Notices
Old 04-19-2006, 09:03 AM   #1
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
Question Wiring Hella 500's question
Im fairly good with wiring stuff but i think im just missing something here.
I want to wire my hella 500's to come on with my high beams but when i put a test light on the wires connected to the headlight switch i cant find any change in wires when i turn on the high beams (if that makes any sense)
Has anyone done this before? I have the relay and everything ready to hook up and mount the lights this is my only hold up. Any advice?
pistoffjstr is offline   Reply With Quote
Old 04-21-2006, 07:51 AM   #2
pistoffjstr
Member#: 29283
Red
Any one?
Old 04-21-2006, 09:13 AM   #3
12Voltking
Member#: 108906
99 OB
white over gray
pistoffjstr. FIrst off, throw away the test light and buy a DMM this will aloow you to search for a negatively switched wire. When you have found this wire that to pin86 and give pin 85 a Positive feed. This will run the lights for you
12Voltking is offline   Reply With Quote
Old 04-21-2006, 09:17 AM   #4
pistoffjstr
Member#: 29283
Red
Ok test light out
I do have a DMM (3 year electronics course in high school) Truthfully i never though of using it for this lol
Im hoping to find a wire under the dash some place so i can keep the relay in the car out of the weather
Thanks for the help ill give it a shot this weekend
Old 04-21-2006, 09:20 AM   #5
twagoon
Member#: 80551
1999 Outback
Green
Have you tried taking it off of the headlight itself. I would think it would be easier to find out which one is the high beam there. Plus it is closer to where the lights will be mounted. You would end up with less wire running all around. If you are dead set on running the wire from the switch you may get lucky and have the wire be the same color all the way from the headlight to the switch.
Just a thought, you may have already gone through this but no one else said anything. And since Bueller is obviously not here I figured we should move on to the next name on class roster.
Good luck.
Damn slow typing skills, you both beet me.
twagoon is offline   Reply With Quote
Old 04-21-2006, 09:37 AM   #6
12Voltking
Member#: 108906
99 OB
white over gray
twagoon you cuol,d do that but then you have to run two wires into the cabin. By locating the wire inside you only need to run one wire outside to the relay.
pistoffjstr, by mounting the relay under the dash and not in the engine bay....you are defeating one of it's major purposes.
Old 04-21-2006, 09:42 AM   #7
pistoffjstr
Member#: 29283
Red
twagoon: I though about tapping the headlight wire but when i test for a hot wire there is 2 of them
12voltking: I never thought of that if i put the relay out in the engine bay i eliminate wires in the dash good idea
Old 04-21-2006, 09:44 PM   #8
12Voltking
Member#: 108906
99 OB
white over gray
Also pistofjstr...by putting the relayts in the dash you have to run your power wire inside the car and then back out...well, the purpose of a relay is take power form anotheer source and switch it but ALSO to make your power runs as short as possible.
Old 04-21-2006, 09:47 PM   #9
fantomas
Member#: 87500
2012 Outback 2.5i P
Graphite Gray
keep the relay in the engine bay, just mount it so the terminals face down and you won't have any problems
fantomas is offline   Reply With Quote
Old 04-22-2006, 08:24 AM   #10
pistoffjstr
Member#: 29283
Red
i think i will keep the relay in the engine bay that is a good idea
Now i just have to find the wire to tap so these things will come on with the high beams
Old 04-30-2006, 12:40 PM   #11
pistoffjstr
Member#: 29283
Red
Well i decided to be lazy and just use a switch i did put the relay under the hood though much less wires to run through the firewall
pics are here
Need help wiring Hella 500's mike_b49431 Electrical & Lighting 2 09-22-2006 10:00 PM
Wiring Hella 500's? ubshtoopid Electrical & Lighting 13 08-30-2004 12:33 PM
hella 500's question piker28 Electrical & Lighting 7 12-27-2003 10:52 PM
Help wiring Hella 500's skyliner33v General Forum Archive 2 01-14-2001 06:47 PM
HELP! Wiring Hella 500's STORER Interior & Exterior Modification 5 11-12-2000 10:40 AM
