Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-19-2006, 07:02 PM   #1
AURAz
Member#: 50056
2002 WRX, '91 S13
Dead Whorelando Drifting
Default UTEC 5.0 and CEL code P0102
So immediately after upgrading to UTEC 5.0 firmware, I started getting an intermittent problem. Sometimes during warm starts (after the car has been turned off for a few minutes) I get code P0102, mass air flow sensor circuit low input, after re-starting the engine. A day or two later the cel will go back off. The car always runs fine and it happened right when I upgraded the firmware, so it's not a sensor problem, something to do with the re-flash. I did a search and a few other people have had this problem, but the threads never end with any resolution. Anyone have thoughts? Thanks!
AURAz is offline   Reply With Quote
Old 04-19-2006, 11:00 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Talk to TurboXs and request 5.0a, note "a" firmware. The "5.0a" firmware fixes this issue.
mick_the_ginge is offline   Reply With Quote
Old 04-20-2006, 10:46 AM   #3
MidRex
Member#: 32841
2007 STI (Sold)
03 WRX FP Green PPG (RIP)
I've been having this problem for a while now and posted about it with no answers. I was actually thinking about replacing the MAF. I just called TXS and I am now going to load 5.0a.
MidRex is offline   Reply With Quote
Old 04-20-2006, 06:10 PM   #4
AURAz
Member#: 50056
2002 WRX, '91 S13
Thanks for the tip, I'll re-flash this weekend and keep you posted.
Old 05-14-2006, 06:58 PM   #5
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
I have the same problem. I did however replace the MAF sensor as it has almost 100K miles on it, and I noticed it was a little dirty. Figured it would be better to replace it than clean it.
Anyone know where I can get a copy of the 5.0a firmware?
coyote73176 is offline   Reply With Quote
Old 05-19-2006, 12:12 AM   #6
brocksdad
Member#: 107352
Not Respectable
I had this same problem. I was using version 5.0 with the stage 3 map loaded on it, when I switched to a bigger turbo, injectors..., I loaded the stage 4 map and haven't seen the problem since. I also replaced the MAF sensor, but it didn't do me any good.
brocksdad is offline   Reply With Quote
Old 05-21-2006, 04:27 AM   #7
zachary.berrier
Member#: 82476
GOD CREATED TURBO
LAG TO GIVE V8'S A CHANCE
I just upgraded also and i need the 5.0a firmware all help is appreciated . Im throwin these codes also
zachary.berrier is offline   Reply With Quote
Old 05-22-2006, 07:44 AM   #8
MidRex
Member#: 32841
2007 STI (Sold)
OK...I have been running the 5.0a firmware for 2 weeks now and I got P0102 again yesterday. I reset it and we'll see if it comes back. I'm gonna be at TXS this thursday and I am going to ask them about it then.
Old 05-22-2006, 08:08 AM   #9
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
Nathan at TXS sent me the 5.0a firmware. I loaded it over the weekend, and things seem to be worse now.
With the 5.0 the P0102 would come on maybe every 5-10 ignition cycles.
With the 5.0a the code comes up every other ignition cycle.
I am gonna re-flash the 4.2c and make sure there isn't a problem somewhere else in the circuit.
Old 05-22-2006, 01:24 PM   #10
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
Bit of an update...
I re-flashed with the 4.2c firmware, and the P0102 code has yet to come up. Of course the car has only been through a handful starting cycles, but with the other firmware the cel would have been on already.
I guess my car is just a little goofy.
Old 05-22-2006, 02:11 PM   #11
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Its not your car. A LOT of people have the problem. I personally ignore it. I think a while back somene figured out it was only if you put the car to ACC but didn't start it for a little bit...then when you started it the CEL will pop up. I just turn off the light in the UTEC and live with it since it doesn't change anything anyway.
cdvma is offline   Reply With Quote
Old 05-22-2006, 02:22 PM   #12
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
That could be the exact problem. I always leave the key in the acc position for a few seconds to let the fuel pump prime the system.
The light doesn't really bother me, but I live in NY and have my inspection (OBD-II) coming next month and will fail if I have any codes.
I plan on re-installing the 5.0 software after I get my inspection done, as I like some of the more advanced features in the 5.0 software.
Old 05-22-2006, 02:33 PM   #13
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Cool. Give that a shot and let us know if it works without putting they key in ACC. I too leave it there for the fuel pump to prime.
Old 05-23-2006, 11:26 AM   #14
MidRex
Member#: 32841
2007 STI (Sold)
I guess I am on the other end because mine seems to happen when I stop somewhere for just a few minutes, get back in the car, and start it without letting the pump prime.
coyote73176 - When you were at 5.0a did the UTEC transition seem to be worse than 5.0? Maybe it's just me though.
Old 05-23-2006, 11:48 AM   #15
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
I am not sure what you mean by the UTEC transition, but when I loaded the 5.0a the CEL would come on sooner than when I was using the 5.0 firmware.
If you mean the transition from ECU to UTEC control, I couldn't really tell you. I only had the 5.0a loaded for about a day before I went back to the 4.2c.
Old 05-24-2006, 10:02 AM   #16
MidRex
Member#: 32841
2007 STI (Sold)
Sorry...I did mean ECU to UTEC control. For me...with 5.0a it seems to take longer for the light to come on, but it still did. Like I said in one of my posts above...I will be at TXS tomorrow to get tuned on a Green and FM .
Old 08-18-2006, 01:55 PM   #17
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
Bumping old thread for those that may still have this problem.
I re-flashed my UTEC with the new 5.8 software. Cel for the MAF is now gone. Now to figure out the speed density fueling.
FS CO: UTEC 6b, 5.0 and HKS BOV ChristopherG Private 'For Sale' Classifieds 3 11-22-2005 03:00 AM
CEL codes P0102 and P0103 both NITROS Service & Maintenance 6 11-15-2005 06:13 PM
UTEC v5.0 help... CEL wastintime Engine Management & Tuning 21 09-26-2005 12:21 PM
utec 5.0 uploader won't recognize usb->seriel nuhga Engine Management & Tuning 1 09-23-2005 01:06 PM
Rave: UTEC 5.0 Cavadini Engine Management & Tuning 14 09-21-2005 11:08 AM
