Old 04-18-2006, 08:52 PM   #1
mekkon
Member#: 55015
2002 Outback Sport
Default Need to replace front rotors/pads on 2002 OBS - Need Advice!
I have a 2002 Impreza Outback Sport and have been out of the country almost the past two years, and in my absence the car has been only driven very occasionally and the front brake rotors are shot - rusted and flaking. The car is now out of warranty so I will be paying to replace the rotors and pads upon my return this month. My question is this:
Is there a reasonable aftermarket rotor/pad I should buy and have installed rather than just pay for the stock ones? I presume if I just go in and have them install the stock parts it'll be fairly pricey to begin with, so I'd much prefer to get a higher quality rotor and pad combo if I could do so for near the same price.
Any advice on basic slotted (or drilled) rotors that I should go with and pads as well? These have to be standard stuff that will fit exactly with no modification. I've had a look around the Tire Rack, but haven't been 100% convinced yet, so I'd love some help.
Many thanks,
-tom
mekkon is offline   Reply With Quote
Old 04-20-2006, 02:46 PM   #2
mekkon
Member#: 55015
2002 Outback Sport
Okay, here's my proposed setup: Brembo Slotted rotors with Hawk Ceramic Pads - which can be sourced through the tirerack for less than my Subaru dealer wants to just for the parts to replace the stock rotors and pads. Is this the answer? Better braking at the same price?
Another question: Will I need to order shims and sleeves as well, or will the subaru dealer have the necessary parts on hand? I still plan on having my dealer install them... Thanks!
Old 04-23-2006, 07:22 PM   #3
WrexT
Member#: 80169
2004 PSM WRX
Cobb Stage 2 biotch!
where's all the brake experts?
WrexT is offline   Reply With Quote
Old 04-23-2006, 11:29 PM   #4
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
just get plain rotors - and those pads
infantsam is offline   Reply With Quote
Old 04-24-2006, 07:36 AM   #5
ten80
Member#: 53625
00 16' FXT
tom- brembo blanks and some good pads are all you need. while you are at it, you can upgrade to WRX sized rotors if you use 02 wrx brake caliper brackets- it's a very good improvement in braking power (10.4 to 11.2" rotor if I remember correctly)
ten80 is offline   Reply With Quote
Old 04-24-2006, 09:04 AM   #6
rkkwan
Member#: 5596
2010 Honda Fit Sport
Unless you have specific needs - track days, rallys, very hard mountain driving - I'd stick with stock everything. They are relatively inexpensive, and if you switch to a performance pads, you'll need to compromise with noise/dust.
With my WRX and now the STi, I use stock rotors/pads except during track days, when I swap them out. The OEM stuff are more than adequate for street use, even more pretty aggressive driving style.
rkkwan is offline   Reply With Quote
Old 04-24-2006, 06:16 PM   #7
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
if you get subaru pads, they come with the clips (metal pieces that hold the pad in) a lot of aftermarket pads do not come with these.... and they are $5 a piece from the stealership. just an fyi
subygirl is offline   Reply With Quote
Need to replace front axles slow03 Baja Forum 2 05-03-2008 10:10 AM
Need to replace all rotors & pads -- need suggestions GTWagon_Phreak Legacy Forum 2 01-29-2006 03:37 AM
Is it ok to replace front rotor/pad only for now? GOT_WRX Brakes, Steering & Suspension 7 06-02-2005 01:08 PM
front diffential question on 2002 OBS rogeryung Service & Maintenance 1 09-05-2003 08:52 AM
Do I need to replace front swaybar links? Heather Brakes, Steering & Suspension 3 05-15-2003 11:36 AM
