#1 |
Member#: 110190
hey, i was wondering if the "check engine light" will come up if i just changed the muffler or intake on an 02 lgt. the reason why i ask this is because i took off the resonator one time and the "check engine light" came up that time.
so..do u think just changing the muffler or intake would do the same thing?
#2 |
Member#: 92423
Vehicle:2002 WRX still locked in freezer |
it shouldnt as long as you hook everything up the right way.
#3 |
Member#: 12874
Vehicle:2005 Outback XT 5spd Black |
I've got an aem CAI intake and a wrx muffler. and the CEL comes on during cold weather. Same thing happened on my 05 v6 accord though, so maybe its just the screwed up quebec air down here. lol.
#4 |
Member#: 94945
Vehicle:1995 Legacy OB 5MT 2003 Forester X 5MT |
The intake might, if the MAP is reading things a little different.
Reset the ECU, the problems should go away. If a code comes back on, get it read at the Advance auto. |
#5 | |
Member#: 9853
International
Vehicle:to keep your mouth shut. |
You're pretty far up compared to us normal people. ![]() |
#6 |
out back
Moderator Member#: 1964
RMIC
Vehicle:01 BH Blue/Bronze |
I'm running a Cobb CAI, Cobb lightweight pulley, Exedy flywheel and a Borla/Random/Fujitsubo exhaust. No CEL.
Reset the ECU, it should adapt. |
#7 |
Member#: 76382
BAIC
Vehicle:2000 BH BP Wannabe |
Maybe there is a problem with your O2 sensor.
#8 |
Member#: 110190
where can i get the ECU resetted?
also, how many inches is the piping? ty |
#9 |
out back
RMIC
Disconnect the battery, step on the brake pedal for a few minutes, and let it sit for 30 minutes to an hour. Reconnect, drive normally.
2.25" OD is the commonly accepted diameter for a 2.5 non-turbo exhaust. |
| Thread Tools | |
| Display Modes | |
| FS: (UT) 2005 LGT mufflers and engine cover | suzysube | Legacy Specific Parts | 2 | 07-25-2009 09:43 PM |
| 99-2.5RS with 02-RS Engine - Intake question | mr_subaru_rs | Normally Aspirated Powertrain | 0 | 05-06-2009 05:04 PM |
| COBB new LGT SF intake 70mm can be used as STI big MAF also. | Kastley85891 | TXIC Private Classifieds | 6 | 04-08-2008 11:54 PM |
| 97 LGT ebay intake? | illegal2.2 | Legacy Forum | 17 | 04-04-2006 09:18 PM |
| any Pro, Con about 02 SPT muffler on 02 RS? | windfactory | Normally Aspirated Powertrain | 7 | 07-11-2002 11:09 AM |
