Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-19-2006, 01:20 PM   #1
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (617)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
Default 73.99 Fuel Pumps shipped, Coolingmist Water Injection specials, Turboxs, SBR, Perrin!
NEW PARTS IN STOCK!
Forge Recirculating blow off valve for 02+ wrx/sti- PM for pricing!
Forge STI wastegate actuator- PM for Pricing!
Check out our new in cockpit manual boost controller!!!!
1 20G td06H ported turbocharger IN STOCK!
http://www.importimageracing.com/pro...oducts_id=1255
Blitz SBC I-Color Boost controller
695 shipped for nasioc members!!!
Power enterprise injector specials!!!
Power Enterprise 850cc injector/walbro install kit combo's ready to go!!! the blow out price of $579 shipped!!!!!
Power Enterprise 650cc injector/walbro install kit combo's ready to go!!! the blow out price of $579 shipped!!!!!
Power Enterprise 800cc injector/walbro install kit combo's ready to go!!! the blow out price of $579 shipped!!!!!
Power Enterprise V mount intercooler kit. Special Order/Special Pricing
Perrin headers in stock 721 shipped!!!!
Turboxs Fuel Rails for 02+ wrx's 358 shipped!!!
Helix 860cc STI injector/Walbro Fuel Pump + install kit combo TOO LOW to advertise, send us a pm! only 1 blow out deal available!
Helix 660cc wrx injector/Walbro Fuel Pump + install kit combo TOO LOW to advertise, send us a pm! only 1 blow out deal available!
Best seller! SBR/Import Image xG install kits-
Comes with Gaskets, Coolant Line, and banjo bolts (all required parts when installing your 16/18/or 20g turbocharger!) for the combo price of $85 shipped
Helix 820CC wrx injectors instock!!
http://www.importimageracing.com/pro...roducts_id=740
Perrin Legacy GT Front Mount Intercooler kit!!! Pre-order yours today and save big!!!!
Walbro Fuel Pumps 73.99 shipped! Need the install kit too? 85.99 shipped! Best pricing ANYWHERE! beware, some vendors are selling without the install kit. That blows away there price be smart!! just send paypal
confirmed to [email protected]
Have a crazy setup? Need a dual walbro pump setup? 165 shipped for dual pumps!
We have every model in stock. If you order one from us, it ships either that day or the next! Have a dyno day planned or you just need it overnighted? We will help you get your parts when you need them!
Coolingmist water injection kits now in stock!!!
Here is a stage 2 Coolingmist STI dyno plot (Higher being with Coolingmist kit)
Stage II retails for $499.95. Your price $WILL NOT BE DUPLICATED shipped
* 2 Quart Tank
* Vari-Cool Coolingmist Controller
* Complete Kit!!!
* No Need To Specify Horsepower!
The Stage II controller kit is a fantastic value. Its exactly the same as stage I except it ships with a brass clog nozzle/water flow detector. It will blink when water/methanol flows and it will tell you if you have a clog. You recieve our high pressure pump, vari-cool tuning controller, a 2.0 quart tank and everything else you need. The controller has a starting point for boost, a maximum point for boost and a tuning knob. The tuning knob gives you 10 algorithms to choose from. For example, if you set the minimum knob at 1 and the max at 30 and have the tuning knob at 1 it will give you a linear feed from 1-30 psi. The higher you change the tuning knob the more agressive the curve. Because of this, you do not need to change injectors when you gain more HP. Our software suite allows you to change the variables in the controller so you can fine tune if you wish. Software requires windows 2000, NT, 2003, or XP +. The controller has a 0-5V input also, so if you prefer to inject the water based on the 0-5 instead of the boost, you can do that also. What else can this unit do? Lets say you want to run based on both 0-5V input and Boost...You can set the 0-5V as the primary input and the boost as secondary or you can set the boost as primary input and 0-5V as secondary. You must have the software configured to run that mode.
Stage III retails for $599.95. Your price $519.99 shipped
(THE STAGE III COMES WITH A 1 GALLON TANK AND FLOAT SWITCH)
* 12 Feet Of Stainless/Teflon Hose (more optional)
* Brass Water Filter
* Stainless Steel Re-Useable fittings
* Hose can be shortened with a Dremel Tool
* 1 Gallon Tank
* Low Fluid Light
The 150 psi deluxe kit + tank is $299.95, your price is $WILL NOT BE DUPLICATED shipped
* Methanol Safe
* 150 PSI Pump
* 15 Feet of Hose
* Boost Activated 1-25 PSI
* 90 Day Warranty
* Complete Kit
* Professionally Packaged
This is the Cooling Mist DELUXE 150 psi Methanol/Water Injection kit. It comes with everything you need. This comes with our 150 psi pump, brass water filter, 2.0 quart water tank , water tank taping kit and all the wiring, injectors and other things you need. This also ships with our outstanding brass checkvalve. This is a great deal. The boost switch is adjustable from 1-25 psi. Its a great kit at a great price. choose single nozzle or dual nozzle setup from the drop down box. If you have more than 500 HP or if you have twin carbs/throttlebodies we recommend the dual nozzle setup.
Options-
All kits come with a 2 quart tank. There is no pricing difference if someone wants a kit without a tank. If you would like to add a float switch with your order add $20
If you would like to upgrade from a 2 QUART tank to the 1 Gallon your cost is $20 to do so.
Upgrade to the 2.5 gallon tank for $40
Add a controller for $179
Quick check out right here-
http://www.importimageracing.com/index.php?cPath=414
1 91+ legacy turbo SBR evo 3 16G fully ported in stock!
Here are some pics of the SBR 16g's...did I mention that I'm selling one non ported for $689.99 shipped within the 48 states?
and 787.99 with porting (inlet and outlet, 10% more power, and faster spool!!!)
these turbos make more power than the vf series turbos and are genuine mitsubishi turbos, not asian copies
need coolant/oil lines to make these work? we have those for you as well
they are oil AND water cooled
Get them before they are gone, packages available!!
Megan Racing performance parts now available!
1 crazy turbo package available
550cc injectors
SBR 16G Turbocharger
Walbro Fuel Pump+ Install kit
$1098 shipped (only 1 at this price)
want the same setup but with a ported turbocharger? add $90 (make 10% more power!) (2 available at this price)
New Turboxs Dtec boost controller combo!!!- includes DTEC boost controller + a second boost solenoid for only-$535 shipped...$535 for dual stages!!!
STI injectors (using your current injectors) Combo- $1017 shipped
Helix Oil Catch Can $81.50
SBR-FMIC $1099 Free shipping!
SBR up pipe with Tial 38 mm or 44 mm provision $316 Free shipping!
Introducing the Slowboy Racing SBR-50T
Why buy a Forced Performance Green Turbocharger for $1300+ when you can get the same thing without the fancy colored name from slowboyracing for 12XX internally gated
and 11XX externally gated. PM FOR PRICING
This turbo's specs-To4e 50 trim tdo6h .63 a/r
Crazy combo-
Slowboy Racing 16G wrx turbocharger
650cc injectors
Walbro Fuel + install kit
Total- 1299.99 shipped!!!
Helix 820cc injectors/fuel pump combos are available!
Perrin Rotated mount turbo setup- 645 shipped!!!
Perrin Rotated mount GT30R Complete setup- Includes stainless steel up pipe and down pipe, Tial 44 wastegate, a complete intake system, oil and water lines, and a GT30R Turbo kit you choose .63 or .82 A/R- $XXXX.XX PM ME!!!! shipped!
Perrin Rotated mount GT35R Complete setup-Includes stainless steel up pipe and down pipe, Tial 44 wastegate, a complete intake system, oil and water lines,and a GT35R Turbo kit you choose .63 or .82 A/R- $XXXX.XX PM ME!!!shipped!
TURBOCHARGERS!!!-
Slowboy Racing 16G wrx turbocharger 689.99 shipped
Slowboy Racing 18G wrx turbocharger 889.99 shipped
Slowboy Racing Evo 16G wrx turbocharger 889.99 shipped
Slowboy Racing 16G wrx turbocharger Fully ported 809.99 shipped
Slowboy Racing 18G wrx turbocharger Fully ported 1009.99 shipped
Slowboy Racing Evo 16G wrx turbocharger Fully ported 1009.99 shipped
Slowboy Racing 20G WRX/STI turbocharger 1139.99 shipped
Slowboy Racing-GT10 External Gate turbocharger- $1199 shipped
Slowboy Racing-GT10 Internal Gate turbocharger- $1324 shipped
Slowboy Racing-GT10 External Gate Fully Ported turbocharger- $1319 shipped
Slowboy Racing-GT10 Internal Gate Fully Ported turbocharger- $1444 shipped
Slowboy Racing-GT11 External Gate turbocharger- $1199 shipped
Slowboy Racing-GT11 Internal Gate turbocharger- $1324 shipped
Slowboy Racing-GT11 External Gate Fully Ported turbocharger- $1319 shipped
Slowboy Racing-GT11 Internal Gate Fully Ported turbocharger- $1444 shipped
Slowboy Racing-GT12 External Gate turbocharger- $1199 shipped
Slowboy Racing-GT12 Internal Gate turbocharger- $1324 shipped
Slowboy Racing-GT12 External Gate Fully Ported turbocharger- $1319 shipped
Slowboy Racing-GT12 Internal Gate Fully Ported turbocharger- $1444 shipped
Slowboy Racing-GT13 External Gate turbocharger- $1199 shipped
Slowboy Racing-GT13 Internal Gate turbocharger- $1324 shipped
Slowboy Racing-GT13 External Gate Fully Ported turbocharger- $1319 shipped
Slowboy Racing-GT13 Internal Gate Fully Ported turbocharger- $1444 shipped
Slowboy Racing-GT14 External Gate turbocharger- $1249 shipped
Slowboy Racing-GT14 Internal Gate turbocharger- $1374 shipped
Slowboy Racing-GT14 External Gate Fully Ported turbocharger- $1368 shipped
Slowboy Racing-GT14 Internal Gate Fully Ported turbocharger- $1493 shipped
Slowboy Racing-GT35 External Gate turbocharger- $1299 shipped
Slowboy Racing-GT35 Internal Gate turbocharger- $1424 shipped
Slowboy Racing-GT35 External Gate Fully Ported turbocharger- $1418 shipped
Slowboy Racing-GT35 Internal Gate Fully Ported turbocharger- $1543 shipped
Forced Performance Green Turbocharger- 1359 shipped
Forced Performance Green Turbocharger with STI oil line kit- 1434 shipped
Power Enterprise 1820 Turbocharger- 1460 shipped
IHI VF34's new with warranty- 849.99 shipped
APS SR55 Turbo $1999
Be sure to check out our combo deals on our website, we are always thinking of new packages to save you money! www.importimageracing.com
Turboxs Parts-
Turboxs WRX/STI Complete Catless Turboback TI tip exhaust- $849 shipped
TXS uppipe- $184 shipped
TXS Downpipe- $329 shipped
TXS TI catback- $419 shipped
TXS intake- $159 shipped
Turboxs Tuner Pro with Bosch sensor- $629 With Free Shipping
TXS Wideband Air/Fuel with Bosch Sensor- $454 shipped
TXS Wideband Air/Fuel with VW sensor- $369 shipped
TurboXS 2002-2005 WRX UTEC- $ PM us!
TurboXS WRX STI Utec- $ 799 shipped!!!
TurboXS FMIC- PM or phone pricing only
TurboXS Dtec Starter Kit (DTEC-STARTER) $219.00 shipped
TurboXS KnockLite (KNOCKLITE) US$122.00 shipped
TurboXS Fuel Cut Defender - 5 volt MAP (FCD - 5V) $124.00 shipped
Turboxs Dtec Fuel Computer (DTEC-FC) (Dtec FC) US$338.00 shipped!
Turboxs Dtec Fuel Computer/Turboxs Bosch Tuner COMBO!! $726.00 SHIPPED!!!!
TurboXS Dtec Starter Kit/Turboxs Bosch Tuner COMBO!! 639.99 shipped!!!
The TurboXS DTEC is a revolutionary new product that turns your Nintendo® Gameboy Advance into a programmable, upgradeable, automotive performance tool for tuning, data logging, and diagnostics.
Turboxs DTEC Boost Controller Pro (DTEC-BC-PRO) US$PM ONLY! We have the best pricing on this item! $444 shipped!
Crazy Combo's with free shipping!-
Turboxs Utec + Map Selector + Dtec Boost Controller Combo- 1289.00
Turboxs Utec + Map selector + Txs Bosch Tuner Combo- 1,259.00
Turboxs Utec + Map selector + Walbro Fuel Pump combo! 940.99
Turboxs/Import Image Stage 2- includes- Free Map Selector! Utec, Free Walbro Fuel Pump with install kit!!!! Turboxs 3inch turboback exhaust with titanium tip Turboxs Short Ram intake- 2,022.00
Turboxs/Import Image Stage 3- includes- Utec, Turboxs FMIC kit, Free Map Selector! Free Walbro Fuel Pump with install kit!!!! Turboxs 3inch turboback exhaust with titanium tip Turboxs Short Ram intake- 3099.99
FP Green, Power Enterprise 800cc injectors, Walbro pump combo- 2022.99
FP Green, PE 850, Walbro, FP oil line STI combo! 2,081.00
Complete stage 4 package-
Turboxs Utec + Map selector + FMIC kit+ Walbro Fuel Pump + install kit!!!! Turboxs 3inch turboback exhaust with titanium tip + Turboxs Short Ram intake + 650cc injectors + SBR 18G turbocharger- $$4560 shipped
Perrin Performance-
Pricing is the same on Forester xt, Legacy GT, WRX, STI- all listed below!
LIGHTENED CRANK PULLEY 93 & UP IMPREZA, WRX, STI, ALL MODELS $120.00 shipped
New 3inch Turbo Inlet Hose 234 Shipped!
FUEL RAIL KIT FOR WRX 2002 & NEWER (NO STI) 366.99 shipped
INTERCOOLER TOP MOUNT 04+ STI (02-05 WRX REQS ENG-305 BELOW) $720
INTERCOOLER FRONT MOUNT 2002 & NEWER WRX & STI $1069
UP-PIPE IMPREZA WRX, AND STI MODELS (OFF-ROAD ONLY FOR WRX) $180.00
DOWN PIPE NO-CATS 2002 & NEWER WRX AND STI (OFF-ROAD ONLY) $329.99
EXHAUST SYSTEM CAT-BACK 2002 & NEWER WRX & STI TWIN TIPS $649.99
EXHAUST SYSTEM CAT-BACK 2002 & NEWER WRX & STI SINGLE TIP $649.99
NEW 04 STI INJECTORS W/816cc Mod. PM for best pricing
MOD EXISTING 04 STI INJECTORS 816cc(Special Pricing)CALL FOR DETAILS $199.99
BLOW OFF VALVE KIT 2002 WRX AND STI $231.99
Aps parts shipped-
- APS 3.5" Race Turbo-Back Exhaust $1290
- APS DR725 Front Mount Intercooler $1480
- GT spec header- $539
- APS FMIC Blow Off Valve $269
Intake Manifold-
Magnus WRX STi Intake Manifold-$1045 shipped
Magnus WRX Intake Manifold-$1095 shipped
Headers-
Vibrant WRX 2002-2005 Header 599.96 shipped (comes with catless up pipe also!)
Invidia WRX 02+ Header w/ intergrated Up Pipe- $986 shipped
DNP WRX Stainless Steel 4-2-1 Equal Length Header- $1289 shipped
We are very competitive with our pricing
Savings on items paid for via Money order, Certified Bank check, and personal check (shipped after check clears) receives additional discounts
ps the price increase of the whole $1 on the fuel pumps is because shipping went up $1 on most pumps, we aren't being greedy, just letting you know why
Disclaimer- If you send a payment and live in FL and do not add 6% sales tax, your item will not ship.
Import Image Racing
Visa/Mastercard-
239 540 6385
Paypal= [email protected]
Money order address=
Import Image Racing
431 sw 34th terrace
cape coral, FL 33914
IMPORTIMAGE is offline
Old 04-19-2006, 07:14 PM   #2
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Turboxs UTEC sale, PM us!
Old 04-20-2006, 02:58 PM   #3
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
To the top!
Old 04-21-2006, 09:06 AM   #4
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Coolingmist specials send us a pm!
Old 04-21-2006, 04:03 PM   #5
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Give us a call, lets make some deals
Old 04-22-2006, 09:09 AM   #6
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
The saturday morning we are working and we love it bump!
Old 04-22-2006, 11:45 PM   #7
eyehate
Member Sales Rating: (10)
Member#: 10223
pmed!
eyehate is offline
Old 04-23-2006, 11:05 AM   #8
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
PM returned
Old 04-24-2006, 09:03 AM   #9
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Monday morning bump
Old 04-24-2006, 09:14 AM   #10
sutter2k
Member Sales Rating: (8)
Member#: 92467
08 STI
how fast to you get a SBR 18g? can you request a td06-18g?
sutter2k is offline
Old 04-24-2006, 01:40 PM   #11
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Let me double check with SBR and I'll send you a PM with the info
Old 04-24-2006, 03:31 PM   #12
eyehate
Member#: 10223
pmed again!!!!!
eyehate is offline
Old 04-24-2006, 05:48 PM   #13
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
PM returned
Old 04-25-2006, 12:19 PM   #14
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Check out the coolingmist specials!
Old 04-26-2006, 09:47 AM   #15
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
To the top!
Old 04-26-2006, 02:30 PM   #16
AnthonyC.01
Member Sales Rating: (1)
Member#: 93706
'15 WRX CWP
rip 05 STi OBP
Bump,
I know everything I wanna get now, just missing turbo...
Utec+map selector
Turboxs FMIC
walbro pump/install kit
pe850's
sbc alky
AnthonyC.01 is offline
Old 04-27-2006, 09:00 AM   #17
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Thanks, let me know when your ready, PE just dropped the price on their injectors, I can prob do a little better on the deal we were working out
Old 04-27-2006, 05:59 PM   #18
wuuusaa
Member Sales Rating: (20)
Member#: 92894
2015 Wrx
pm'ed yah
wuuusaa is offline
Old 04-28-2006, 09:56 AM   #19
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
PM returned
Old 04-28-2006, 03:20 PM   #20
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Power Enterprise 850cc injector/walbro install kit combo's 3 in stock ready to go!!! the blow out price of $565 shipped!!!!!
Sti pink injectors (550cc) in stock with walbro fuel pumps!!! combo price of $405 shipped!!!
Old 04-29-2006, 03:27 PM   #21
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
to the top!
Old 04-30-2006, 08:12 AM   #22
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Be sure to check out our turbocharger sale in the group buy section!
Old 05-01-2006, 08:40 AM   #23
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Monday morning bump!
Old 05-01-2006, 09:58 PM   #24
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Evening bump
Old 05-03-2006, 09:11 AM   #25
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Weds morning bump
Closed Thread
$74.99 Fuel Pumps, Perrin headers, Turboxs, Power Enterprise, Coolingmist!! IMPORTIMAGE Engine/Power/Exhaust 125 12-19-2006 03:10 PM
Insane October sales!-73.99 Fuel Pumps, Perrin, Turboxs, Power Enterprise IMPORTIMAGE Engine/Power/Exhaust 144 11-06-2006 01:28 PM
73.99 Fuel Pumps, Cobb AP, Power Enterprise, Turboxs, Perrin, Forge, Coolingmist! IMPORTIMAGE Engine/Power/Exhaust 118 09-29-2006 12:06 PM
73.99 Fuel Pumps, Forge, Power Enterprise,Coolingmist, Turboxs, SBR, Perrin BLOWOUT! IMPORTIMAGE Engine/Power/Exhaust 11 09-01-2006 11:54 AM
73.99 Fuel Pumps, Coolingmist stage II specials, Turboxs, Forge, SBR, Perrin specials IMPORTIMAGE Engine/Power/Exhaust 104 08-30-2006 01:15 PM
