Old 04-17-2006, 01:46 AM   #1
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Default hi how to change color to red hvac,cd player
hi i have a 06 sti and i want to change my hvac,and stock radio 6disc cd changer indash to red but iam not sure the write up is for a 06 because its on a 02 will it be the same or no t thank you
subaru222 is offline   Reply With Quote
Old 04-17-2006, 08:37 PM   #2
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
bump does any one know
Old 04-17-2006, 09:23 PM   #3
jason2004STI
Member#: 43340
2004 STI
Java Black Pearl
Talking
I'm going to be completely useless and tell you to search, but I do remember reading how to do it on 04/05's, I would suspect it's the same or similar for an 06. It's on NASIOC somewhere.. maybe I can find it again.. brb...
ok, maybe this will help
http://forums.nasioc.com/forums/show...ulb+red+change
Good luck!
Peace
jason2004STI is offline   Reply With Quote
Old 04-17-2006, 09:30 PM   #4
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
that the same one i found ,,not sure if that will work or ot
Old 04-18-2006, 11:39 AM   #5
quezanart
Member#: 83072
2016 WRX
Lapis Blue Pearl
well i know the way you change the buttons on the radio is the same as in that write up, its just bulb condoms. But the part that isn't the same is the display.
The new model 6 cd changers have a different kind of display that doesn't use a bulb to light it. Search for changing the clock from green to red. The solutions for that, besides replacing the clock, will also apply to the display on the cd changer as they are the same type of display.
As for the HVAC, that requires a bit more work. Namely soldering on some new LED's under the HVAC knobs. I have actually done this successfully. Here is a link to the instructions that i followed to do it http://www.iwsti.com/forums/showthread.php?t=18110.
If you have any questions you can feel free to PM me and i'll do what i can to help out.
-Dan
quezanart is offline   Reply With Quote
Old 04-18-2006, 09:27 PM   #6
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
dam that look really hard to do i dont think i will do it any more,will pay some one to do it...
Old 04-22-2006, 07:47 PM   #7
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
Hey, I give S202wagn credit for tell me about it. But he took the face plates off of the HVAC controls, taped them off, and painted them with candy apple red transparent model paint. I also went ahead and painted the knobs and the switch that changes from inside to outside air. It turned out great and has a nice red color. It cost like 3 bux and you can get the paint at walmart. Just make sure you remove the current green condoms. I actually went with the condoms first, but when I wasn't happy with the outlook, I decided to try it his way. When I went to pull the condoms off, they had actually melted to the bulbs.
Here's how mine turned out. Sorry about the crappy picture. I couldn't get a good shot. But color looks like the one bright red circle looks like, but over the whole thing.
HappyIdiot is offline   Reply With Quote
Old 04-22-2006, 10:41 PM   #8
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
but i herd there is no condom it led lights
Old 04-22-2006, 11:19 PM   #9
mystiwip
Guest
Member#:
scoobymods should have what you're looking for.. search for 05 sti havc. it's the same as the 06 sti... as far as the HVAC, there's nothing much you can do but to add some red LEDs.
Old 04-23-2006, 01:02 AM   #10
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
I had green condoms on my mine. But they might have been from the previous owner.
Old 04-23-2006, 01:51 AM   #11
The Dayman
Member#: 84815
2015 water n badass.
badass n water.
very carefully?
The Dayman is offline   Reply With Quote
anyone know how the change color of defi? sum0325 Electrical & Lighting 0 11-28-2008 04:22 AM
How to change color of front Subaru badge?? shamrock 05 Interior & Exterior Modification 9 11-14-2008 01:23 PM
How to change color on oem column boost gauge? Senorpablo Interior & Exterior Modification 3 02-01-2006 07:35 PM
Dipping wheels in polish to change color subeesteve25 Tire & Wheel 14 11-12-2005 11:16 PM
52mm gauge to install right below aftermarket indash cd player WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-12-2002 02:40 AM
