70    00  11.5  +23.4   93.6 ECU.   +0.0 ECU.   4.0  11.50
 5827 +12.5 4.0  98  60    00  11.5  +23.8   93.4 ECU.   +0.0 ECU.   4.1  11.50
 5910 +12.5 4.0  98  60    00  11.5  +24.2   90.8 ECU.   +0.0 ECU.   4.1  11.50
 5963 +11.9 4.1  99  60    00  11.5  +24.2   95.6 ECU.   +0.0 ECU.   4.1  11.50
 6049 +11.9 4.1  72  60    00  11.5  +24.8   93.7 ECU.   +0.0 ECU.   4.0  11.50
 6060 +11.9 4.1  72  60    00  11.5  +26.8   76.8 ECU.   +0.0 ECU.   2.4  11.50
 5564  +9.6 2.4   0  00    00  11.5  +10.6   30.6 ECU.   +0.0 ECU.   2.3  11.50
 5649  +6.8 2.2   0  00    00  11.5  +10.9   30.6 ECU.   +0.0 ECU.   2.1  11.50
 5546  +6.8 2.2   0  00    00  11.5  +10.9   30.6 ECU.   +0.0 ECU.   2.1  11.50
 5473  +4.1 2.1   0  00    00  15.7  +10.9   30.6 ECU.   +0.0 ECU.   2.2  15.70
 5282  +1.5 2.2   0  00    00  lean0  +11.0   30.6 ECU.   +0.0 ECU.   2.2  lean0
 5159  +1.5 2.2   0  00    00  lean0  +10.9   30.6 ECU.   +0.0 ECU.   2.2  lean0
 5050  -1.4 2.2   0  00    00  lean0  +10.8   30.6 ECU.   +0.0 ECU.   2.2  lean0
 4916  -4.0 2.2   0  00    00  23.7  +10.9   30.6 ECU.   +0.0 ECU.   2.2  23.70
 4816  -4.0 2.2   0  00    00  23.7  +10.9   30.6 ECU.   +0.0 ECU.   2.3  23.70
 4741  -4.0 2.5  14  00    00  23.7  +14.9   53.0 ECU.   +0.0 ECU.   3.0  23.70
 4714  -6.5 2.5  14  00    00  23.7  +17.7   28.6 ECU.   +0.0 ECU.   3.2  23.70
 4668  -6.5 2.5  14  00    00  23.7  +18.9   29.4 ECU.   +0.0 ECU.   3.3  23.70
 4480  -6.9 3.4  98  10    00  16.1  +21.7   43.9 ECU.   +0.0 ECU.   3.6  16.10
 4694  -4.9 3.6  98  10    00  11.5  +19.3   58.3 ECU.   +0.0 ECU.   3.7  11.50
 4662  -4.9 3.6  98  10    00  11.5  +19.0   63.8 ECU.   +0.0 ECU.   3.7  11.50
 4688  -4.9 3.8  99  10    00  11.5  +19.1   64.8 ECU.   +0.0 ECU.   3.7  11.50
 4688  -2.4 3.8  99  30    00  11.5  +19.3   69.2 ECU.   +0.0 ECU.   3.8  11.50
 4688  -2.4 3.8  99  30    00  11.5  +19.5   73.4 ECU.   +0.0 ECU.   3.8  11.50
 4708  +2.7 3.8  99  50    00  11.5  +20.8   71.7 ECU.   +0.0 ECU.   3.8  11.50
 4880  +4.9 3.8  98  50    00  11.5  +22.2   72.9 ECU.   +0.0 ECU.   3.8  11.50
 4952  +4.9 3.8  98  50    00  11.5  +22.3   73.5 ECU.   +0.0 ECU.   3.8  11.50
 4975  +7.6 3.8  98  60    00  11.5  +22.5   74.1 ECU.   +0.0 ECU.   3.8  11.50
 5035  +8.6 3.8  98  50    00  11.5  +23.0   74.2 ECU.   +0.0 ECU.   3.8  11.50
 5065  +8.6 3.8  98  50    00  11.5  +22.5   74.1 ECU.   +0.0 ECU.   3.8  11.50
 5012  +8.6 3.9  99  50    00  11.5  +22.8   75.0 ECU.   +0.0 ECU.   3.9  11.50
 5065  +9.4 3.9  99  60    00  11.5  +22.3   80.2 ECU.   +0.0 ECU.   3.9  11.50
 5376  +9.4 3.9  99  60    00  11.5  +22.2   78.1 ECU.   +0.0 ECU.   3.9  11.50
 5159  +9.6 3.9  98  50    00  11.5  +22.0   87.0 ECU.   +0.0 ECU.   3.9  11.50
 5265 +10.0 4.0  98  60    00  11.5  +21.7   88.6 ECU.   +0.0 ECU.   4.0  11.50
 5491 +10.0 4.0  98  60    00  11.5  +21.6   89.6 ECU.   +0.0 ECU.   4.0  11.50
 5402 +10.0 4.0  99  60    00  11.5  +21.6   86.5 ECU.   +0.0 ECU.   4.0  11.50
 5428 +10.6 4.0  99  60    00  11.5  +21.7   87.3 ECU.   +0.0 ECU.   4.0  11.50
 5393 +10.6 4.0  99  60    00  11.5  +21.8   92.7 ECU.   +0.0 ECU.   4.0  11.50
 5527 +11.0 4.0  98  70    00  11.5  +21.3   89.0 ECU.   +0.0 ECU.   4.0  11.50
 5564 +11.5 4.0  99  70    00  11.5  +21.3   92.8 ECU.   +0.0 ECU.   4.0  11.50
 5509 +11.5 4.0  99  70    00  11.5  +21.9   93.0 ECU.   +0.0 ECU.   4.0  11.50
 5611 +11.5 4.0  98  70    00  11.5  +22.1   89.7 ECU.   +0.0 ECU.   4.0  11.50
 5574 +11.5 4.0  98  60    00  11.5  +22.0   89.8 ECU.   +0.0 ECU.   4.0  11.50
 5678 +11.5 4.0  98  60    00  11.5  +22.2   92.8 ECU.   +0.0 ECU.   4.0  11.50
 5747 +12.1 4.0  98  60    00  11.5  +23.8   94.7 ECU.   +0.0 ECU.   4.0  11.50
 5847 +11.5 4.1  99  60    00  11.5  +23.8   93.7 ECU.   +0.0 ECU.   4.1  11.50
 5777 +11.5 4.1  99  60    00  11.5  +24.2   89.5 ECU.   +0.0 ECU.   4.0  11.50
 5858 +11.3 4.0  98  60    00  11.5  +24.0   66.6 ECU.   +0.0 ECU.   4.0  11.50
 5858 +10.6 4.0  10  00    00  11.5  +25.5   26.6 ECU.   +0.0 ECU.   2.5  11.50
 5583 +10.6 4.0  10  00    00  11.5  +10.9   25.9 ECU.   +0.0 ECU.   2.2  11.50
 5621  +8.4 2.2   0  00    00  11.5  +10.7   25.9 ECU.   +0.0 ECU.   2.2  11.50
 5500  +5.5 2.2   0  00    00  14.1  +10.8   25.9 ECU.   +0.0 ECU.   2.2  14.10
 5527  +5.5 2.2   0  00    00  14.1  +10.9   25.9 ECU.   +0.0 ECU.   2.2  14.10
 5350  +5.5 2.2   0  00    00  21.1  +10.8   25.9 ECU.   +0.0 ECU.   2.2  21.10
 5265  +2.9 2.2   0  00    00  21.1  +10.8   25.9 ECU.   +0.0 ECU.   2.2  21.10
 5299  +2.9 2.2   0  00    00  21.1  +10.9   25.9 ECU.   +0.0 ECU.   2.2  21.10
 5159  +0.0 2.2   0  00    00  lean0  +10.8   25.9 ECU.   +0.0 ECU.   2.2  lean0
 5027  +0.0 2.2   0  00    00  lean0  +10.9   25.9 ECU.   +0.0 ECU.   2.2  lean0
 4930  -2.6 2.2   0  00    00  lean0  +10.9   25.9 ECU.   +0.0 ECU.   2.2  lean0
 4844  -2.6 2.2   0  00    00  lean0  +11.1   25.9 ECU.   +0.0 ECU.   2.2  lean0
 4755  -5.3 2.2   0  00    00  24.0  +11.1   25.9 ECU.   +0.0 ECU.   2.2  24.00
 4681  -5.3 2.2   0  00    00  24.0  +11.2   25.9 ECU.   +0.0 ECU.   2.3  24.00
 4547  -7.9 2.2   0  00    00  24.0  +12.8    1.0 ECU.   +0.0 ECU.   3.0  24.00
 4426  -8.9 3.2  69  10    00  23.7  +18.3   26.8 ECU.   +0.0 ECU.   3.2  23.70
 4438  -8.9 3.2  69  10    00  23.7  +21.3   30.8 ECU.   +0.0 ECU.   3.3  23.70
 4468  -8.9 3.2  69  10    00  22.7   +3.1   35.4 ECU.   +0.0 ECU.   3.4  22.70
 4438  -7.7 3.3  99  10    00  22.7  +23.5   42.2 ECU.   +0.0 ECU.   3.4  22.70
 4559  -7.7 3.3  99  10    00  22.7  +23.0   44.4 ECU.   +0.0 ECU.   3.6  22.70
 4504  -5.9 3.5  99  10    00  13.1  +20.8   52.2 ECU.   +0.0 ECU.   3.6  13.10
 4535  -5.9 3.5  99  10    00  11.5  +17.7   58.1 ECU.   +0.0 ECU.   3.7  11.50
 4510  -3.4 3.7  98  20    00  11.5  +17.8   61.6 ECU.   +0.0 ECU.   3.7  11.50
 4498  -3.4 3.7  98  20    00  11.5  +17.4   66.2 ECU.   +0.0 ECU.   3.7  11.50
 4572  -0.8 3.7  99  40    00  11.5  +17.2   64.0 ECU.   +0.0 ECU.   3.7  11.50
 4535  -0.8 3.7  99  40    00  11.5  +17.4   68.1 ECU.   +0.0 ECU.   3.7  11.50
 4541  +1.9 3.7  99  50    00  11.5  +17.1   68.9 ECU.   +0.0 ECU.   3.7  11.50
 4629  +4.5 3.7  98  50    00  11.5  +17.9   68.7 ECU.   +0.0 ECU.   3.7  11.50
 4553  +4.5 3.7  98  60    00  11.5  +17.9   67.9 ECU.   +0.0 ECU.   3.7  11.50
 4597  +7.2 3.7  98  60    00  11.5  +18.4   69.3 ECU.   +0.0 ECU.   3.8  11.50
 4649  +8.4 3.7  99  60    00  11.5  +19.0   69.7 ECU.   +0.0 ECU.   3.7  11.50
 4662  +8.4 3.7  99  60    00  11.5  +19.0   70.6 ECU.   +0.0 ECU.   3.7  11.50
 4734  +9.6 3.7  98  60    00  11.5  +19.3   67.9 ECU.   +0.0 ECU.   3.8  11.50
 4768 +10.2 3.8  98  60    00  11.5  +19.4   69.9 ECU.   +0.0 ECU.   3.8  11.50
 4761 +10.2 3.8  98  60    00  11.5  +19.7   74.1 ECU.   +0.0 ECU.   3.8  11.50
 4810 +10.2 3.8  98  60    00  11.5  +19.8   73.7 ECU.   +0.0 ECU.   3.8  11.50
 4734 +10.4 3.8  98  60    00  11.5  +20.2   71.7 ECU.   +0.0 ECU.   3.8  11.50
 4728 +10.4 3.8  98  60    00  11.5  +19.6   72.8 ECU.   +0.0 ECU.   3.8  11.50
 4816 +11.0 3.8  98  60    00  11.5  +19.3   76.6 ECU.   +0.0 ECU.   3.8  11.50
 4866 +11.0 3.8  98  60    00  11.5  +19.0   78.4 ECU.   +0.0 ECU.   3.9  11.50
 4810 +11.3 3.9  98  70    00  11.5  +19.4   80.8 ECU.   +0.0 ECU.   3.9  11.50
 4789 +11.3 3.9  98  70    00  11.5  +19.6   79.3 ECU.   +0.0 ECU.   3.9  11.50
 4930 +11.7 3.9  98  70    00  11.5  +19.8   83.2 ECU.   +0.0 ECU.   3.9  11.50
 4960 +11.7 3.9  98  70    00  11.5  +20.0   82.2 ECU.   +0.0 ECU.   3.9  11.50
 4859 +12.1 3.9  98  80    00  11.5  +20.1   84.0 ECU.   +0.0 ECU.   3.9  11.50
 4880 +12.1 3.9  98  80    00  11.5  +20.2   81.5 ECU.   +0.0 ECU.   3.9  11.50
 4923 +12.5 3.9  98  70    00  11.5  +20.5   80.3 ECU.   +0.0 ECU.   3.9  11.50
 5012 +12.5 3.9  98  70    00  11.5  +20.2   83.5 ECU.   +0.0 ECU.   3.9  11.50
 5005 +12.5 3.9  99  70    00  11.5  +19.7   86.7 ECU.   +0.0 ECU.   3.9  11.50
 5020 +12.5 3.9  99  70    00  11.5  +19.7   84.7 ECU.   +0.0 ECU.   3.9  11.50
 5089 +12.7 3.9  98  70    00  11.5  +20.4   84.6 ECU.   +0.0 ECU.   3.9  11.50
 5112 +12.7 3.9  98  70    00  11.5  +18.9   85.4 ECU.   +0.0 ECU.   4.0  11.50
 5065 +13.3 3.9  98  70    00  11.5  +19.3   85.7 ECU.   +0.0 ECU.   3.9  11.50
 5089 +13.3 3.9  98  70    00  11.5  +19.3   85.8 ECU.   +0.0 ECU.   4.0  11.50
 5104 +13.3 4.0  99  70    00  11.5  +19.4   87.0 ECU.   +0.0 ECU.   4.0  11.50
 5058 +13.3 4.0  99  70    00  11.5  +18.5   87.8 ECU.   +0.0 ECU.   4.0  11.50
 5065 +13.3 3.9  99  70    00  11.5  +19.5   85.9 ECU.   +0.0 ECU.   4.0  11.50
 5500 +13.1 3.9  98  70    00  11.5  +19.4   88.3 ECU.   +0.0 ECU.   4.0  11.50
 5128 +13.1 3.9  98  70    00  11.5  +19.6   90.4 ECU.   +0.0 ECU.   4.0  11.50
 5241 +13.1 3.9  98  70    00  11.5  +18.5   86.9 ECU.   +0.0 ECU.   4.0  11.50
 5175 +13.1 4.0  99  70    00  11.5  +19.7   89.4 ECU.   +0.0 ECU.   4.0  11.50
 5159 +13.1 4.0  99  70    00  11.5  +19.7   88.7 ECU.   +0.0 ECU.   4.0  11.50
 5282 +13.1 4.0  98  70    00  11.5  +19.5   93.1 ECU.   +0.0 ECU.   4.0  11.50
 5257 +13.3 4.0  99  70    00  11.5  +19.4   88.9 ECU.   +0.0 ECU.   4.0  11.50
 5282 +13.3 4.0  99  70    00  11.5  +19.5   91.1 ECU.   +0.0 ECU.   4.0  11.50
 5359 +13.3 4.0  98  70    00  11.5  +19.7   89.5 ECU.   +0.0 ECU.   4.0  11.50
 5411 +13.1 4.0  98  70    00  11.5  +20.4   89.6 ECU.   +0.0 ECU.   4.0  11.50
 5420 +13.1 4.0  98  70    00  11.5  +20.3   90.4 ECU.   +0.0 ECU.   4.0  11.50
 5393 +12.9 4.0  99  70    00  11.5  +19.9   93.9 ECU.   +0.0 ECU.   4.0  11.50
 5473 +12.7 4.0  98  70    00  11.5  +20.5   90.1 ECU.   +0.0 ECU.   4.0  11.50
 5491 +12.7 4.0  98  70    00  11.5  +21.1   89.7 ECU.   +0.0 ECU.   4.0  11.50
 5428 +12.1 4.0  98  60    00  11.5  +21.4   93.2 ECU.   +0.0 ECU.   4.0  11.50
 5527 +12.3 4.0  98  60    00  11.5  +21.3   92.8 ECU.   +0.0 ECU.   4.0  11.50
 5555 +12.3 4.0  98  60    00  11.5  +21.3   92.6 ECU.   +0.0 ECU.   4.0  11.50
 5630 +11.9 4.0  98  60    00  11.5  +22.1   92.9 ECU.   +0.0 ECU.   4.0  11.50
 5500 +12.1 4.1  98  70    00  11.5  +22.0   95.9 ECU.   +0.0 ECU.   4.0  11.50
 5611 +12.1 4.1  98  70    00  11.5  +21.8   93.8 ECU.   +0.0 ECU.   4.0  11.50
 5668 +11.9 4.0  98  70    00  11.5  +22.1   90.5 ECU.   +0.0 ECU.   4.0  11.50
 5611 +11.7 4.0  98  70    00  11.5  +21.9   90.6 ECU.   +0.0 ECU.   4.0  11.50
 5698 +11.7 4.0  98  70    00  11.5  +22.1   93.3 ECU.   +0.0 ECU.   4.0  11.50
 5602 +11.7 4.1  69  70    00  11.5  +22.8   54.5 ECU.   +0.0 ECU.   2.4  11.50
I did some logs with my map on but the delay was so long before I was able to get on the gas, that UTI stopped logging in between shifts I'll get proper logs after work.
Eric
*edit* One thing I noticed along with someone who PM'd me, is that the load column is showing 10% off throttle in the original log. My stock ecu log shows 0% load. Pretty odd...
Old 04-19-2006, 11:05 PM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Your BOV is not working correctly
Code:
The BOV should have vented at this pioint but it did not. It's lucky that the UTEC kept fueling.
I suggest you check your BOV. It's either broken, sticking or the vaccum line is blocked.
mick_the_ginge is offline   Reply With Quote
Old 04-20-2006, 10:16 AM   #9
ElmnTfrliF
Member#: 72708
2005 STi
2009 CBR600RR
Code:
Are you sure? The car seems to run 100% fine with the utec on map position 0. I have tried three different BOV/BPV's (GFB Hybrid, Stock, WORX adjustable) I also changed out the vacuum line for the valve. I guess I'll snoop around the engine bay some more...
Old 04-20-2006, 04:59 PM   #10
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Did his timing map seem a bit off in the 70-100 load columns? There were a few 6-7 degree jumps.
Also, why aren't you reaching 80, 90, or 100 load %?
kingtut12 is offline   Reply With Quote
Old 04-20-2006, 05:13 PM   #11
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I just think if you have let off the throttle that much (snip of log I posted) then the BOV should have vented and your boost should have dropped off.
Old 04-20-2006, 05:18 PM   #12
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
The UTEC forces itself in control at about 5250 RPM as I remember it. This is why the UTEC reports 10% yet you have 0% TPS. You are above the auto crossover.
weird problem with throtttle sticking WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-22-2002 12:49 AM
hmmm weird problem with A/F install Impreza25RS Normally Aspirated Powertrain 3 11-25-2001 09:21 PM
('93-'01) Weird problem when I try to start my car Dobes Impreza Forum 13 09-16-2001 09:49 PM
Any weird problems with the Website? Nick General Forum Archive 41 01-31-2001 10:53 AM
Weird problem, radio wont come on BoomerRS Car Audio, Video & Security 3 08-28-2000 11:30 AM
