Old 04-17-2006, 05:46 PM   #1
subywrxdude
Member#: 88359
Default Cobb stage 2 maps (HWG VS. 91oct vs. 93 oct.)
Is it safe to use the hwg maps here with our elevation, what is the difference, maybe a higher boost rate? is there a big power difference between the 91vs the 93 octane map. cobb only claims 5 extra hp or torque i forget.
note running on a 02 wrx at high elevation (mile high denver!)
subywrxdude is offline   Reply With Quote
Old 04-17-2006, 05:53 PM   #2
-Kevlar-
Member#: 82378
i dont think there is a big power increase between the 91 and 93 maps... like you said cobb says 5hp. id go with that... do you need the hwg?
-Kevlar- is offline   Reply With Quote
Old 04-17-2006, 06:05 PM   #3
subywrxdude
Member#: 88359
i dont have a boost gauge so i dont know what im hitting for max boost. A lot of guys here in Co are using the hwg
Old 04-17-2006, 06:19 PM   #4
-Kevlar-
Member#: 82378
have you used read live boost? try it and see what you are hitting.. you shouldnt use it unless youre not hitting target...
Old 04-19-2006, 12:30 PM   #5
thejean
Member#: 17763
What exactly is the HWG map anyway? How does it differ from the regular Stg2 91/93 maps?
thejean is offline   Reply With Quote
Old 04-19-2006, 04:53 PM   #6
-Kevlar-
Member#: 82378
for people that cant hit target boost.... read the map notes on cobbs website....
Old 04-19-2006, 05:00 PM   #7
thejean
Member#: 17763
I did, but it really wasn't clear to me why some people might not hit target boost. What exactly in the mapping is different?
Old 04-19-2006, 11:49 PM   #8
azndrifter01
Member#: 106041
04 wrx sti
black
wow....some people need to research don't even get stage 2 if u can't answer these questions urself NEXT TOPIC!
azndrifter01 is offline   Reply With Quote
Old 04-20-2006, 02:04 AM   #9
thejean
Member#: 17763
oh gosh, i haven't bothered to read about the hwg maps and i loaded stage 2 into my ECU... will i be punished by the ECU police?
it probably took more effort for you to be an ass than to actually provide the answer. nice.
Old 04-21-2006, 11:09 AM   #10
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
I think the hwg map makes the wg stay closed longer to reach a little higher boost. I don't know all the parameters or what else is diff.
PS I think some people are just addicted to the word "search" Might as well get used to it. You will be told again sometime in another thread.
breathinez is offline   Reply With Quote
Old 04-21-2006, 11:25 AM   #11
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Posted this last year:
After doing a ported turbo and uppipe install I have had low peak boost, 14psi. For about a month and a half I have been using Cobb's realtime HWG map on top of 91oct stage 2 base map. I later reflashed the RT map to 91 oct and adjusted the actuator arm. These are my perceptions and results comparing the two methods.
1. HWG didn't increase my "peak" boost it was still around 14psi.
2. HWG did increase boost overall, meaning that I was seeing higher boost all the time. Examples: Under load up a hill the HWG gave me 2 to 3 more pounds of pressure than the actuator adjustment under the same conditions. Also boost came on sooner and stayed higher under partial throttle and everyday driving. (yes the engine was more responsive and more fun to drive)
3. The extra boost under everyday driving was causing worse gas mileage. After the actuator arm adjustment I'm seeing a 2-4 mpg increase.
4. Actuator arm adjustment did increase my "peak" boost.
5. WOT performance is better with the actuator arm adjustment.
WRX03 is offline   Reply With Quote
Old 04-21-2006, 11:30 AM   #12
thejean
Member#: 17763
Interesting observations.
09 WRX. Perrin stage 2 vs Cobb stage 2 map. Liquidr1 AccessPort 10 02-22-2010 10:05 PM
Differences between Cobb Stage 2 maps for 91, 91 and ACN 93 2slow AccessPort 0 02-12-2009 07:04 PM
have boost problem with cobb stage 2 map or PDX maps alvinli217 AccessPort 23 12-04-2008 03:59 PM
Anyone with 1/4 time with new 1.2 Cobb stage 2 map? WRXVII Engine Management & Tuning 17 09-20-2004 02:50 AM
VF30 and supporting mods on Cobb stage 2 map... help WRXVII Engine Management & Tuning 4 07-08-2004 09:16 PM
