Old 10-04-2001, 07:54 PM   #1
GTkrockett
Member#: 8678
Silverish 2.5GT
Default tire size
anyone running 215/45/17's on a 7" rim 48" offset, with H&R springs? and if so, are you rubbing?
GTkrockett is offline   Reply With Quote
Old 10-04-2001, 10:13 PM   #2
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
I would highly recommend going down to 215/40/17 if you want to run 215mm, otherwise you will rub. Or go to a 205/45/17 and you should be ok... but may still rub when there's load in the rear.
GTBGUY is offline   Reply With Quote
Old 10-05-2001, 12:55 PM   #3
whitt
Member#: 8928
0216 02 WRX & 16 WRX
White & Lapis Blue
Question
how much wider are the H&R springs than the stock GT springs? Im running 215's and even with four people and their stuff and they dont rub
whitt is offline   Reply With Quote
Old 10-06-2001, 02:04 PM   #4
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Ok let me explain this. With a +48mm offset, you're bringing rubber closer to the fender. whitt - you have the newer Legacy, so you have a little more space to play with.
For the B(D/G) guys, if you want to go with a 215 section, definately go down to the 40 aspect ratio, especially if you're lowered (with +48mm offset). I've tried 215/45/17's lowered w/ my Speedline ST's and they didn't rub, but I wanted better handling so opted for 215/40/17.
Old 10-06-2001, 03:22 PM   #5
tora
Member#: 5851
09 Forester XT
+ NA Miata
I'm running 215/45-17's with a 43 mm offset. I am not lowered but I have been over some pretty big dips at pretty high speeds and have not rubbed at all, even with the car loaded down. I'm going to be lowering the car but you probably need this info sooner than I will be doing that. I'm guessing that I won't rub though.
tora is offline   Reply With Quote
Sticky for Rim sizes and tire sizes? TomsSound Brakes, Steering & Suspension 8 02-01-2012 09:30 PM
Tire sizes and speaker sizes... samtheblur Legacy Forum 9 06-03-2005 08:04 PM
Racing Tire Size to Street Tire Size mav1c Brakes, Steering & Suspension 0 11-18-2002 03:16 PM
Interesting Tire Size/Contact Patch Size/Shape Info - aka why I don't have 18" wheels rao Brakes, Steering & Suspension 6 06-19-2001 04:08 PM
Here is tire sizes chart. No more tire size Qs? Yeah, right! 25psi Brakes, Steering & Suspension 18 04-18-2001 03:29 PM
