Old 10-04-2001, 01:12 AM   #1
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Question Help - do I have all my parts?
I bought this kit along w/ a TECII from IANBROGLIE. It arrived last weekend all nice and packed up. I'm going to South Cali this weekend so my friend Eric and I can install the whole thing. Much thanks to EMPREZYA for hooking me up w/ a tranny cooler. Will all this work for my MY00 Auto 2.5RS? Am I missing a major component/minor component? Critical bolts? Oil lines/fuel lines? If you guys could give me a hand I'd be seriously grateful
Brydon
aussiebrydon is offline   Reply With Quote
Old 10-04-2001, 01:17 AM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
What kit is that?
If it's a Minnam/Technik stage 2 kit you'll probably need to fab a new downpipe and/or vent the wastegate to atmosphere because it hits the auto tranny.
Good luck!
Keiho is offline   Reply With Quote
Old 10-04-2001, 01:59 AM   #3
MPREZYA
SCIC
Member#: 85
Ummm I am guessing you have a seperate pic of the tec II items like the control unit wiring harness, plug wires, and various sensors, injectors (if you have em) . You may want to post that on Shiv's board www.vishnuperformance.com as he can help you with any other items like a fuel pump you may need.
Rich
MPREZYA is offline   Reply With Quote
Old 10-04-2001, 02:50 AM   #4
Kcz
Member#: 2038
2000 RS-T
Silverthorn Metallic
I wold be worried about about the small peices like T fittings and small adapters like that. Not too hard to find, But make sure Napa or Pep Boys is open when you do the install.
Kcz is offline   Reply With Quote
Old 10-04-2001, 02:51 AM   #5
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
I don't see an oil or feed line.
Can you show some more pics of the up pipe?
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-04-2001, 03:40 AM   #6
Andrew
Member#: 1170
2005 STi
new oil pan unless you like to tap your own.
Andrew is offline   Reply With Quote
Old 10-04-2001, 09:36 AM   #7
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
you need oil and coolant lines, vaccume, oil and coolant fittings, gages, hose clamps, etc
STiShawn is offline   Reply With Quote
Old 10-04-2001, 03:04 PM   #8
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Default Thankyou
<sniff> it just makes me so emotional, everyone being so helpful, you guys are so wonderful
No seriously thankyou very much guys
Old 10-04-2001, 03:08 PM   #9
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Forgot the oil pan like was pointed out, you can use the banjo style oil line (See ISR Performance), but that has been debated over its usefullness. Get a pan from Ludespeed.
Old 10-04-2001, 06:36 PM   #10
gromit
Member#: 9426
Looks like an ASR kit. You might want to make some brackets to support the turbo and the downpipe. Have someone weld a bracket on the downpipe near the turbo and one downstream where the factory hanger is. Whatever you do, do not use the bolts on the back of the turbo (intake side) to hold a bracket. The genius I bought my kit from did and it stripped two holes in the aluminum housing. Also, trial fit the piping to make sure the silicone hoses fit; I had to buy my own. You might want to consider a clutch before you put everything in. Good luck!
gromit is offline   Reply With Quote
Old 10-04-2001, 06:38 PM   #11
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Rich
Thanks bro, I'm pretty sure that I have all the parts, it was still in the original box 'cause the TECII was never installed on Ian's car.
I'm picking up a Ludespeed oil pan from Tom, anyone know where I can get a down-pipe for this kit?
Old 10-04-2001, 07:43 PM   #12
brogliei
Member#: 8650
2002 WRX - Sedan
White (sometimes)
Just caught the post. Looks like you have the oil line issue covered since you are getting a tapped oil pan. The kit is an ASR stage II (sent you an email). You will probably need some T's for vacuum and pressure lines also.
Auto tranny is that wide? Bummer, I did not know about that. I guess you could have a quality muffler shop copy the down pipe and make the necessary changes during the bending process.
Does anyone know where the ASR down pipe is to wide for the RS auto tranny? Maybe you could have the down pipe bent at a muffler shop? (if it is a small change) Just a thought.
Peace and good luck
Ian
brogliei is offline   Reply With Quote
Old 10-04-2001, 07:49 PM   #13
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
wow, this's awesome. In the space of an afternoon, I have everything taken care of. Thankyou all very much for helping me out, especially Ian for getting back to me in only hours. You guys rule!!!! I'm very happy w/ everyone here being so cool about this - will post pics when I'm done
Brydon
Old 10-04-2001, 08:02 PM   #14
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Thumbs up
thanks again guys. More Q's. Where should I tap oil for the turbo? I'm getting the Ludespeed oil pan so the out is fine, but I don't know where to get the oil from to put into the turbo.
Also, what kind of upgraded fuel pump should I use, any recommendations? I have Shiv's TECII so I don't want to starve my stock fuel-pump!
Last question, what's a good BOV for this setup do you think? (ASR Stage II turbo kit, TECII engine management, MY00 RS running 6-7lbs boost to start, 9-10 later)
Old 10-04-2001, 08:16 PM   #15
MPREZYA
SCIC
Member#: 85
www.imprezars.com use the instructions from there as a basis for install. HKS SSQ BOV that thing rocks... 'nuff said
Old 10-05-2001, 12:13 AM   #16
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Anyone know of a good racer parts shop in Southern California I can get good service at? Need the HKS BOV that Imprezya mentioned, etc. I'm going to be in Ontario (Corona actually) area, any ideas gang?
Old 10-05-2001, 12:20 AM   #17
kaos200
Member#: 2692
that kit has an HKS BOV, not the SS, but a base model that works for <10psi
How far are you from the Irvine area?
I can help you install it...
kaos200 is offline   Reply With Quote
Old 10-05-2001, 12:27 AM   #18
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
go to Gourmet Garage..they are in rosemead, (626)443-6858...........and ISR in Huntington Beach.. both less than an hour from Corona. and both really cool.
PEACE
StarDogChampion is offline   Reply With Quote
Old 10-05-2001, 12:59 AM   #19
MPREZYA
SCIC
Member#: 85
Old 10-05-2001, 03:07 AM   #20
TaiChih
Member#: 3467
1998 Dinan3
Bleck
How much did you pay for all that?it seems to be missing alot. NO catylytic converter, no flex pipe, no downpipe bracket, gaskets?what about guages? got a new clutch? I bought a used technik stage II with a few missing pieces that cost me an additional $2000 in misc parts and guages, etc. GOOD LUCK!
TaiChih is offline   Reply With Quote
Old 10-05-2001, 12:39 PM   #21
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Oh hey thanks for the concern dude, I paid $1,500 for this, it's an ASR Stage II turbo kit w/ Turbonetics t3/t4 hybrid and Turbonetics piping. My buddy is going to help me install it, so we're going to fabricate the brackets, and this thing has all the gaskets on it already. I actually bought a TECII and all the gauges from the same guy, so my total for the kit, turbo, TECII, gauges, and gauge pod was $4,200, I just didn't show all the parts in the picture. My car is Automatic, so I'm just going to use Emprezya's auto tranny cooler.
I'll let you guys know how it all went
Do I have all my Coilover parts ? rentforsale Brakes, Steering & Suspension 11 09-18-2009 12:17 PM
Going to do timing belt, do I need all these parts? orndog South East Region Forum 66 04-07-2009 09:52 AM
sti tranny --> 07 wrx ... do I have all the parts? Bad Noodle Newbies & FAQs 5 01-10-2009 06:19 PM
The I sold my car and I have all these parts left over thread (56k warning) anfernee NESIC Private Classifieds 46 10-31-2008 12:46 PM
I think i got all my parts for a stage 4. Have another $375, do i need anyting else? Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 12-14-2003 06:33 PM
