North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 04-17-2006, 09:32 PM   #1
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
Default would this work, and would it hurt your car?
seeing every now and then a car is stolen here, and it seems an sti was stolen (which i hope the owner gets his car back in one piece) recently from an apartment complex. seeing you need the fuel pump to pump gas, what if you wired in a switch that would be mounted somewhere inside the cabin. what you would need to do is turn power on to the fuel pump in order to drive the car more then a few yards. now if the car runs out of gas, is it hard on a turbo car? i think something like this might give the owner a chance to save his car from bieng stolen... do any of you think something like this would work?
David Glasscock is offline   Reply With Quote
Old 04-17-2006, 09:34 PM   #2
DChan
Gone... But not forgotten
Member#: 60342
2004 STi
You can also pull some fuses.
DChan is offline   Reply With Quote
Old 04-17-2006, 09:36 PM   #3
JasonLHall
Member#: 111318
2002 Forester S
white like a cracker
The Cobb Access Port has an anti theft mode on it that cuts the fuel.
JasonLHall is offline   Reply With Quote
Old 04-17-2006, 09:43 PM   #4
BraveUlysses
Member#: 93205
1991 318iS
2000 Z3MCoupe
Yes, you can install a relay and switch to turn off the fuel pump. You wouldn't want to mount it near the drivers seat however, thieves know to look near drivers seats for killswitches.
BraveUlysses is offline   Reply With Quote
Old 04-17-2006, 09:51 PM   #5
traction
Member#: 32016
2010 CRV EX-L
Polished Metal
I had a cut off switch in my old wrx, worked like a charm. not gonna post where i hid it though.
traction is offline   Reply With Quote
Old 04-17-2006, 10:41 PM   #6
AmolaitoPR
Member#: 38609
2004 STI
I had a similar setup on my 82 Rx7. Mainly to prevent fuel leaks on the GSL-SE 13B Motor, but it worked for anti theft at least once.
AmolaitoPR is offline   Reply With Quote
Old 04-17-2006, 10:43 PM   #7
DChan
Member#: 60342
2004 STi
Problem w/ that is if the theif is somewhat smart, all they have to do is unplug the battery to reset the ECU. Then your ECU will lose that realtime flash unless you decide to reflash your ECU w/ that anti-theft mode. But then there is that time issue and the flashlife of your ECU.
Old 04-17-2006, 11:00 PM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
What about an remote alarm style set up on the fuel pump power?
Old 04-17-2006, 11:00 PM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
/\/\/\/\/\/\/\/\/ Bang!
Old 04-17-2006, 11:53 PM   #10
bboy
Member#: 56468
04 Improved STI
Dirty White
I have thought about using a remote switch, that is switched on/off by a key fob. You take the ability to switch the pump on with you.
Old 04-18-2006, 01:52 AM   #11
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
i got one myself it alsome
ChAi is offline   Reply With Quote
Old 04-18-2006, 12:45 PM   #12
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
what I use when I leave my ride at the airport.
tazswing is offline   Reply With Quote
Old 04-18-2006, 01:44 PM   #13
03WRX_Rich
Member#: 64660
2003 WRX
Silver & Dirt
Back in high school I had a pushbutton switch mounted in my glovebox of my rabbit then wired to the fuel pump wires on the back side of the fuse box. Make sure you use a relay as the fuel pump has some amps associated with it. Good luck figuring out how to immobilize that! It's easy to do....just don't forget you cut the pump when you get back in your car.
03WRX_Rich is offline   Reply With Quote
Old 04-18-2006, 01:49 PM   #14
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
would be awesome
Kaymin is offline   Reply With Quote
Old 04-18-2006, 01:55 PM   #15
BraveUlysses
Member#: 93205
1991 318iS
2000 Z3MCoupe
Originally Posted by Kaymin
would be awesome
Until you accidentally hit the button while driving.
Old 04-18-2006, 06:25 PM   #16
blueribbon
Member#: 22668
2006 AE86 Levin it
NA1
I had a fuel cut on my FD both for theft and flooding issues.
Mike
blueribbon is offline   Reply With Quote
Old 04-18-2006, 06:38 PM   #17
abaxter34
Member#: 34723
fwd FTL!
that might be hard to do since the key fob will be hanging from the steering column.
abaxter34 is offline   Reply With Quote
Old 04-18-2006, 06:52 PM   #18
fordfabwiz
Member#: 8875
2002 REX
Sliver
Lojack
fordfabwiz is offline   Reply With Quote
Old 04-18-2006, 09:50 PM   #19
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I've got one of those big red-keyed switches to lock out the starter in my car. Damned if I ever use it though.
specialev is offline   Reply With Quote
Old 04-19-2006, 02:18 PM   #20
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
I don't think they'll even get it started. Doesn't the fp pressurize the system when you turn the ignition? But if a thief did get it started, they won't build enough positive pressure in the the few feet they'll go to hurt your engine. It'll be just like running out of gas off boost.
scrappydoo is offline   Reply With Quote
what stage STI would this be and does it sound like i good set up 450STi Newbies & FAQs 10 02-04-2008 07:39 PM
How much power would this produce and would it be reliable? yardsale Factory 2.0L Turbo Powertrain 7 10-11-2005 12:21 AM
Would this work as a rally car? RebelINS Motorsports 7 12-12-2003 04:22 PM
legacy gt..would this work? what else would i need? jkyes Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-01-2002 04:29 PM
Apexi S-AFC, will it hurt my car in the long run? inzomniak Normally Aspirated Powertrain 7 01-25-2001 05:55 PM
Message Board Statistics All times are GMT -4. The time now is 07:34 PM.
