Old 04-11-2000, 09:32 PM   #1
BeAn
Member#: 558
2002 WRX sedan
midnight black pearl
Unhappy Changing springs/struts????
let me get some directions on how to go about taking off my brake lines from the strut so that they dont leak all over the damn place and cuase me to bleed the brakes..
subie gal.. i already got yours thanx by the way..
ok all info appreciated..
thanks,
mark t
BeAn is offline   Reply With Quote
Old 04-11-2000, 09:58 PM   #2
GTMAN
Member#: 480
1998 Legacy GT Wagon
Smile
Well, Subie gals way is the only way to do it....cutting the bracket, bending it just enough to get the hose out. At least thats the only way that I've come across to not mess with bleeding the brakes.
Good luck,
GTMAN
GTMAN is offline   Reply With Quote
Old 04-12-2000, 02:41 PM   #3
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
I agree with the cutting/bending technique (that's what I did...a dremel works wonders in these situations). Otherwise, there really is no safe way to do it (you COULD try vice gripping the lines really tight to stop them from leaking, but, you would still have to get any air out of the lines later).
Cutting the brackets is not that bad. Invest in a dremel and it's not hard at all. Just be carful not to CUT the lines when cutting the bracket.
Kevin www.lagging.com
Force[FED] is offline   Reply With Quote
Old 04-12-2000, 04:11 PM   #4
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Question
What are you doing with your old set? are they in good condition? If so I would be interested in buying them if they don't have to many miles on them. I have a 91 Legacy and was looking to get new springs/struts because mine have seen better days.
John2.5RS is offline   Reply With Quote
Old 04-12-2000, 11:09 PM   #5
BeAn
Member#: 558
2002 WRX sedan
Post
Questoin number 2.. how exactly do you bleed the brakes? and is it time consuming/ hard?
ok thanks for the replys
Change from coilovers to spring/strut setup? phant Newbies & FAQs 8 07-13-2007 10:38 AM
Changing springs to my wrx 05 inverted struts... giggio26 Brakes, Steering & Suspension 5 10-08-2005 04:02 PM
JDM STi spring/struts vs STi Tarmac spring/struts deevoc Brakes, Steering & Suspension 10 03-23-2005 11:45 PM
FT: Stock Springs/Struts plus $$ for Any stock struts / lower springs besides eibach relirex Mid West Subaru Owners Club Forum -- MWSOC 1 03-12-2004 01:02 PM
Change the struts or springs or both? MrJaemz Brakes, Steering & Suspension 4 05-30-2002 04:49 PM
