Old 04-16-2006, 10:02 PM   #1
madwrxing
Member#: 109212
03 wrx
Sonic Yellow
Default Learning Gear Ratio and Final Drive Ratio
Fellow tranny gurus,
Can you guys point me to a place where I can learn about what do all those numbers mean? And how they are translated to torque and top speed?
My main confusion is by having a lower/closer gear ratio suppose to give me more torque at lower speed? Or it's the other way around. For FD ratio, I have seen people talking about how 4.11 works better than 3.90.
I am in the process of rebuilding my 03 WRX stock tranny (2nd and 3rd broken teeth). I am thinking to go with "sti v6 cryco RA gearset", and then I don't know which gear ratio I should get, the closer gear ratio or keep the stock gear ratio?? My question is how much stronger is cryco than non-cryco set? A fellow nasioc member is selling sti v6 RA set for $1395 shipped (non-cryco treated), should I go for it? Where are some places I can get gearsets? I am also thinking just upgrade 1-4, still keep stock 5th gear.
I don't care about speed tops off at 150mph or whatever I will never attempt to go that fast. I would like some more low end torque and maintain smooth shifting. By the way, it will mainly be in-town driving, so 5th gear high way cruising at high RPM is also not a concern.
thanks
madwrxing is offline   Reply With Quote
Final Drive ratio & 6th gear ratio? scuzzy Transmission (AT/MT) & Driveline 1 11-09-2013 10:54 AM
Gear and Final Drive ratios... Driver72 Impreza Forum 4 09-27-2004 12:59 PM
How many gear ratios and final drives on 6MT? Greg555 Transmission (AT/MT) & Driveline 4 09-04-2004 06:08 AM
the gear ratios and Final Drive question ChAi Transmission (AT/MT) & Driveline 0 11-20-2003 07:40 PM
Gear Ratio and Final Drive of '94 1.8L AWD? Aspen Transmission (AT/MT) & Driveline 9 03-11-2003 08:08 AM
