Old 04-16-2006, 08:13 PM   #1
DickWRX
Member#: 60590
Default Helix cams,people whu run them opinoins please!
Hey
I am am building a new motor, I am going with EJ257, P&P WRX heads along with cams. Looking @ the price of Helix they cannot be passed over,I did a search but all I got is bitching about the packing.
I would like to get feedback from people who run them. Are they true 264 or just labeled 264. Are they ok to use or should I just save up and go with DPR or cosworth?
Thank you
Rich
DickWRX is offline   Reply With Quote
Old 04-16-2006, 08:44 PM   #2
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
Originally Posted by DickWRX
Hey
Thank you
Rich
i will let ya know pretty soon. i to am running a modded 2.5l with p&ped heads with raduis grinds,and 264 cams. i do know they are true 264 cams
sonic rx is offline   Reply With Quote
Old 04-16-2006, 08:52 PM   #3
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
purty
jigga is offline   Reply With Quote
Old 04-17-2006, 01:27 AM   #4
02Toyowrx
Member#: 56520
True 264.... this phrasing does not make sense.. its either 264 or not.
264 degrees of duration, 272 degrees of duration, or 280 degrees of duration..
Dealing with the JDM/Euro market cams are measured at .010"
In the US most cam grinders measure cams at .050" which is more accurate of a number.
So although a cam with the duration measured at .010" and has 264 degrees of duration, if this same cam was measured at .050" the duration would approx be about 225 degrees (if you are speaking directly of subaru turbo cams).
02Toyowrx is offline   Reply With Quote
Old 04-17-2006, 02:39 AM   #5
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
there is this post ...
http://forums.nasioc.com/forums/show...9&postcount=43
this thread:
http://forums.nasioc.com/forums/showthread.php?t=954775
this post:
http://forums.nasioc.com/forums/show...0&postcount=14
contained in this thread:
http://forums.nasioc.com/forums/showthread.php?t=981874
i am very happy with my helix cams. gobs of midrange power, which is where i want it.
banzai is offline   Reply With Quote
Old 04-17-2006, 11:56 AM   #6
303WRX
Member#: 35097
2002 WRX Sedan
I'm interested in the Helix camshafts as well, but buying something that is so new on the market makes me very nervous. The first people that used DPR and Crower camshafts had quite a few problems them. It took DPR and Crower a while to work out the "bugs." I would hate to get stuck having problems with the Helix cams after spending a lot of time and money putting them in. At this point I think I'm going to save up and go with the DPRs. They're proven to make power and be reliable.
303WRX is offline   Reply With Quote
Old 04-17-2006, 12:41 PM   #7
02Toyowrx
Member#: 56520
These cams arent AVCS, so they shouldnt have a problem.
Something to think about they are designed for the 2.0L (different Lobe seperation). They will work with a wrx/STI combo, but not to the fullest potential a cam could offer for a 2.5L application.
Helix cam lift= .377" stock USDM 2.5L STI cam lift= .380"
so for a 2.5L you arent gaining airflow, but you should get a better powerband.
Old 04-18-2006, 08:52 AM   #8
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
helix 264 is a .413" lift and .222" at .050 mine are installed in p&ped heads with radius grind. i bet i will increase airflow big time alot more than the sti cams for sure. the are cams you are quoting lift on have a duration of 264,and 272 they have a .377,and .403 lift and at .050 they are 222,232 lift
Old 04-18-2006, 01:10 PM   #9
banzai
Member#: 63926
deck EJ 20G stroker
if you check www.helix-power.com they are working on a AVCS cam.
Old 04-18-2006, 01:27 PM   #10
02Toyowrx
Member#: 56520
9.6mm lift= .377" of lift. This is what is quoted on the helix website.
Old 04-18-2006, 02:09 PM   #11
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
i looked at thhe site and found no info. which site did you go to mine were checked at the shop that worked the heads.i supplied all my own stuff.so the #'s given to me were not padded
2006 WRX Turbo Combos, Forged internals, Helix Injectors, Helix Cams, & More!!! Gruppe-S Engine/Power/Exhaust 9 08-30-2006 09:30 PM
Helix Injectors, VF22s, VF34s, Helix DPs, Helix Cams, cheap accessories all in stock! Gruppe-S Engine/Power/Exhaust 11 08-29-2006 08:11 PM
Helix Cams back in stock - $519 Shipped! STi Mounts! Cobb APs in stock! Helix DPs! Gruppe-S Engine/Power/Exhaust 3 07-31-2006 06:59 PM
STi Helix Injectors back in stock! Helix Cams for EJ20, built motors, much more! Gruppe-S Engine/Power/Exhaust 32 02-09-2006 04:00 PM
Holy hell these people know how to get people to allow them to meet with them. aod Off-Topic 11 03-02-2005 03:13 PM
