Old 04-21-2006, 01:24 PM   #1
bluecamel04
Member#: 88287
2005 Subaru STI
Default RA gears Vs PPG gears
well it has been the longest debat now for me is to which i go with, the plan is running a 20g maybe super zila on the car and i def need a bette gears than what i have at my stock tranny. for haveing about 370-400 whp. what are you guys thoughts and experinces with them
bluecamel04 is offline   Reply With Quote
Old 04-21-2006, 01:53 PM   #2
AttaQ
Member#: 20301
2004 BMW M3
lightweight optioned
For that much torque, I would say you are better off going with something beefier than an RA gearset.
AttaQ is offline   Reply With Quote
Old 04-21-2006, 02:35 PM   #3
Beebs99
Member#: 73803
2008 4 Door WRX
ppg's are a huge upgrade over ra's.
Beebs99 is offline   Reply With Quote
Old 04-21-2006, 02:48 PM   #4
josh04
Member#: 89288
2002 Rex
Yeah RA gears are only safe rated a little over 300whp. At least that's what I've read.
josh04 is offline   Reply With Quote
Old 04-21-2006, 02:57 PM   #5
Beebs99
Member#: 73803
2008 4 Door WRX
Oh yeah, ppg 1 & 2 is a good option with 04+ gears 3-5.
Old 04-21-2006, 08:27 PM   #6
ejh25
Member#: 65267
There isn't really much of a comparison between the RA and PPG. PPG is far superior.
ejh25 is offline   Reply With Quote
Old 04-21-2006, 08:30 PM   #7
S4toSTI
Member#: 85210
2008 Si
Taffetta White
Tho PPG gears are a tad more expensive don't you think.
S4toSTI is offline   Reply With Quote
Old 04-21-2006, 08:58 PM   #8
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
You get what you pay for
Old 04-21-2006, 09:17 PM   #9
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Xeleventy
Old 04-21-2006, 09:23 PM   #10
le wagon
Member#: 109109
2005 WRX wagon
Wrong Fitment Crew #015
you might as well buy the sti 6-speed IMO if your gonna get PPG gears
le wagon is offline   Reply With Quote
Old 04-21-2006, 09:40 PM   #11
S4toSTI
Member#: 85210
2008 Si
Taffetta White
but in order to do a sti tranny right you should do a rear end and when you figure all of that you may as well buy a sti.
Old 04-22-2006, 02:11 AM   #12
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
BAD ADVICE. Please don't throw around blanket statements. There are goods/bads to RA sets, OEM sets, PPG sets, 6MTs, etc. For example, someone who drag races would be better off using a PPG 5MT over a STi 6MT.
Old 04-22-2006, 10:17 AM   #13
ejh25
Member#: 65267
Please support your comment with some fact. The PPGs are an absolutely amazing gearset.
Old 04-22-2006, 10:51 AM   #14
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Are the gear ratios any different in the PPG gear set? I am planning on 2.5 hybid with 18g turbo and meth inj at 400 tq /hp Think the 1-2 PPG gearset only with stock (I have 04 WRX) 3-5 OEM gear set will suffice? I don't drag race (like 1-2 passes a year now that that's out of my system) and I daily drive the car. Almost ALL my fun is romping from 40 mph on.
CoolRex is offline   Reply With Quote
Old 04-22-2006, 10:58 AM   #15
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
If you are in doubt what do buy buy PPG as ra can not take the punishment. I have had both. I have actually done wheel spins really ez with ppg. How many threads can ra's say about that? I have busted 3 syncro's now with ppg and no sign of problems. I am upgrading to all three diff's next.
ra ratio's are nice for keeping power in the power band but thats it.
Old 04-22-2006, 11:05 AM   #16
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
After reading some more threads I think I don't have the wider gears in my car??? When I did my clutch my tranny has stubs that the axles slid on and had to pop/install those pins. Does that mean my 04 doesn't have the wider gears?
Old 04-22-2006, 11:10 AM   #17
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
All 04s have the wider gears. You need to read the Transmission FAQ and brush up on your knowledge.
Old 04-22-2006, 11:13 AM   #18
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
That was what I thought....there is a lot of misinformed people that confuses those like me who thought otherwise. Thanks for clearing that up. What is this about the mid 04's and stubless being stronger??
Old 04-22-2006, 11:29 AM   #19
CynicX
Member#: 48199
06 WRX
PPG is going to be alot LOUDER and more expensive then the RA. But they are also going to be stronger....The noise is something you may want to keep in mind if this is your DD. Some people love it, I on the other hand wouldnt be able to tolerate it for long drives if my wrx was my DD...
CynicX is offline   Reply With Quote
Old 04-22-2006, 11:31 AM   #20
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Well I am thinking of doing only 1-2.
Old 04-22-2006, 11:49 AM   #21
keaniegenie
Member#: 94494
2005 Element 92x
I'm going to try to respond to everything I've read so far. Unabomber, please fill in if I miss something.
1.) 04+ WRX gears are RA width, but aren't RA strength. Please read "Gearbox Technical Discussion" in the sticky's for details. (Thanks Rallispec)
2.) RA's and PPG's are no different than any other gearset. Abuse CAN break them. That said, PPG's are definitely capable of handling more abuse and torque than RA gears.
3.) There are several users I've talked to who have RA's pretty good size turbos and are okay. One has them on a 2.5l hybrid and a 20g, another has the STI-non RA gears on a 2.5l hybrid and a GT30R .82!(the STI non RA gears are the same design as RA's with different ratios). I also know users who've broken several RA's on a 2.0l. I would probably not recommend RA's for your 20g if your drag racing, but for spirited Daily driving, I think you're fine.
4.) STI 6-speeds are another option, but not superior to a PPG 5MT. PPG gears should still handle more power than than a 6-speed. Also, you DO NOT have to use the entire STI rear-end to use a 6mt. A 4EAT shaft will adapt to the STI 6-speed.
5.) The kind of clutch you use should also be considered. If you plan on having a 6 puck racing clutch, get PPG's or a 6mt. If you stick to an organic sprung clutch, you'll probably be fine with RA's. With your setup, you'll probably have to get a new clutch as the stock WRX clutch is only capable of handling around 280wtq or less.
You'll definitely be near the limits of your RA's with a new clutch and the 20g, but there are definitely people running that setup and are fine.
keaniegenie is offline   Reply With Quote
Old 04-22-2006, 12:07 PM   #22
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Thanks for that. My tuner told me to go RA and I am gonna but I like to weigh my options. I am gonna go 2.5L Hybrid with td05 18g and RA gears. However I do need to get an organic clutch and ditch the puck one I have.
Old 04-22-2006, 01:39 PM   #23
keaniegenie
Member#: 94494
2005 Element 92x
If you get a td05-18g, get the greddy one. They have had great results on hybrids. I personally wouldn't go smaller than a 20g, but that's me.
Good luck!
Old 04-22-2006, 06:49 PM   #24
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Good luck!
I already have a Deadbolt td05 18g on my stock 2.0L engine with meth inj.
Old 04-22-2006, 07:24 PM   #25
Jersey Dino
Member#: 85242
2002 WRX Sedan
RA gears=stock gears. a little stronger. though they are awesome to drive becasue of the ratios...they are not all that strong. if you like to drive your car get something else. 6 speed is the way to go. I can say this becasue i broke stock gears and RA gears. at 230whp and around 290-300 whp. they are not that strong. second gear broke each time the same way on the same street around the block from my house if you can beleive that.
Jersey Dino is offline   Reply With Quote
Legacy GT 1-4 gears vs PPG 1,2 IllNastyImpreza Transmission (AT/MT) & Driveline 6 03-31-2007 01:55 AM
07 gears vs 06 gears mph cobbsti06 Transmission (AT/MT) & Driveline 2 03-29-2007 05:55 PM
PPG vs. STi RA vs. Stock GEAR QUESTION holdtight bp Transmission (AT/MT) & Driveline 4 11-09-2005 12:21 PM
Pics of some STi RA Gears vs. WRX gears taken at RalliSpec Geoff Transmission (AT/MT) & Driveline 18 10-20-2004 10:33 AM
Top Gear vs. Fifth Gear dr_wheel Off-Topic 31 09-23-2004 06:31 PM
Message Board Statistics All times are GMT -4. The time now is 02:30 PM.
