Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 04-21-2006, 11:33 PM   #1
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
Default OPEN/CLOSED LOOP BOOST CONTROL?(pics)
I just installed my TMIC, 18g and pink injectors, so I had to download Stage4 parameters. The parameters had cosed loop boost maps. With my set up I was boosting 18psi with closed Boost map of 400. With open Boost map of 80 I was boosting 18.1psi more spiky Though. Has anyone try the diference between open/closed boost control?
my
new baby
gaby is online now   Reply With Quote
Old 04-21-2006, 11:50 PM   #2
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Open loop is generally more consistant. What turbo is that on the left?
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 04-22-2006, 12:10 AM   #3
gaby
Member#: 94097
11.2@130.7
Left OEM WRX Right Turbochargers.com 18G.
Old 04-22-2006, 12:14 AM   #4
gaby
Member#: 94097
11.2@130.7
Exhaust side compare
Old 04-22-2006, 09:38 AM   #5
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Its just that the compressor side doesnt really look any bigger in that photo. I know when I got my big 16g, the size difference was extremely obvious. The exhaust side pics show the diff. a little more though.
Jeff
Old 04-22-2006, 09:09 PM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Really? I've never seen any data to say either is better than the other. By definition open loop should be subject to more variation than closed loop. Care to further explain your position?
cdvma is offline   Reply With Quote
Old 04-22-2006, 09:45 PM   #7
Freon
Member#: 88322
2009 BMW 135i
Err, no way. Use closed loop... It will be more consistent. Open loop you just set your boost control solenoid duty cycle. Whatever boost that happens to make, there you are. You could make different boost level every day of the week.
I don't think anyone uses open loop on a UTEC these days. I wouldn't touch it. Maybe in certain circumstances (like a drag-only car) it might make sense.
Freon is offline   Reply With Quote
Old 04-23-2006, 06:17 AM   #8
gaby
Member#: 94097
11.2@130.7
I think is a normal 16g t05 compresor with a 18g clip. It was easier to set the open loop, why will it change the boost every day?
Old 04-23-2006, 12:52 PM   #9
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
What 18g is it, Deadbolt or FP or other?
Jeff
Old 04-23-2006, 02:25 PM   #10
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Read the thread Jeff
He said its a Turbochargers.com 18G and I also asked a question, if you could scroll up and answer it I'd appreciate it, thanks.
Old 04-23-2006, 06:01 PM   #11
gaby
Member#: 94097
11.2@130.7
It is an 18g from turbochargers.com( I am very happy with it). Deathbolt got the same one bot is ceramic coated, Forceperformence do have the same one. It uses the same compresor(t05) from the big 16g. I get 19psi(tha's what Im runing) at 3900rpms, 15 psi at 3500rpm and I haven't dynno tunned it yet. I maxxed out my oem injector at 9psi400rpms with this baby and the pinks are running 83% at 10:1afr. It really put some cfms on my car.
Old 04-29-2006, 04:18 PM   #12
gaby
Member#: 94097
11.2@130.7
update : Im using the closed loop option a it reduced the spike and gain lower end boost.
Old 04-29-2006, 06:00 PM   #13
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
sorry, i didnt catch it earlier.
Jeff
Close Loop Boost vs. Open Loop Boost chuglobal Engine Management & Tuning 35 10-27-2004 03:07 PM
2004 open/closed loop question nate49509 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-24-2004 05:35 PM
What's available in Map/Closed loop boost controllers snookem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-03-2002 09:46 PM
at wat RPM does MAP cars switch open/closed loop? wistful Normally Aspirated Powertrain 4 10-14-2001 03:06 PM
Unichip Closed Loop Boost Control D_REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-25-2001 12:41 PM
