Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-21-2006, 06:40 PM   #1
Cjchaps
Member#: 3181
07 Rav4
Default How do you tell when a 12 Volt 20 Amp battery is going bad?
I have a robomower and it takes two 12 Volt 20 Amp batteries. Do you measure the volts or amps or both to tell when it is going bad? I measured the volts with my multimeter and they both come up about 13.5 Volts and I couldn't test the amps because my multimeter only measures up to 10 amps...
Cjchaps is offline   Reply With Quote
Old 04-21-2006, 06:41 PM   #2
jamz
Member#: 8725
2013 Black Company
Annalist
When it slaps you and takes your wallet.
jamz is offline   Reply With Quote
Old 04-21-2006, 06:42 PM   #3
alacrity024
Review Crew
Member#: 49476
stick your tongue across the terminals. if you get a little tingle it's okay.
alacrity024 is offline   Reply With Quote
Old 04-21-2006, 06:51 PM   #4
ShortThrow
Member#: 92607
check if it tastes funny
ShortThrow is offline   Reply With Quote
Old 04-21-2006, 06:54 PM   #5
Cjchaps
Member#: 3181
07 Rav4
I already did that when I stuck my tongue on it
Old 04-21-2006, 07:02 PM   #6
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Don't try to measure amps directly with your multimeter... you need a load. Did you maybe mean 20 Ah instead of amps?
Anyway, you typically measure voltage to test a battery.
BJamerican is offline   Reply With Quote
Old 04-21-2006, 07:26 PM   #7
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Unless your testing a car/truck sized battery. Its a combination of reading the voltage and testing the amps. Only a true battery tester can put a load on a battery and measure the amps.
I've tested batteries here at work that put out 12v but tested at zero amps.
Old 04-21-2006, 08:22 PM   #8
Physics Junkie
Member#: 65609
Voltage is the ability for electrons to flow from the anode to the cathode...
The volt is defined as the potential difference across a conductor when a current of one ampere dissipates one watt of power(represented as one joule of energy per coulomb of charge, J/C).
An ampere is a base unit of electric current equal to one coulomb per second.
Physics Junkie is offline   Reply With Quote
Old 04-21-2006, 08:33 PM   #9
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Take it to Autozone and ask them to test it for you.
chapstien is offline   Reply With Quote
Old 04-21-2006, 10:28 PM   #10
Cjchaps
Member#: 3181
07 Rav4
Old 04-21-2006, 10:30 PM   #11
Cjchaps
Member#: 3181
07 Rav4
What is the difference between an amp and an Ah?
It's Amp hours right?
How do you tell when a possum isn't just playing? fliz Off-Topic 23 05-10-2010 12:52 PM
How can you tell when the water pump is going bad? GreasyJoe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-30-2008 06:25 PM
How do you tell other people at work that the office is not daycare? rogue Off-Topic 36 06-01-2006 05:32 PM
How do you tell when your differential oil is low? only1agam Newbies & FAQs 8 11-14-2004 09:53 PM
How do you know when EGT gauge is going bad? Jsunn Interior & Exterior Modification 1 07-16-2003 09:21 AM
