#1 |
Member#: 10471
TXIC
Vehicle:2000 BMW Z3 sold Outback & ForesterXT |
Well, the thread title says it all...
I was replacing my clutch slave cylinder and was retorquing the banjo bolt. The directions can be found in a SOA bulletin, and we were discussing why to replace this part here: http://forums.nasioc.com/forums/showthread.php?t=985376 So, I set my torque wrench to 28 ft lbs and started turning. It just kept turning and then it started feeling loose. I thought, "oh, that can't be good!" So I turned it back out and then the head snapped off. At least I got the bolt out easily and didn't have to buy a new slave cylinder, too. So, my wrench goes down to 25 ft lbs, but apparently it doesn't actually work that far down. It's a big wrench and i was using a 3 inch extension. I know extensions affect the torque amount, but is that what went wrong? Or should I buy a small wrench for small amounts?!? This is how I feel about that bolt: ![]()
#2 |
Member#: 10471
TXIC
No comments?!? Well, I have until monday to wait and hear from you guys, since the parts won't be here until then. I'm going to sears and buy a smaller torque wrench too...
#3 |
Member#: 30727
South East
Vehicle:2000 Legacy B4 RSK *Formerly subyluvr2212* |
I personally do everything by feel; I haven't used a torque wrench in years.
Glad you got the rest of it out. |
#4 | |
Member#: 10471
TXIC
I do that for the most part, except for head bolts and bolts that hold in fluid. So, this one gets the torque wrench... ![]() |
| Thread Tools | |
| Display Modes | |
| caliper banjo bolt broke | tazswing | Brakes, Steering & Suspension | 2 | 03-11-2009 11:53 AM |
| can i use the stock banjo bolt for my 18g oil feed line? | anthonyrb98 | Factory 2.0L Turbo Powertrain | 3 | 09-23-2006 05:59 PM |
| WTB: Banjo bolt for oil feed on my GT35R | White 2.5rs | Private 'Wanted' Classifieds | 7 | 12-09-2005 06:19 PM |
| Stock Banjo bolt same as Stoptech Banjo bolt? | mav1c | Tire & Wheel | 3 | 11-22-2004 10:15 AM |
| Turbo banjo bolt same as brake banjo bolt? | dan avoN7 | Factory 2.0L Turbo Powertrain | 5 | 11-15-2004 09:25 PM |
