Old 04-20-2006, 02:56 PM   #1
lovecars23
Member#: 84383
Default My (lock) lug nut off my wheel fell off...help
My (lock) lug nut off my wheel fell off....i don't know where
but i just had my wheels replaced like less than 2 months ago
from Irvine Subaru
hehe....think they will cover it?
if not what do they sell individual locks that match all 3 of the others?
Thank you for your help
lovecars23 is offline   Reply With Quote
Old 04-20-2006, 03:11 PM   #2
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Fell off? Did you forget to torque it down?
You're likely going to have to buy a new set.
bl_easy is offline   Reply With Quote
Old 04-20-2006, 03:14 PM   #3
lovecars23
Member#: 84383
I didn't do it they installed it
Old 04-20-2006, 03:15 PM   #4
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Then they will no charge you.
MF-DIF is offline   Reply With Quote
Old 04-20-2006, 03:35 PM   #5
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
alloy wheels need to be retorqued about 100 miles after they have been mounted.
the simplest way to describe it is that the alloy "settles." someone that understands metalurgy better than i do can go into more detail.
alway check the torque of your lug nuts about 100 miles after the wheels have been put back on the car.
greg donovan is offline   Reply With Quote
Old 04-20-2006, 03:39 PM   #6
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
You will probaly have to get new ones like bl_easy said. And you might want to go outside as soon as you can and check all your other lug nuts. Get a torque wrench and tighten them babys up. I don't know how much to torque them to but someone on here will speak up in a few.
breathinez is offline   Reply With Quote
Old 04-20-2006, 03:40 PM   #7
greg donovan
Member#: 60743
'95 Impreza L
i torque mine to about 85-90 foot pounds.
Old 04-20-2006, 03:40 PM   #8
kaisersouse
Member#: 85900
2001 Forester S
I thought it was between 65 and 75 f/lbs
kaisersouse is offline   Reply With Quote
Old 04-20-2006, 03:46 PM   #9
dj_booduh
Member#: 70861
2005 Scoobie WRX
80 f/lbs that's what my mechanic and everyone around sd that I know that drives a suby says.
dj_booduh is offline   Reply With Quote
Old 04-20-2006, 04:18 PM   #10
Lachlan
Member#: 19470
1981 Brat GL
65.7 ft-lbs according to subaru. Why would you want to overtorque?
Lachlan is offline   Reply With Quote
Old 04-20-2006, 04:21 PM   #11
bl_easy
Member#: 91407
BRetty green
Overtorquing the lugs too much is baaaad.
When I first got my car, the lugs were on right (not cross-threaded) but on TIGHT as hell. When I wanted to put my new wheels on, I think 2 wheel studs were just totally seized and broke off. Getting the old ones out and new ones in was not fun
Most I do is 70 ft-lbs
Old 04-20-2006, 04:22 PM   #12
lovecars23
Member#: 84383
After a little talking to Irvine Subaru
they decided to give me a whole set of new locks for free
but wow Rich at Irvine is a weird guy never smiles just looks at you
he gave me the locks but eh that guy is kinda a jerk
i have had probs with him before
I GUESS THE BEST WAY TO GET MY ANSWER WAS TRY IT
BUT THANK YOU EVERYONE FOR YOUR HELP
Old 04-20-2006, 04:32 PM   #13
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
^^^ glad it worked out for you
Surfer Steve is offline   Reply With Quote
Old 04-20-2006, 04:37 PM   #14
bl_easy
Member#: 91407
BRetty green
Don't forget to check the torque every now and then
Old 04-20-2006, 05:38 PM   #15
lovecars23
Member#: 84383
Thanks i will for sure
Old 04-21-2006, 01:40 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....'the book' says 65.7ft-lbs.....I use ~70......never broke a lug.....jack the car up ~1/2 way---THEN loosen the lugs
RE-torque after 100 miles
Old 04-21-2006, 02:04 AM   #17
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
Why half-way?
I've always broke the lugs with the wheels on the ground and then took her up.
D fresh is offline   Reply With Quote
Old 04-21-2006, 02:12 AM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by D fresh
Why half-way?
....weight on the wheels puts LOTS and LOTS of pressure on the lugs after they have been in use for a while....jacking the car enough so that the lugs can spin off without the weight of the car keeping the lugs tight helps keep the lugs from breaking off when ya try to loosen them.
I also use my 12v cordless impact, gives ~60-65 ft-lbs, to put the lug nuts on before I drop the car....then I roll the car a bit to equalize all the lugs before I final torque them with the torque wrench.
Old 04-21-2006, 05:39 AM   #19
D fresh
Member#: 95459
the activity level
^^^Makes sense, I figured that was the reasoning behind it. I'll have to give it a try.
nnj wtt my tuner lug nuts for stock sti lug nuts fosingwo Wheels/Tires 0 04-02-2010 01:57 AM
WI/IL: Subaru wheel locks, Muteki lug nuts, and lug nuts to replace wheel locks JWA Wheels/Tires 7 03-22-2010 04:52 PM
Volk Lugs Aluminum Extended Lug Nuts, Volk Locking Lug Nuts, Genuine Suby Wheel Locks timeless Wheels/Tires 10 08-21-2008 01:06 AM
My Stock Lug Nuts Suck On My New Wheels??? EjMiami Tire & Wheel 8 05-28-2006 03:19 PM
('93-'01) My wheel fell off SuBart Impreza Forum 10 08-01-2002 06:38 PM
