Old 10-04-2001, 09:58 AM   #1
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Thumbs up Finally got the unichip installed with the new map
OMG!!!!!!
My little automatic runs like a raped ape!!!
Couple things to note:
For automatic owners, a new version of the piggy back board will be released soon to help accomodate us. There was one wire actually missing that passed through a signal to the TCM. This resulted in an annoyingly fast flashing "AT OIL TEMP" light, a CEL (1711: torque signal sensor 1) and a rather interesting sensation while shifting at high speed . Our short term fix was to remove the wire from my stock connectors and plug it into the unichip harness. Worked like a charm.
After about 100 miles of driving last night in various conditions the car really started to come onto it's own...
Setup the trusty type-1 to do a prelim 0-62MPH (100KPH) test and it busted out:
4.64 seconds
EDIT: launch conditions were 4200RPM (stalled)
Hell... even give 2/10th for error.... (which historically has been +- 1/10th up to this point)
And this is running a "conservative" vf-22 map.
Here are some specs at time of installation
Full tank of Mobil 93 with GTA fuel enhancer (2oz)
64 degrees ambiant air temps
124 degrees trans temperature
185 degrees water temperature
43 PSI fuel pressure
10895 miles
My mods at this point:
Stock automatic internals (haven't sprung for the hydrovalve body yet)
Stock fuel injectors
Pro-torque street/strip setup converter
Amsoil synthetics in diffs/trans
K&N drop in with hacked air box
Walbro 280L/HR fuel pump
Ultimate-Racing Up-pipe
BPM TB GT exhaust
IHI VF-22
MAX boost 16.1 PSI (no tappering on my tune BTW)
Datasek UNICHIP "conservatively" tuned by Mark McGovern at TurboXS
NOTES: not even anything more then a slight glow from the knocklink at 120 MPH.
EGT's at WOT at 100MPH 1410F
A/F at WOT at 100MPH at about 11.3:1 (calculated off of (narrowband) O2 voltage via OBD2)
Part throttle cruise held egts at 1310F at 65MPH
MAX part throttle ignition advance 35.2 degrees
Final tune will be setup at 53 PSI, allowing final A/F adjustability via fuel pressure to compensate for temperature and humidity.
Finally, I would guess that the rich A/F's at 16PSI on stock injectors are a big part of the GTA fuel enhancer. Makes the extra $.83 per tank worth it.
Hope that helps you auto guys...
In the next week or so (once the dyno is setup) I'm heading out there for the shake down sessions. Then it's off to the track.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 10-04-2001, 10:12 AM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
WOOHOO! Way to go man...
BTW...how did you calculate this?
JenisonWRX is offline   Reply With Quote
Old 10-04-2001, 10:16 AM   #3
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Got the rear sensor voltage and compared it to a spredsheet I have that maps voltage to A/F (not NEARLY as good as a wideband unit.. but it gives a damn good approximation)
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-04-2001, 10:25 AM   #4
JenisonWRX
Member#: 6049
02 WRX & 99 RS
You've got mail
Old 10-04-2001, 10:37 AM   #5
Cjchaps
Member#: 3181
07 Rav4
Default Re: Finally got the unichip installed with the new map
Which dyno are you talking about?
Originally posted by RiftsWRX
OMG!!!!!!
Jorge (RiftsWRX)
www.ProjectWRX.com
Cjchaps is offline   Reply With Quote
Old 10-04-2001, 10:41 AM   #6
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Mark's dynopac is on the plane, and most likely on a truck to MD by now. ETA was late this week
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-04-2001, 10:53 AM   #7
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Here is that spreadsheet (since some have asked for it already)
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-04-2001, 11:10 AM   #8
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Thanks Jorge!
I'm curious - with your new found power...how did the automatic react? shift points change or anything?
Old 10-04-2001, 11:17 AM   #9
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Nope... since the unichip doesn't affect the TCM (which hopefully something will come out for that later on) the points and characteristics are all the same....
Just gets there a butt load quicker
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-04-2001, 11:38 AM   #10
Imprezd
Member#: 3357
Sweet... man...
I feel like the TurboXS stepchild
Pray for my WRX... she's in the hospital
Imprezd is offline   Reply With Quote
Old 10-04-2001, 11:50 AM   #11
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Default not trying to get off topic... but.
Dude!!! Did I miss something? What happened?
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-04-2001, 11:56 AM   #12
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Thumbs up
Excellent Jorge - beter save up for some tranny work
rao is offline   Reply With Quote
Old 10-04-2001, 11:57 AM   #13
Keith
Member#: 191
2012 J train
Brown
ahhh good info..egts, temps, mods... Great post!! thanks for all the info
Keith
Keith is offline   Reply With Quote
Old 10-04-2001, 11:58 AM   #14
Imprezd
Member#: 3357
Lets stay tons of misfire codes and ... rough idling... could be alot of things... even a slipped timing belt
yes... she's in the hospital as of today...
Old 10-04-2001, 12:01 PM   #15
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Thanks guys!
Imprezd: I'm so sorry dude that blows the big donkey! Let us know what goes on!
Always look at it on the bright side... if it was the belt, now is the time to spring for the STI one!
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-04-2001, 12:01 PM   #16
Imprezd
Member#: 3357
Oh yeah not to mention the turbo is leaking oil from behind the IC.
Old 10-04-2001, 12:02 PM   #17
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Time to throw that PE in!
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-04-2001, 12:14 PM   #18
Imprezd
Member#: 3357
Talking
so how's that beast of your... when you taking it to the track again?
Old 10-04-2001, 12:28 PM   #19
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
I think everyone who has actually installed the TurboXs unichip on their WRX has been very very happy - - that Mark is a great tunner !!!!!!!
alfriedesq is offline   Reply With Quote
Old 10-04-2001, 12:39 PM   #20
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
yep!!! gotta agree on that one. Especially for an "at the hip" shot at the prelim map.
Imprezd: once I get back from Mark's I'll do a formal set of runs at GLD (where I've done all my runs but one up till now)
I'd easily anticipate high 12's once it's setup (why not... everyone else does hehe)... I'm happy... from 16's down to 12's for less then 30k total investment!
EDIT: total investment including the car, that is
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-04-2001, 07:30 PM   #21
Dolphino
Member#: 8009
2002 WRX Sport Wagon
WR Blue (Automatic, Baby)
Bump for ya...
Good news, Jorge!
Eric
Dolphino is offline   Reply With Quote
Old 10-04-2001, 08:06 PM   #22
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
Great news. Now all we have to do is get the software and start tuning this stuff ourselves... I cant wait to go for a drive(if youll give me one)
later
-nick
Redline8k is offline   Reply With Quote
Old 10-05-2001, 01:37 AM   #23
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
hehehe anytime bud!
UPDATE: as more and more miles are going on I can tell that the computer is still dialing itself in. Drivability is improving rapidly, and top end performance is coming on better and better.
They are right about that... the unichips do help the self-learn of the car happen faster
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 10-18-2001, 10:18 PM   #24
enphorcerWRX
Member#: 8030
Platinum Silver Wagon
Jorge, can you explain the difference if you just replace your VF22 back with the TD04. I see that as a single expensive mod, is it really worth it. I read tons of stuff about better flow and efficiencies, does this relate to the real world in your experiance. Lets say you go with just the TurboXs stage 1 and a VF22. Would I need a full exhaust to get the VF22 happy?
I understand that mods are best as a sum of thier outputs working together to be effective. I'm trying to come to a best-case scenerio with another $1000 here...
What do you think about this:
txs stage 1 (mapped for the new turbo of course) - own already
vf22 - the big question
torque converter mod - Fighting for budget vs. VF22
up-pipe - will get, haven't decided which one
CAI - own already
cool rims - undecided, not in this budget anyway
your consultation fee - freebie?
Thanks!!
enphorcerWRX is offline   Reply With Quote
Old 10-19-2001, 01:24 AM   #25
GDA
Member#: 4324
02 GDA
Platinum
hey jorge-
any negative side effects with the GTA fuel enhancer. It seems like its really worth it at and additional $.83 a tank!!
I think that it might come in real handy for me in CA with our lovely 91 octane that way the unichip doesnt have to be detuned as much, lol.
let me know, im thinking of picking up the 1 gallon box of it.
thanks
EJ20WRX
GDA is offline   Reply With Quote
Finally got a few pics of the new G-Ride STI RAGE Texas Impreza Club Forum -- TXIC 92 12-15-2010 11:07 AM
Finally got around to install my coilovers/DP/intake/tune lateralus1082 General Community 23 03-25-2008 07:43 PM
FINALLY got EGT gauge installed avatar382 General Community 1 08-25-2005 06:49 PM
Finally got these rices installed (56k beware!!) thucydides Vancouver Impreza Club Forum -- VIC 32 06-25-2004 05:19 AM
Finally got some mods installed! DR EVYL North West Impreza Club Forum -- NWIC 11 07-02-2003 02:29 PM
