Old 10-04-2001, 01:47 AM   #1
SCOOTAE
Member#: 10735
1995 2.2L COUPE
BRIGHT ASS RED
Question turbo'ing a 2.2l
I was wondering if it is possible to turbo my 95 2.2 coupe, and if yes what would I need.
SCOOTAE is offline   Reply With Quote
Old 10-04-2001, 03:16 AM   #2
PERRIN
NASIOC Manufacturer
Member#: 6776
I can get you an older WRX engine for $1000 or so. then get you a Haltech ECU, exhaust and you can use your existing tranny. All of this would cost less than most of the aftemarket turbo systems. Around $3500 or less.
This would give a low compresion, more durable engine
PERRIN is offline   Reply With Quote
Old 10-04-2001, 04:54 PM   #3
SCOOTAE
Member#: 10735
1995 2.2L COUPE
BRIGHT ASS RED
ANYONE ELSE???????????
Old 10-04-2001, 04:56 PM   #4
SCOOTAE
Member#: 10735
1995 2.2L COUPE
BRIGHT ASS RED
Couyld I modify a 1.8 L turbo to work? or change heads and use a 2.5 turbo?
Old 10-04-2001, 05:39 PM   #5
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
You should really look through the threads for at least a few days and you'll see others have asked the same question.
Yes you can turbo it, will it work? You can make it work. What will you need? depends on the boost you want. Click on the little www icon under this thread for some more info.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-04-2001, 08:40 PM   #6
AZ-GT
Member#: 192
2011 WRX
WR Blue
Hmm, check the other turboing a 2.2l post. Forced Air Technologies (see links) has turboed one and it's very impressive. My friend owns it. Good luck.
AZ-GT is offline   Reply With Quote
WRX catback on 2.2l OBS catpipe...the weld broke :| Quick dia ?s kaisersouse Normally Aspirated Powertrain 0 06-01-2010 08:20 AM
2.5 injectors in a 2.2l SOHC OBS? cams for 2.2l? kaisersouse Normally Aspirated Powertrain 3 04-02-2006 09:10 PM
Any 2.2L internal for turbo's? Homemade WRX Normally Aspirated with bolt-on Forced Induction Powertrain 16 04-02-2003 06:57 PM
00 2.2L vs. 96 2.2L, where'd the power come from? 96Lconversion Normally Aspirated Powertrain 15 01-19-2001 12:32 AM
'95 2.2L engine same as '97 2.2L? I need the part quick! chyisan Normally Aspirated Powertrain 1 12-22-2000 03:33 PM
