#1 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
So, in light of the fact that our stock hoods weigh about 8 million pounds, and CF hoods are hard to come by and $$$, I've been thinkin... I don't have a good picture to post as a reference, but what I'm thinking of doing is Dremeling off the hood liner (not the foamy sound deadening, I'm talking the inner ribs and stuff). Not sure if that makes sense, but the hood is basically 2 layers of steel - the actual hood itself, and then the underside. I think I could cut a few inches in from the edge all the way around, leaving the latch, hinges, and enough structure so the thing doesn't fold in half.
Thoughts? I think it would work fine, but obviously I'm wary of the hood, well, folding itself in half. ![]() Pat Olsen '97 Legacy 2.5GT sedan
#2 |
Member#: 41012
E. Canada
Vehicle:1998 Legacy L |
I think youd need to add at least some new support, or else the hood will seizure in the wind
#3 | |
Member#: 16653
Vehicle:2012 Mazda 3 2004 Honda Pilot |
Keeps the paint from getting baked by the engine heat. |
#4 |
Member#: 19193
Vehicle:2005 LGT Regal Blue |
Sport Compact Car did this on a Sentra SE a couple of years ago when they prepped it ghetto-style for track events. They made a lot of dents in the hood cuz there's a dense glue used to hold the hood down to the cross member supports. It worked, was lighter, but wasn't much to look at and flexed a lot during races. You will need hood pins as well.
Christian |
#5 | |
Member#: 66304
Vehicle:98 RWD BG Outback ...with R200 and ITBs ;) |
The cheaper/better way to do it might be to buy another steel hood and give it to someone who will mold fiberglass or carbon. I know a local guy and will probably have him make a few as soon as I get a day to go visit him. |
#6 | ||
Member#: 120
AKIC
I have seen some nice flush ones, I'll have to see if I can find them again. Here - http://www.aerocatch.com/automotive-home.html .Pat |
#7 |
Member#: 19681
RMIC
Vehicle:1998 Legacy Wagon GT Green |
The foam under hood serves the following purposes:
To make the engine quieter when the engine is running. To blanket the engine, in the event of a fire. Theory being that the plastic clips melt, and foam(or whatever it really is) drops on the engine, helping to put out a fire. It's not really a heat shield. It absorbs some of the heat, but isn't really designed to reflect it. The paint won't be damaged in any way if it's not there. But you don't have fire protection either. That didn't stop me, as I took mine off long ago. |
#8 |
Member#: 120
AKIC
I don't know why I haven't taken mine off. It looks like ass, as it's been soaked by coolant on a number of occasions when my head gaskets blew.
![]() Pat |
#9 |
Member#: 19681
RMIC
My personal opinion...
edit: damn that's a big pic! Hood pins good: ![]() Hood pins bad: ![]() |
#10 |
Member#: 4615
BAIC
Vehicle:05 STi, 97 Leg OB |
Best:
![]() ![]() mranlet, if you're going to get something molded, it'd be killer to make a larger hood opening (taller scoop) for the guys running forced induction. I'd certainly be interested in a carbon hood, and if there's a few guys interested, the cost would probably go down for you as well. Just a thought, though I know you're going the ITB route....... |
#11 |
Member#: 60224
Vehicle:2008 FXT Sports 2.5 Dark Grey Metallic |
I don’t have any under-hood insulation and I haven’t experienced any problems from it.
Man that hood will buckle like crazy with no under-reinforcement framing. Definitely pins would be mandatory, plus I’d try it out of a junk-yard hood first too. Maybe you can find one from an L, then cut your own scoop setup (i.e. taller wrx/sti scoop). PS: I’d be happy to help you out with the project when you’re in the area in the coming months ![]() |
#12 | |
Member#: 66304
If the footprint of one of the aftermarket WRX scoops is the same or larger, I could mold a OEM style (i.e. Stealthy) Outback or LGT hood and for those who want a larger scoop, just cut away the little one and rivet or resin on the larger unit... I personally will opt for a OEM style Outback hood and an airbox to seperate out rain and debris since. I'm effectively incapacitated until my R200 axles come in, so it may be a while. I'll keep the world updated of any progress. |
#13 | |
Member#: 120
AKIC
Pat |
#14 |
Member#: 82556
Vehicle:1996 Legacy L wagon |
For other people, a place that is not utilized too often are technical/vocational schools. There are alot of schools that will mill/lathe parts for you for cost of materials, because the students are doing it, they can not charge because the person doesn't hold a degree.
I know Colorado State has a CF molding lab, that they use for their mini-racers and other projects. |
#15 |
Member#: 36735
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
#16 |
Member#: 58806
Vehicle:1998 RIP Legacy2.5GT 2.2L legacy wagon |
Hmm i wonder how hard it was to get that bumper to fit...
#17 |
Member#: 66304
The Impreza bumper is supposedly the same width as the Legacy. I have a pic in another thread with an S14 Kouki R33 GTR style bumper mocked up on my car: http://forums.nasioc.com/forums/showthread.php?t=892802
The school that I go to, University of South Florida, has a CF lab for their formula SAE car. Maybe I'll check that out too. Other front end lightening that I'd like to do involves a Braille Auto No-Weight battery, bumper support lightening/replacement, fiberglass front bumper (which, BTW, didn't Pat win a fiberglass bumper on Ebay recently?), lightweight crank pulley and almunium control arms. The carbon hood would be the most bling of all those, and Paul Eklund had claimed that up to 40lbs of weight could be shaved by going from the metal Impreza hood to a fiberglass version. Blake Fuller also told me that he shaved 35lbs by going from the OEM Subaru battery to his No-Weight model, which is no bigger than 2 VHS tapes laid back to back. |
#18 |
Member#: 82556
A link to this battery?
#19 |
Member#: 66304
#20 | |
Member#: 4615
BAIC
#21 | |
Member#: 4615
BAIC
What might be cool is to pick a scoop style (bugeye, blobeye, the new '06's) and integrate that cutout; you could do one of the reverse scoops on an NA car for venting purposes, or place any aftermarket or OEM scoop on. A hood with a replaceable scoop element would be killer, but it's not your responsibility to make it happen (would just be cool if you have access to a company that's interested). I talked to Seibon at SEMA, and they're just not convinced there's a market, especially at the prices low production implies; it's rough; a lot of people would buy a carbon hood if it was like most other cars, in the 300-400 range, but when you talk about 800-900 plus shipping for a hood with a tiny opening (when most buyers are going turbo) it's a tough sell. |
#22 |
Member#: 82150
Vehicle:1998 Legacy SL-i.net White |
My buddy removed the "hood ribs" on his Eclipse. It weighs so much less it's not funny. Only draw back is when it's popped up with the hood stand the hood sags a lot. He also had to install hood pins.
#23 | |
Member#: 60224
Look at the difference: ![]() |
#24 | |
Member#: 36735
#25 | |
Member#: 36735
The car I posted is located in Ireland. |
| Thread Tools | |
| Display Modes | |
| FS: (SoCAL) Silver GT Hood for BD/BG | MannySoobia | Legacy Specific Parts | 3 | 05-01-2009 08:38 PM |
| heated mirror for BD/BG? | etam | Legacy Forum | 17 | 01-05-2004 07:20 PM |
| who needs skidplates for BD/BG | etam | Legacy Forum | 1 | 11-20-2003 01:16 AM |
| Whiteline rear strut bar for BD/ BG Legacy | BrokenCrank | Private 'For Sale' Classifieds | 4 | 10-07-2003 05:53 PM |
| Who wants JSM clear side markers for BD/BG Legacy? | yuji | Legacy Forum | 49 | 12-12-2001 08:20 PM |
