Old 04-15-2006, 10:26 PM   #1
neptune
Member#: 60093
2010 Outback 2.5i
Gold
Unhappy Can't inflate tire
I got my summer tires mounted today and noticed that one of them can't be inflated.
Everytime I try to put air in it, the tire ends up losing more. I think there might be something wrong with the valve stem? Anyone know what could be causing this and how I might go about fixing it?
I plan on taking it to a shop on Monday... how much am I looking at for that?
So far, I've tried two tires and only one seems to have this problem. I tried three different gas stations and four different pressure gauges.
Please let me know. Its essentially undrivable right now because of the low pressure.
Thanks!
neptune is offline   Reply With Quote
Old 04-15-2006, 10:34 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Well if it's coming out the valve stem you should be able to feel/hear the air escaping. If it is the stem might just not be tight, or there could be something wrong with it.
How quickly is the air coming out? If it's leaking rapidly it should be fairly easy to find where it's going.
If these are used tires there may be a screw or nail in the tire someplace, or possibly there might have been one that came out and left a hole.
Old 04-15-2006, 10:35 PM   #3
stanton
Member#: 21508
'03 WRX Wagon
Hopefully it is just the valve. Put some air in it, then try the tried and true method of wiping some spit (or soapy water) over the valve stem to cover the hole completely. If it's leaking, it will make a spit bubble. If it's not leaking, the spit should stay there for a while. With a leak this bad, it will be very obvious.
Did any dirt (or something) get in between the tire and the rim? Did you somehow get a puncture in this tire?
stanton is offline   Reply With Quote
Old 04-16-2006, 02:13 AM   #4
ChrisL2
Member#: 1444
I had a tire like that. Held air pretty good until I tried putting air in it. It was just the valve stem. Discount Tire replaced it for at no charge, even though I hadn't gotten the wheels/tires from them.
ChrisL2 is offline   Reply With Quote
Self-Inflating Tire Technology Triumphs At The 2009 Tire Technology Awards For Innova AVANTI R5 Non-Subaru News & Rumors 5 02-19-2009 09:20 PM
New “Smart” system automatically detects & fills under-inflated tires with air. NYCshopper Non-Subaru News & Rumors 23 05-25-2007 03:36 AM
Anyone use tire inflator-in-a-can for emergencies? Cindy H Brakes, Steering & Suspension 10 08-08-2002 11:08 PM
What to inflate tires to for different conditions desiwrx02 Newbies & FAQs 3 07-08-2002 09:02 PM
keep your tires inflated!! RaceCarRiot Brakes, Steering & Suspension 3 09-01-2001 02:00 PM
