Old 04-17-2006, 01:44 PM   #1
singincanary
Will mod for Guinness
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
Default Does anyone know if an '03 WRX oilpan will work on a 2.5???
Have one of these lying around and wondering if this will work on a 2.5l engine.
It is off of an '03 ej20, and I want to know if it will work with an ej25.
Please help me out as I can't find the part #'s for this online.
Thanks,
Bruce
singincanary is offline   Reply With Quote
Old 04-17-2006, 01:51 PM   #2
tribaltalon
Member#: 106763
I have an 02 wrx with a 2.5 block in it, I'm using the original oil pan from ej20. However if you want to put the STI headers on you will have to get the STI oil pan.
tribaltalon is offline   Reply With Quote
Old 04-17-2006, 06:08 PM   #3
singincanary
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
someone wanted to put this oil pan on their STi, so they would be using stock STi headers on their engine, so I guess that it won't fit. Thanks for the info.
Old 04-17-2006, 06:23 PM   #4
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
It fits, but you have to use the complete oil pan assembly with the oil pickup. The only sti headers that DO NOT FIT are the JDM v8 sti headers. The usdm's are the same exact as the usdm wrxs
petawabit is offline   Reply With Quote
Old 01-10-2014, 11:16 AM   #5
KevinG
Member#: 146091
14 Mazda 3
Red
How does changing out the oil pan from the 2.5 to the 2.0 oil pan effect amount of oil needed?
KevinG is offline   Reply With Quote
Old 01-10-2014, 02:40 PM   #6
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Shouldnt effect how much is needed but the dip sticks are 2 different lengths
cosseywrx is offline   Reply With Quote
Old 01-10-2014, 02:50 PM   #7
Kid_with_the_face
Member#: 369616
2003 Wrx
Midnight Black Pearl
Just went from an 03 2.0 pan to an sti pan. The markings on the dipstick are different although it takes the same amount of oil. The oil sits at a different level in the pan due to the depth/shape. You could make new markings on the old stick but I just got a new one. The only other thing that's different is the oil pickup. The wrx pan can't accommodate equal length headers so also be aware of that. Some people change the dipstick tube but I'm pretty sure they're the exact same thing.
Kid_with_the_face is offline   Reply With Quote
Old 01-13-2014, 07:57 PM   #8
autoscience
Member#: 353836
The wrx pans hold more oil, if I remember correctly 4.8 in a wrx in and 4.3 in an sti. Yes you have to use the oil pick up and windage tray to match the pan or if physically wont fit. You all need the dip stick to match the pan.
autoscience is offline   Reply With Quote
Does anyone know if an 08-10 WRX gauge cluster will go in a 02-07 WRX? 100_Percent_Juice Interior & Exterior Modification 32 04-04-2010 01:33 AM
Anyone know if an STI Axel-back will bolt up to a 3" Surewin V2 midpipe? theleveler Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-22-2009 04:47 PM
Anyone knows if 17" TC Scion wheels will fit on WRX? txl146 Tri-State Area Forum 17 12-04-2007 08:22 PM
Anyone know if a stock STi exhaust will fit on a 99 2.5 RS?? Black-STi Subaru Conversions 4 05-02-2006 02:23 PM
does anyone know if the front and rear cigar lighter on the 99 is on the same fuse? Big_Hitter Forester Forum 0 02-05-2005 01:29 PM
