Old 04-17-2006, 11:52 PM   #1
mathetes
Member#: 106238
Default Will 04-06 Sti steering wheel fit 02-3?
As stated in the topic. Will the 04-06 Sti wheel fit into the bugeyes w/o modifications? Plug and play?
mathetes is offline   Reply With Quote
Old 04-18-2006, 12:44 AM   #2
ten80
Member#: 53625
00 16' FXT
Make sure the airbag connector that plugs into the car is the same- I know the plug in back of the airbag itself is different.
ten80 is offline   Reply With Quote
Old 04-18-2006, 09:15 AM   #3
fourdegrees
Member#: 49662
2005 FEALing fine
Ten80 is correct. You will need the roll connector from an 04-05 car to make it fit. This wires into your steering column, and allows you to have the same airbag connector as the steering wheel you are using. If you are really lucky (supposedly during the 03 model year they switched to the new style of airbag connector) you may not have to switch the roll connectors.
fourdegrees is offline   Reply With Quote
Does a 06 STI steering wheel fit in a 02 WRX sedan? vicdeng Interior & Exterior Modification 1 06-23-2007 08:26 PM
06 sti steering wheel fit on 04 sti??? turbofed Interior & Exterior Modification 1 06-05-2007 08:53 AM
06 Sti bbs wheels fit 02 BE? ttatsumi Legacy Forum 6 11-09-2006 04:18 PM
Will 04-05 STi steering wheel fit on 02 WRX w/o modification? txl146 Interior & Exterior Modification 10 04-10-2005 12:06 AM
Will a 2004 STi steering wheel fit on a GC8? Chocobo Interior & Exterior Modification 3 08-29-2003 02:17 AM
