04-16-2006, 12:57 PM | #1 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
My Current Build
Check out my site at http://www.white25rs.com for more up to date information.
Previous Build-
Jeff S. said the 110 tune should most likely work well on 104, meaning either : 1- more power could have been pulled out of the fuel but wasn't out of concern for my transmission or 2- the turbo was maxed out and less octane wouldn't have mattered. I took it to the strip, and pulled a whopping 14.7 @ 108.56. I blame myself 90% and the Link Plus 10%. My 60' was 2.8. My trap speed should have been higher despite the crappy time. The car was boosting 2-3 psi less than it should have been. I think altitude and weather made the difference. I could feel the drop in speed, so I checked the datalog, looked on my conversion mpa to psi, and noticed the boost drop. I never fixed it before I was done racing, as I got I think 4 runs in that night. Since then I have practiced my launching and yeah...now I have a really good routine down and it launched like no other. But 342 wasn't enough for me... Current Build-
4/18- I ordered a new black loom kit...much to the delight of fellow NASIOC'ers. Black it was, and black it shall be again. Time to go back to Ellensburg, later.
Last edited by White 2.5rs; 10-08-2011 at 01:33 AM. Reason: Didn't like what it said? |
04-16-2006, 04:09 PM | #2 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
Do yourself a favor and buy a decent chop saw. It will make your life 100x easier.
04-16-2006, 05:20 PM | #3 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
are you cutting Aluminum or SS? If you are cutting Aluminum get a bandsaw, you will save yourself a TON of clean up on the cut afterwards.
Ben |
04-16-2006, 07:07 PM | #4 |
Member#: 39936
Stainless-I have that same die grinder you do Ben, with a ...5" ? stainless cutting disc
also i have a flap sander attachment and a grinding wheel |
04-17-2006, 09:39 AM | #5 |
Member#: 13617
4.5", if you are doing SS then do what Drac said and get a chop saw for like 100 bucks, it will make your life much easier, you can do straight cuts and it will save you on cleaning up a lot of burrs. Do you have a bench grinder? If not you will want one with a SS wire wheel also, that is if you are doing all the prep work. the grinder will be about 30 and the wire wheel is prob 10.
Ben |
04-17-2006, 10:29 AM | #6 |
Member#: 39936
It'd be nice to have an extra 250-350 laying around for those tools, but no can do.
I have access to a grinder/chop saw/belt sander/band saw <horiz, so it kinda sucks> at my dads shop, where I normally work on the car. I just got the boot out of there a while back because they need the space my car normally takes up. |
04-17-2006, 08:37 PM | #7 |
Member#: 90396
NWIC
Vehicle:2005 Legacy 2.5i Brilliant Silver Metallic |
What is the thickness of your headgaskets?
I'm doing a similar setup w/ an RS block (open deck vs semi-closed) Forged wiseco's, eagle rods, balanced crank, new main bearings, the SOHC heads with upgraded valvetrain (minus the valves themselves) ala TWE, and cobb 'spicy' cams (they say NA only, but after talking with a cobb tech he said many people run them on Forced Induction apps with good results). Anyways, I plan on using STi headgaskets vs RS ones, the RS ones are about 2.5 times thicker than STi headgaskets, how thick are the cometics your using? Thanks, Nick |
04-17-2006, 10:34 PM | #8 |
Member#: 39936
I really don't remember...TWE told me to go w/ what they recommended, and I did...I never saw the specs... .060 rings a bell? but I don't know if that has to do with something else
04-17-2006, 11:59 PM | #9 |
Member#: 90396
NWIC
That sounds about right... RS is like .051 or .056 forgot which, but I know STi is .021.
I don't think it makes a huge differance either way since your headgaskets are aftermarket high performace ones, but as far as the ones from the dealership I figured the STi had to be better because they are made of differant materials, and thinner for less possible moving around. ARP Head studs are SPENDY though!! 230 bucks for some bolts!? You know factory STi blocks hold together fine with factory studs! And if the block goes, its probably not because of the studs, Nick |
04-18-2006, 12:34 AM | #10 |
Member#: 39936
I just followed a lot of what TWE told me. I trust them, I've spent 4-5gs with them, and they told me they use ARPs on all of their high HP setups...same with a lot of tuners...I figure if I have that much $ in head gaskets, spending a little more in bolts to make sure nothing happens is justified.
04-18-2006, 01:09 AM | #11 |
Member#: 20508
Vehicle:1998 Red Wagon New Turbo Project... |
cheap
Harbor Freight $50 chop saw is THE best $50 I've ever spent in my entire life.
Buy one. People give HF a bad wrap, but at $50 you can not go wrong with this one. I haven't broke mine yet and I ABUSE it. Cutting 1/4" plate with bungies to keep it cutting unattended |
04-18-2006, 01:19 AM | #12 |
Member#: 39936
I guess I'll pick it up
Thanks CDW |
04-18-2006, 06:56 PM | #13 | |
Member#: 93364
RMIC
Vehicle:1998 '98 Impreza RST '14 BRZ |
How much are you looking at for a usdm six speed? I know you need a lot of stuff and I was wondering how much a whole swap would be. Your set-up looks sweet btw |
04-18-2006, 08:17 PM | #14 |
Member#: 39936
I was planning on spending 3500 on the transmission/diff **** <still need to know what I need > and around 1400 on a clutch <Tilton ceremetallic>
04-20-2006, 08:32 PM | #15 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
why use a RRFPR ? .. just seems that it would make it more difficult to tune
04-20-2006, 09:00 PM | #16 |
Member#: 39936
well its a FPR with 1:1 raising on it, i dont know if thats the proper term, maybe i should change it to say fpr instead of rrfpr
04-20-2006, 09:14 PM | #17 |
Member#: 39936
4/20- I ordered the Harbor Freight chop saw.
My cheapness set in and I googled "Harbor Freight Coupon" and came across a coupon for not only 5 bucks off, but a free 12 piece file/rasp set...couldn't pass that up Last edited by White 2.5rs; 04-21-2006 at 10:35 AM. |
04-21-2006, 10:39 AM | #18 |
Member#: 39936
4/21- I made an apointment with a welder that has done some work for me in the past. Monday I take the car in for custom end tanks, weld my turbo bracket I made, hopefully weld the uppipe in place, and mount the intercooler. If this guy is as cool as he the last couple times I've gone to him, I don't think I'll pay more than 200 bucks.
Heres a pic of my oil feed line. One fitting will be removed, and it will be tightened down so it will be a little shorter. I know it looks somewhat ghetto, but that whole thing, with the extra T for checking my oil pressure, and the oil filter from FP, was only like 105, as opposed to the standard 75 dollar line. |
04-21-2006, 03:22 PM | #19 |
Member#: 39936
Hmm...I basically got fired today for being too stupid...so this job is going to take a ****ing lot longer...
05-07-2006, 11:13 PM | #20 |
Member#: 39936
I found some fuel injectors (96 lb/~1000CC) from PSI187, who after paypal finishes sending me my money!, I'm going to pay and have them sent to RC for flow testing. I also got my chop saw (a beast, thanks guys) and cleaned up the garage a little.
I'm also done organizing and stripping the wires to put back onto the original ECU connector clips for the hydra once I get some money/a job. That is all |
05-09-2006, 10:08 PM | #21 | |
Member#: 20508
05-10-2006, 01:40 AM | #22 |
Member#: 39936
the GT35R uses a different setup than the standard banjo bolt
consider this feed line to be about 25 bucks off the shelf because that filter was around 75 Alex |
05-10-2006, 02:22 PM | #23 | |
Member#: 81633
Vehicle:'98 RS-T Blue |
My 2¢ |
05-10-2006, 03:26 PM | #24 |
Member#: 177
NWIC
after reading your "Current Build" why do a aem WB vs a hydra WB? auto tune is nice
05-10-2006, 04:03 PM | #25 |
Member#: 39936
I like having a gauge displayed constantly so I know if something is up.
I think the auto tune is like 400 dollars on top of the 300 dollars for the wideband, isnt it? |
we might as well start now, pussification of christmas----err, holiday? | Meat Supply | Off-Topic | 25 | 10-27-2008 11:28 PM |
Sleeping might very well become a thing of the past... | Hazdaz | Off-Topic | 22 | 03-05-2006 10:49 PM |
As Paul Harvey says, "and that's, the REST of the story" | MK19_ | South East Region Forum | 10 | 03-09-2005 11:02 PM |
hey mv's on a roll, might as well join in | skimmilk68 | Southern California Impreza Club Forum -- SCIC | 7 | 05-27-2004 08:33 PM |
getting the rest of the crap out of my garage. | steve_d | South East Region Forum | 5 | 02-09-2004 05:33 PM |
