Welcome to the North American Subaru Impreza Owners Club Saturday December 27, 2014
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-19-2006, 01:24 PM   #1
TurbojonLS
Member#: 38772
2 Cars, No Bling
Default Perrin EBCS & Boost Map
For those of you who are using Perrin's EBCS, what kind of changes did you need to make to your boost map values? The instructions say 30% reductions for interrupt mode (which I'll be using) - are these accurate? What about changes to the Gain (as if spool can be too quick )?
Mods (just in case it matters):
Drop-in Filter
Samco IC hoses
HKS Replica Header
Helix Uppipe
Madad V1 Shorty downpipe
Prodrive ABE
TurbojonLS is offline   Reply With Quote
Old 04-19-2006, 01:33 PM   #2
TheMadScientist
Member#: 23717
2005 Big red
I use the GM solenoid, basicly the same as the EBCS.
You will need to raise you gain a couple of points to reduce spiking. I would start with ~150 in the boost map and work your way up in steps ~20. When you start to see the boost rise with the map #'s reduce your steps to ~10. Once you start to control the boost with the new solenoid the #'s in the boost map become more sensitive.
TMS
TheMadScientist is offline   Reply With Quote
Old 04-19-2006, 04:03 PM   #3
Xman23
Member#: 50224
2004 WRX
Yours had instructions?
Percentage wise I'm not sure. I knew it was coming though. I dropped everything in my boost map by 100 and worked upward.
I didn't have to work up very far.
Just make sure you drop them down to something. I shiver when I think of what would have happened with the EBCS and my old map...
Xman23 is offline   Reply With Quote
Old 04-19-2006, 04:13 PM   #4
TurbojonLS
Member#: 38772
2 Cars, No Bling
Yeah, the scientific inquisitive part of me wants to datalog boost pre EBCS, post EBCS (same map), & post EBCS (revised map). I think it would be an interesting comparison. But the part of me that doesn't want to hit fuel cut & do bad things to my motor isn't so keen on the idea. Maybe I'll cut my boost values in half just to run the comparison.
Old 04-19-2006, 04:44 PM   #5
TheMadScientist
Member#: 23717
2005 Big red
If you want to run a low boost comparo. Up the boost #'s until you get jusy over wastegate pressure. That way the solenoid is controlling boost and not the wastegate.
TMS
Perrin EBCS & Agency Power inlet adapter hose Bolster RMIC Private Classifieds 1 10-24-2006 12:23 AM
UT: Perrin EBCS & Agency Power silicone hose Bolster Engine/Power/Exhaust 6 10-24-2006 12:22 AM
Perrin EBCS (Electronic Boost Control Solenoid) Dasani TXIC Private Classifieds 1 04-09-2006 09:53 PM
Perrin EBCS (Electronic Boost Control Solenoid) Dasani Private 'For Sale' Classifieds 3 04-09-2006 09:44 PM
F/S:VA: PERRIN EBCS & GM 3 BAR MAP SENSOR moorebl Private 'For Sale' Classifieds 4 04-08-2006 03:14 PM
