Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 04-15-2006, 10:37 PM   #1
Member#: 69063
2000 2.5 RS
Blue Ridge Pearl
Default What else to replace while doing timing belt replacement?
Besides the timing belt and water pump and water pump gasket is there anything else I should replace while I'm in there?
Car's got a 106K.
the_glassman is offline   Reply With Quote
Old 04-16-2006, 02:01 AM   #2
Member#: 54525
2000 ej20g rs
blue ridge pearl
check the oil pump and the front seal, alot of the oil pumps develop leaks over time. It you take the pump off look at the back, theres like 3 screws back there, make sure they haven't backed out, that will cause a leak.
damonmlime is offline   Reply With Quote
Old 04-16-2006, 08:46 AM   #3
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Probably check/replace the radiator hoses and thermostat while they are easily done.
lakepop is offline   Reply With Quote
Old 04-16-2006, 11:58 AM   #4
Member#: 1134
2010 Legacy GT Ltd.
The timing belt tensioner. Mine actually blew at 62K miles I think it was (I'm at 129K now), so I had the belt swapped while they were in there. So sort of a backward job from yours, but the same idea.
Siper2 is offline   Reply With Quote
What is a fair price for timing belt replacement? mizh New England Impreza Club Forum -- NESIC 28 03-05-2015 07:46 PM
How to hold cam gears...timing belt replacement ratso Normally Aspirated Powertrain 13 12-20-2008 08:33 PM
Water pump replacement at second timing belt replacement? doobie Service & Maintenance 1 10-19-2007 12:12 PM
Going to Philly for a weekend to see the Red Sox play, what ELSE to see while there? 03WRXMA Off-Topic 51 06-08-2005 05:52 PM
Things to replace while doing timing belt? lag Legacy Forum 4 04-17-2004 10:28 PM
